Home » Modeling » TMF (Xtext) » Debugging Xtend2 generated Java
Debugging Xtend2 generated Java [message #1863014] Wed, 10 January 2024 22:02 Go to next message
Ernesto Posse is currently offline Ernesto PosseFriend
Hi. I was wondering about how to debug the Java code generated from Xtend2. Currently, whenever I'm debugging Xtend2 code, the debugger steps through the source .xtend files and the Variables view shows (some but not all) Xtend variables. But in order to properly debug the code I need to step through the generated Java. If I put a breakpoint in the generated Java, execution stops there, but the source brought up by the debugger is still the .xtend, and the variables are seem to be a subset of all the Java variables normally available but not all. For example, I often see "it" and "it_1" which are usually lambda arguments in the generated Java, but I don't see the parameters of the method being debugged. So, is there any way to configure Xtend or the debugger so that it only goes through the Java sources?
Re: Debugging Xtend2 generated Java [message #1863020 is a reply to message #1863014] Thu, 11 January 2024 05:45 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
in the debug view you can click on the stack and show source -> java
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: Debugging Xtend2 generated Java [message #1863032 is a reply to message #1863020] Thu, 11 January 2024 19:51 Go to previous message
Oh great! I missed that!
Thanks!
Previous Topic:Xtext 2.34.0.M1 is out
Next Topic:Dot '.' is not allowed inside double quote in Xtext
Current Time: Sun Jan 19 01:21:57 GMT 2025
Powered by FUDForum. Page generated in 0.04221 seconds
