Home » Modeling » TMF (Xtext) » Code Action Resource access(Trying to use the resource to filter possible executable commands)
Code Action Resource access [message #1869756] Fri, 23 August 2024 10:48 Go to next message
I have an implementation which exploits the xtext ICodeActionService2 implementation. From the Options (org.eclipse.xtext.ide.server.codeActions.ICodeActionService2.Options) I should be able to access both document and resource and allow querying the model to determine if an executeable command should be applicable:
val offset = document.getOffSet(position)
val element = resource.resolveContainedElementAt(offset)
pre 2.20 the codeActions Options were populate with the resource - e.g.:
https://github.com/eclipse/xtext/blob/fedf312fcc8f88605fdf182e3ae2041de793ce4a/org.eclipse.xtext.ide/src/org/eclipse/xtext/ide/server/LanguageServerImpl.java#L785
but now this is the not the case:
https://github.com/eclipse/xtext/blob/main/org.eclipse.xtext.ide/src/org/eclipse/xtext/ide/server/LanguageServerImpl.java#L818-L823
so the resource is always null.
I was wondering if there was a way to access the resource from somewhere else in the IDE module - I have available a ProjectManager via the ServerModule, but not entirely sure how to initialise this properly
many thanks for any help
Re: Code Action Resource access [message #1869762 is a reply to message #1869756] Fri, 23 August 2024 13:53 Go to previous messageGo to next message
Maybe you can do some archeology on
https://github.com/eclipse/xtext/commit/955533e89e829c3ca0e182a4e47eec3db5727bcc#diff-de69d0b3cc6ee48a1c1dd195a62c2109a69addda2bc3d5729fd58889bf6344e3
https://github.com/eclipse/xtext-core/pull/1915
And why the set resource is not called.
[Updated on: Fri, 23 August 2024 13:58] by Moderator
Re: Code Action Resource access [message #1869765 is a reply to message #1869762] Fri, 23 August 2024 14:19 Go to previous messageGo to next message
thank you! Will study this
Re: Code Action Resource access [message #1870407 is a reply to message #1869765] Mon, 26 August 2024 07:05 Go to previous messageGo to next message
Thanks a lot for the links here - the correct way now to do this (for reference in case someone else find this) is to use e.g.
options.languageServerAccess.doSyncRead(options.URI, [ Context context |
val resource = context.resource
val document = context.document
Re: Code Action Resource access [message #1870410 is a reply to message #1870407] Mon, 26 August 2024 07:51 Go to previous message
yes this is what i assume.
Previous Topic:Xtext 2.36.0 is out
Next Topic:[LSP]: How to support project configuration files
Current Time: Fri Nov 07 14:38:16 EST 2025
Powered by FUDForum. Page generated in 0.03457 seconds
