drop schema lars; results in syntax error [message #34890] |
Sun, 19 August 2007 22:45 |
I have in Derby 10.2.2.0 a schema called "lars". This was created via the
SQL Editor and the following statement:
create schema lars;
I'm not able to delete this schema. If I type the following into the SQL
Editor:
drop schema lars;
The SQL Editor returns with an error message:
Syntax error: Encountered "<EOF>" at line 2, column 18.
Can you please check? I assume this is a bug and will open a bug report for
this if noone know a solution for this.
Best regards, Lars
Re: drop schema lars; results in syntax error [message #34944 is a reply to message #34890] |
Mon, 20 August 2007 02:31 |
Originally posted by: hui.cao.sybase.ocm
Hi Lars,
The error comes from Derby server and this is not a bug. You should use:
drop schema lars RESTRICT;
instead.
Here's the exerpt from the Derby manual:
The RESTRICT keyword enforces the rule that no objects can be defined in the
specified
schema for the schema to be deleted from the database. The RESTRICT keyword
is
required
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:faah63$s73$1@build.eclipse.org...
> Hello,
> create schema lars;
> Editor:
> drop schema lars;
> for this if noone know a solution for this.
> Best regards, Lars
Re: drop schema lars; results in syntax error [message #35080 is a reply to message #34944] |
Mon, 20 August 2007 18:32 |
Hi Hui,
thank you.
Best regards, Lars
"Hui Cao" <hui.cao@sybase.ocm> wrote in message
news:faaue1$io$1@build.eclipse.org...
> Hi Lars,
> use:
> instead.
> the specified
> keyword is
> required
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> Hello,
>> create schema lars;
>> Editor:
>> drop schema lars;
>> Best regards, Lars
Re: drop schema lars; results in syntax error [message #587468 is a reply to message #34944] |
Hi Hui,
thank you.
Best regards, Lars
> Hi Lars,
> use:
> instead.
> the specified
> keyword is
> required
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> Hello,
>> create schema lars;
>> Editor:
>> drop schema lars;
>> Best regards, Lars
FUDForum. Page generated in 0.02077 seconds
