Home » Eclipse Projects » XML Schema Definition (XSD) » Conversion from XML to HTML
Conversion from XML to HTML [message #35137] Thu, 08 January 2004 11:31 Go to next message
Originally posted by: sandeepm.in.nds.com
I just want to know if there is an API, if so what is the package name for
me to convert an XML file to HTML by applying a stylesheet. I've already
written the stylsheet. Is there any class that loads the stylesheet and
then applies it on an XML file.
Is this possible using JAXP or SAX. I just want to know the package name
of the class name if possible.or a link to a page containing the
information
Thank you
Re: Conversion from XML to HTML [message #35189 is a reply to message #35137] Thu, 08 January 2004 21:25 Go to previous message
David Steinberg is currently offline David SteinbergFriend
Hi Sandeep,
I think you might be in the wrong place. This newsgroup is for the XML
Schema Infoset Model project, which has nothing to do with stylesheets or
XML transformations.
Sorry I can't be of more help.
Dave
Re: Conversion from XML to HTML [message #582354 is a reply to message #35137] Thu, 08 January 2004 21:25 Go to previous message
Hi Sandeep,
Dave
Previous Topic:Conversion from XML to HTML
Next Topic:problem with headless xml schema -> genmodel
Current Time: Thu Sep 24 21:50:14 GMT 2020
Powered by FUDForum. Page generated in 0.08035 seconds
