Home » Eclipse Projects » Buckminster dev » Version override with type Triplet vs. Omni Version
Version override with type Triplet vs. Omni Version [message #34633] Tue, 16 June 2009 09:51 Go to next message
Ken Wenzel is currently offline Ken WenzelFriend
Member
Hallo,
I suppose that I encountered a bug regarding Buckminster's capabilities for
version overrides using advisor nodes. I'm using the latest version of Buckminster
for Eclipse 3.5.0.
If type "Triplet" is selected then Buckminster automatically converts a given version number
to an Omni Version expression. For example the version number 2.3.0 gets converted to "raw:2.3.0.M/format(n[.n=0;[.n=0;]][d?S=M;]):2.3.0" - this is
controversial to the selected version type "Triplet" (by the way the type Omni Version is missing and therefore cannot be selected).
If I try to save the CQuery then the following exception is raised:
Save Failed
Format "format(n[.n=0;[.n=0;]][d?S=M;])" was unable to parse raw:2.3.0.M/format(n[.n=0;[.n=0;]][d?S=M;]):2.3.0
It seems that Buckminster tries to parse the version number as a triplet and not as an Omni Version expression.
Either Buckminster should not automatically transform a triplet version number to an Omni Version expression or the attribute type should be omitted
for version overrides and all versions should be handled as Omni Version expressions.
The current implementation of version overrides with type "Triplet" is unfortunately unusable.
Ken Wenzel
Re: Version override with type Triplet vs. Omni Version [message #34668 is a reply to message #34633] Tue, 16 June 2009 10:09 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
> is controversial to the selected version type "Triplet"
No, this is not controversial. The version types are just shortcuts for omni type version formats.
All versions are omni versions so this type is always implicit.
> Save Failed
That is certainly a bug. Can you please enter a bugzilla for this?
Thomas Hallgren
Re: Version override with type Triplet vs. Omni Version [message #34703 is a reply to message #34633] Tue, 16 June 2009 10:14 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
Can you file a bugzilla issue for this?
Sounds like it translates the input to OmniVersion, and then the
translated version once again :)
- henrik
Ken Wenzel wrote:
> Hallo,
> Buckminster
> for Eclipse 3.5.0.
> is controversial to the selected version type "Triplet" (by the way the
> Save Failed
> omitted for version overrides and all versions should be handled as Omni
> Best regards,
> Ken Wenzel
Re: Version override with type Triplet vs. Omni Version [message #34735 is a reply to message #34668] Tue, 16 June 2009 10:36 Go to previous message
Member
I've created a bug report for this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=280430
Previous Topic:[buckminster-dev] +1 for Ed Merks on tools.buckminster
Next Topic:[buckminster-dev] Vote for Committer status for Achim Demelt has started
Current Time: Thu Nov 26 05:11:54 GMT 2020
Powered by FUDForum. Page generated in 0.01907 seconds
