Home » Eclipse Projects » GEF » zest examples SimpleExample: JavaFX-Runtime-Komponenten fehlen
zest examples SimpleExample: JavaFX-Runtime-Komponenten fehlen [message #1871160] Tue, 17 September 2024 09:48 Go to next message
I follow the explanations of https://github.com/eclipse/gef?tab=readme-ov-file and want to try out the examples as described in the "Run the examples" section. I did all the setup - I think - in the right way as described. But when i try out the example in org.eclipse.gef.zest.examples SimpleExample I get the error message
Fehler: Zum Ausführen dieser Anwendung benötigte JavaFX-Runtime-Komponenten fehlen
I add some screenshots to show my configuration
I appreciate any hint, thank you
Christian
Re: zest examples SimpleExample: JavaFX-Runtime-Komponenten fehlen [message #1871223 is a reply to message #1871160] Wed, 18 September 2024 08:09 Go to previous messageGo to next message
Hello Christian!
As a starting poing please consider the blog post: https://blogs.itemis.com/en/after-eight-eclipse-development-with-java-and-javafx and the forum thread https://www.eclipse.org/forums/index.php?t=msg&th=1113522&goto=1860988&#msg_1860988 .
Hope that helps!
Tamás
Re: zest examples SimpleExample: JavaFX-Runtime-Komponenten fehlen [message #1871238 is a reply to message #1871223] Wed, 18 September 2024 09:51 Go to previous messageGo to next message
Hi Tamas
I first tried your second solution and got (see screenshot).
The first one I would like to skip, because I use already OpenJDK 21 and OpenFX 21 and Eclipse 4.33.0, but it seems I have not really an option?
Thans in any case!
Christian
Re: zest examples SimpleExample: JavaFX-Runtime-Komponenten fehlen [message #1871367 is a reply to message #1871238] Mon, 23 September 2024 11:58 Go to previous message
If you need any futher assistance, I suggest you to comment the itemis blog post above and describe the problem there ( maybe as a reference to this forum thread), there you may find someone who could help you.
Tamás
Previous Topic:Using GEF for a Track Planning system?
Current Time: Wed Feb 12 05:29:59 GMT 2025
Powered by FUDForum. Page generated in 0.04942 seconds
