Home » Language IDEs » Java Development Tools (JDT) » m2eclipse (Maven Integration): how to see actual Maven output or customize builds?
m2eclipse (Maven Integration): how to see actual Maven output or customize builds? [message #1867476] Wed, 26 June 2024 15:30 Go to next message
I'm used to simply select Project -> Clean or Build Project and then look to the Errors view to find all the issues. But I never saw actual maven build output of m2eclipse, like how it downloads dependencies, compiles modules, etc. How can I do that? And side question: how can I customize the build, like by adding a custom variable?
I have found the answer on the m2eclipse FAQ page, but it's confusing because images don't show up in that article.
Thank you in advance.
UPDATE: I posted the same question in Stack Overflow.
[Updated on: Thu, 25 July 2024 04:17] by Moderator
Report message to a moderator
Re: m2eclipse (Maven Integration): how to see actual Maven output or customize builds? [message #1872713 is a reply to message #1867476] Fri, 15 November 2024 16:17 Go to previous message
Go to the Console View and using its Open Console toolbar dropdown, open the Maven Console.
Previous Topic:Switch/default->null caused a building problem.
Next Topic:How to add/update an environment variable without Eclipse restart?
Current Time: Sat Feb 15 06:48:35 GMT 2025
Powered by FUDForum. Page generated in 0.03669 seconds
