Home » Newcomers » Newcomers » Where's the marketplace?(Help -> Marketplace... is gone after updating eclipse - what's wrong?)
Where's the marketplace? [message #1868079] Wed, 10 July 2024 15:48 Go to next message
I am not exactly a newcomer (using Eclipse since 2001...) but I found no better forum to ask this question - so here it goes:
I updated my (pretty well-working) Eclipse installation from Eclipse 2024-03 to 2024-06 today and now I just found that the Eclipse marketplace entry (in Menu Help) is gone!?! I don't assume that this is intentional or "to be expected", is it?
If yes: what's the alternative? Where else and how do we we fetch new features and extensions then?
If no: what could be the reson that this doesn't feature show up anymore? WHat can I check or fix to make it re-surface?
I want to install a new feature and for that I need access to the marketplace.
[Updated on: Wed, 10 July 2024 15:49] by Moderator
Re: Where's the marketplace? [message #1868097 is a reply to message #1868079] Thu, 11 July 2024 07:38 Go to previous messageGo to next message
Is there something in the Error Log view that might indicate why the marketplace bundles aren't starting?
The latest released version is here:
https://download.eclipse.org/mpc/releases/1.10.3/
So you might try to uninstall it and then install from the latest.
Another hacky approach is to go to any listing:
https://marketplace.eclipse.org/content/testdoxon
Click on the heath icon
https://www.eclipse.org/setups/marketplace/?id=4142493
There it shows the update site from which you can try to install.
Re: Where's the marketplace? [message #1868103 is a reply to message #1868097] Thu, 11 July 2024 09:12 Go to previous message
> Is there something in the Error Log view ...
No - there was nothing that provided any indication why the marketplace didn't appear. There were a couple of groovy-code related issues (I had some groovy support installed that I later uninstalled again which obviously didn't fully work).
I then decided to install another copy of eclipse (in which the marketplace happily appeared) and then used that to simply install me all the plugins that I needed.
When - just for testing - I directed my old eclipse installation to that newly created workspace it also showed the marketplace again.
Thus - I conclude - the issue seems to have been due to some (corrupted?) data or settings saved in the workspace. But I am afraid that data has been cleared or overwritten by now.
[Updated on: Thu, 11 July 2024 09:14] by Moderator
Previous Topic:Link Text editor and Project Explorer doesn't work in some cases
Next Topic:Gradle comply about unsupported Java Version
Current Time: Thu Jun 12 12:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.13361 seconds
