Home » Newcomers » Newcomers » Raise IDE toolbar icon size
Raise IDE toolbar icon size [message #1863644] Sat, 17 February 2024 16:50 Go to next message
Hi all,
I find toolbar icon size of the IDE too small .
Is there a way to zoom these icons permanently ?
Thanks !
Re: Raise IDE toolbar icon size [message #1864024 is a reply to message #1863644] Tue, 12 March 2024 00:38 Go to previous messageGo to next message
ray gllisse wrote on Sat, 17 February 2024 21:50
Hi all,
Thanks !
To permanently increase the IDE toolbar icon size, you can edit the IDE's configuration file (eclipse.ini) and add the following lines: -Dswt.enable.autoScale=true -Dswt.autoScale=150 -Dswt.autoScale.method=nearest. Adjust the 150 value to scale the icons to your preference.
I hope the solution worked for you.
Re: Raise IDE toolbar icon size [message #1864043 is a reply to message #1864024] Tue, 12 March 2024 23:57 Go to previous messageGo to next message
Yvonne Rhodes wrote on Tue, 12 March 2024 04:38
Hi all,
I find toolbar icon size of the IDE too small . Milestone Card
Thanks !
Is this solution worked for you or not? If any question let me know, will help you.
Re: Raise IDE toolbar icon size [message #1866594 is a reply to message #1864043] Mon, 03 June 2024 06:10 Go to previous messageGo to next message
I have the same problem.
I tried the solution offered here, but it doesn't seem to change the icon sizes.
Instead of changing the icon sizes, it messes up the maximise an minimise icons and the gutters (where breakpoints etc are shown). If the scaling factor is set to 100, there is no effect at all and the mess doesn't happen.
index.php/fa/44634/0/
index.php/fa/44637/0/
I looked at the github for eclipse.platform.swt and discovered method can be set ti auto, smooth or nearest - so I tried each one in turn
I'm running eclipse on Macos Ventura 13.6.7.
Any ideas ?
Re: Raise IDE toolbar icon size [message #1866600 is a reply to message #1866594] Mon, 03 June 2024 15:12 Go to previous message
Curious, is that a conflict specific to the built-in Dark theme?
Previous Topic:Reports on child data sets
Next Topic:I need help with making a new project.
Current Time: Tue Mar 18 14:19:15 EDT 2025
Powered by FUDForum. Page generated in 0.05921 seconds
