Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » "Internal FBs" in a Basic Function Blocks(How to use the FBs defined in the properties of a Basic Function Block ?)
"Internal FBs" in a Basic Function Blocks [message #1872165] Thu, 24 October 2024 08:53 Go to next message
Dear Experts,
I am defining a Basic Function block starting from the template.
In the "Properties" tab of the new function block there's a sub-tab called "Internal FBs". Here I found I can add function blocks from the library.
My question is: how do I use these blocks ? I imagined I would be able to use it inside a function, such as "internalBlockInstance.IN = TRUE;", however this does not seem to work.
Can anyone shed some light ?
Guido
Re: "Internal FBs" in a Basic Function Blocks [message #1872195 is a reply to message #1872165] Thu, 24 October 2024 17:58 Go to previous messageGo to next message
internal FBs is an idea that was translated from IEC 61131-3 to IEC 61499. Similar to IEC 61131-3 where internal variables of FBs can also be FBs we added this as additional list. You can call FBs in your algorithms like you can do that in IEC 61131-3.
We destinquish two different call types:
1. if the FB has only one input event:
internalFB(IN := TRUE, OUT => var3);
2. if the FB has more then one event the event name acts as method name:
internalFB.REQ(IN := TRUE, OUT => var3);
internalFB.INIT(QI := TRUE, QO => var2);
I hope this helps.
Alois
Re: "Internal FBs" in a Basic Function Blocks [message #1872234 is a reply to message #1872195] Fri, 25 October 2024 09:27 Go to previous messageGo to next message
Hello everyone!
I'm trying to make a SimpleFB with ST algoritm. I use internal FBs (TON and R_trig in particular) like this:
TON0(IN:= Work, PT:= CommonSwitchTime, Q=> NeedSwitchPLS);
And when I'm trying to export the FB it shows an error of output variable Q:
Unhandled parameter types: [org.eclipse.fordiac.ide.model.structuredtext.structuredText.impl.OutArgumentImpl@5350383e (var: Q) (not: false)]
So I wonder whether my FB_TON instance call is written in a right way or do I miss something?
Maxim
Re: "Internal FBs" in a Basic Function Blocks [message #1872237 is a reply to message #1872195] Fri, 25 October 2024 09:44 Go to previous messageGo to next message
Thanks, very clear explanation !
Re: "Internal FBs" in a Basic Function Blocks [message #1872261 is a reply to message #1872237] Fri, 25 October 2024 17:55 Go to previous messageGo to next message
Hi Maxim,
this feature only works correctly in the preview versions of the upcoming release. Please use the 4diac IDE release you can get from here https://download.eclipse.org/4diac/updates/rc/
If you scroll down there are the zip files for the different platforms.
Re: "Internal FBs" in a Basic Function Blocks [message #1872446 is a reply to message #1872195] Thu, 31 October 2024 06:15 Go to previous messageGo to next message
Hallo Alois!
Thank you a lot! I'll try. Do I need to use some new version of FORTE source files either?
Re: "Internal FBs" in a Basic Function Blocks [message #1872479 is a reply to message #1872446] Fri, 01 November 2024 04:18 Go to previous messageGo to next message
Yes please use the latest 4diac FORTE source from our github repository. Here please use the freeze branch.
Re: "Internal FBs" in a Basic Function Blocks [message #1872485 is a reply to message #1872195] Fri, 01 November 2024 09:33 Go to previous message
Thanks!
[Updated on: Fri, 01 November 2024 09:59] by Moderator
Previous Topic:How to create IEC 61131-3 callable function in 4diac?
Next Topic:Interfacing input-->output with type ANY_MAGNITUDE
Current Time: Thu Jul 17 12:36:50 EDT 2025
Powered by FUDForum. Page generated in 0.27112 seconds
