Home » Newcomers » Newcomers » information about UML and eclipse IDE. Quick Tip. Single eclipse IDE(Information about IDE and Modeling tools UML. Single eclipse IDE.)
information about UML and eclipse IDE. Quick Tip. Single eclipse IDE [message #1866729] Wed, 05 June 2024 20:07 Go to next message
I am new on eclipse IDE. I am going to install a eclipse IDE only for UML project reasons.
I am going to install for the pourpose to project using UML, for code generation. And UML project.
Can someone give me a installation tip? I will not be programming. Will be using the IDE only for design.
What software should I download?
Any information is fine.
Re: information about UML and eclipse IDE. Quick Tip. Single eclipse IDE [message #1866744 is a reply to message #1866729] Thu, 06 June 2024 04:27 Go to previous messageGo to next message
You could ask here instead:
https://www.eclipse.org/forums/index.php?t=thread&frm_id=117
You can install any of the IDE from here:
Probably the Eclipse Modeling Tools is the best fit.
Then you can install UML2 stuff using Help -> Install New Software:
index.php/fa/44673/0/
Re: information about UML and eclipse IDE. Quick Tip. Single eclipse IDE [message #1866870 is a reply to message #1866744] Sun, 09 June 2024 22:00 Go to previous message
Do you known about a project based on eclipse called papyrus?
What do you think about the project?
Previous Topic:I need help with making a new project.
Next Topic:How do I completely remove Eclipse IDE from my Linux computer?
Current Time: Sat Nov 08 05:57:50 EST 2025
Powered by FUDForum. Page generated in 0.10141 seconds
