Home » Modeling » Papyrus » Problem with Papyrus Moka installation
Problem with Papyrus Moka installation [message #1863831] Wed, 28 February 2024 11:52 Go to next message
Since two days, I'm trying to install Moka on Papyrus. When I using the Eclipse MarketPlace to download and proceed the installation, I have an error message like this :
Cannot complete the install because one or more required items could not be found.
  Software being installed: Moka Core 4.1.0.202301271307 (org.eclipse.papyrus.moka.feature.feature.group 4.1.0.202301271307)
  Missing requirement: Moka Core 4.1.0.202301271307 (org.eclipse.papyrus.moka.feature.feature.group 4.1.0.202301271307) requires 'org.eclipse.equinox.p2.iu; org.eclipse.json [1.1.0,1.2.0)' but it could not be found
I was also trying to install Moka following this tutorial (https://wiki.eclipse.org/Papyrus/UserGuide/ModelExecution) and when I try to add Nebula I have this message :
  Software being installed: Nebula CDateTime Widget 1.0.0.201605312033 (org.eclipse.nebula.widgets.cdatetime.feature.feature.group 1.0.0.201605312033)
  Missing requirement: org.eclipse.nebula.cwt 1.0.0.201605312033 requires 'java.package; org.eclipse.swt.internal.theme 0.0.0' but it could not be found
  Cannot satisfy dependency:
    From: Nebula Custom Widget Toolkit 1.0.0.201605312033 (org.eclipse.nebula.cwt.feature.feature.group 1.0.0.201605312033)
    To: org.eclipse.equinox.p2.iu; org.eclipse.nebula.cwt [1.0.0.201605312033,1.0.0.201605312033]
    From: Nebula CDateTime Widget 1.0.0.201605312033 (org.eclipse.nebula.widgets.cdatetime.feature.feature.group 1.0.0.201605312033)
    To: org.eclipse.equinox.p2.iu; org.eclipse.nebula.cwt.feature.feature.group 0.0.0
I'm a beguiner at Eclipse and Papyrus interface, all of my tries have failled or files are incomplete and I can't use it. I'm actually on Window 11 PC, with the latest version of Eclipse (2023-12) and Papyrus. I tried on both software, nothing is working and I had obtained the same results during installation.
I hoped that somemone could help me.
Wish you a good day.
Pardon my english, I'm not too good on that language.
Re: Problem with Papyrus Moka installation [message #1863842 is a reply to message #1863831] Thu, 29 February 2024 09:36 Go to previous messageGo to next message
Unfortunately, we didn't do a new release for 2023-12 and we should. The only solution I have to install moka now, is tu use the nightly build : https://ci.eclipse.org/papyrus/job/papyrus-moka-master/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.moka.p2/target/repository/
Sorry for the inconvenient,
Pauline
Re: Problem with Papyrus Moka installation [message #1863865 is a reply to message #1863842] Fri, 01 March 2024 12:05 Go to previous message
Thank you for your reply.
Best regards.
Kristen
Previous Topic:Questions about c++ code generation and "using namespaces".
Next Topic:Is there any demo of sysmlv2 in the SysOn project
Current Time: Fri Jul 18 20:07:05 EDT 2025
Powered by FUDForum. Page generated in 0.04192 seconds
