Home » Eclipse Projects » DTP » new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db
new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db [message #35173] Tue, 21 August 2007 22:10 Go to next message
Charles Doucette is currently offline Charles DoucetteFriend
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1762)
at java.lang.String.substring(String.java:1735)
at
org.eclipse.datatools.enablement.msft.sqlserver.profile.ui.l oaders.SQL2005RoutineLoader.loadSource(SQL2005RoutineLoader. java:185)
at
org.eclipse.datatools.enablement.msft.sqlserver.profile.ui.l oaders.SQL2005RoutineLoader.access$0(SQL2005RoutineLoader.ja va:180)
at
org.eclipse.datatools.enablement.msft.sqlserver.profile.ui.l oaders.SQL2005RoutineLoader$SQL2005ProcedureFactory.initiali ze(SQL2005RoutineLoader.java:51)
at
org.eclipse.datatools.connectivity.sqm.loader.JDBCRoutineLoa der$ProcedureFactory.createRoutine(JDBCRoutineLoader.java:36 3)
at
org.eclipse.datatools.enablement.msft.sqlserver.profile.ui.l oaders.SQL2005RoutineLoader.processRow(SQL2005RoutineLoader. java:134)
at
org.eclipse.datatools.enablement.msft.sqlserver.profile.ui.l oaders.SQL2005RoutineLoader.loadRoutines(SQL2005RoutineLoade r.java:152)
at
org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCSch ema.loadRoutines(JDBCSchema.java:191)
at
org.eclipse.datatools.connectivity.sqm.core.rte.jdbc.JDBCSch ema.getRoutines(JDBCSchema.java:152)
at
org.eclipse.datatools.modelbase.sql.schema.impl.SchemaImpl.g etSpecializedRoutines(SchemaImpl.java:450)
at
org.eclipse.datatools.modelbase.sql.schema.impl.SchemaImpl.g etProcedures(SchemaImpl.java:426)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.vnode.ServerExplorerVNodeCon tentProviderNav.displayStoredProcedureNodeChildren(ServerExp lorerVNodeContentProviderNav.java:192)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:1 90)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:2 44)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractLayoutProviderNav.ge tChildren(AbstractLayoutProviderNav.java:88)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.impl.ServerExplorerContentProviderN av.getChildren(ServerExplorerContentProviderNav.java:231)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.impl.ServerExplorerContentProviderN av.hasChildren(ServerExplorerContentProviderNav.java:272)
at
org.eclipse.datatools.connectivity.ui.CommonContentProviderB ase.hasChildren(CommonContentProviderBase.java:254)
at
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.hasChildren(SafeDelegateTreeContentProvider .java:107)
at
org.eclipse.ui.internal.navigator.extensions.SafeDelegateTre eContentProvider.hasChildren(SafeDelegateTreeContentProvider .java:292)
at
org.eclipse.ui.internal.navigator.NavigatorContentServiceCon tentProvider.hasChildren(NavigatorContentServiceContentProvi der.java:662)
at
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:2014)
at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer .java:563)
at
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:2044)
at
org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTreeViewer.java:2668)
at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.j ava:823)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:807)
at
org.eclipse.ui.navigator.CommonViewer.createTreeItem(CommonV iewer.java:150)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:781)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:755)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:615)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1407)
at
org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:906)
at
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1418)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:125)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7053)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 8)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1541)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5798)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3705 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5370)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 64)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
at
at
at
at
at
at
at
at
at
at
org.eclipse.datatools.modelbase.sql.schema.impl.SchemaImpl.g etUDFs(SchemaImpl.java:433)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.vnode.ServerExplorerVNodeCon tentProviderNav.displayUDFNodeChildren(ServerExplorerVNodeCo ntentProviderNav.java:183)
at
org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.AbstractOnDemandContentProvi derNav.getChildren(AbstractOnDemandContentProviderNav.java:1 94)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db [message #35197 is a reply to message #35173] Wed, 22 August 2007 01:48 Go to previous messageGo to next message
Originally posted by: hui.cao.sybase.ocm
Please open a bug against the mssql enablement project. Thanks!
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:fafo01$m0b$1@build.eclipse.org...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db [message #35292 is a reply to message #35197] Wed, 22 August 2007 15:53 Go to previous message
done - bug #200843:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=200843
Chuck
"Hui Cao" <hui.cao@sybase.ocm> wrote in message
news:fag4l8$r95$1@build.eclipse.org...
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db [message #587525 is a reply to message #35173] Wed, 22 August 2007 01:48 Go to previous message
Hui Cao is currently offline Hui CaoFriend
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db [message #587556 is a reply to message #35197] Wed, 22 August 2007 15:53 Go to previous message
done - bug #200843:
Chuck
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:new error from DTP 1.5 with Eclipse 3.3.0 accessing stored procedures from SQL Server 2000 db
Next Topic:Editor core plugin internal error: java.net.UnknownHostException
Current Time: Sun Jun 13 05:35:34 GMT 2021
Powered by FUDForum. Page generated in 0.04678 seconds
