Home » Modeling » MoDisco » Plans for java>7
Plans for java>7 [message #1864673] Tue, 02 April 2024 16:38 Go to next message
As modisco is a dependency of many other projects and as modisco is stuck on java 7, is there any plan to upgrade to a newer java version?
Kind regards
Re: Plans for java>7 [message #1864674 is a reply to message #1864673] Tue, 02 April 2024 16:41 Go to previous messageGo to next message
At least the java metamodel and the parser would be enough for many cases.
Re: Plans for java>7 [message #1868994 is a reply to message #1864674] Mon, 29 July 2024 01:54 Go to previous message
As noted in https://www.eclipse.org/forums/index.php/t/1115877/ MoDisco 1.5.5M2 removes Java 5/6/7 references that break on Eclipse 4.33 (2024-09).
No support is provided for post Java 8 constructs. If you care to contribute, org.eclipse.modisco.java.discoverer.tests is where tests of new functionality could exist.
Previous Topic:Java 8 compatibility for Eclipse 4.33 (2024-09) in MoDisco 1.5.5
Next Topic: Please use MoDisco Discussions
Current Time: Fri Jun 20 13:46:54 EDT 2025
Powered by FUDForum. Page generated in 0.27903 seconds
