Home » Eclipse Projects » RCP Testing Tool » Run with exported run configuration(How to specify exported run configuration (AUT) in test runner)
Run with exported run configuration [message #1862545] Mon, 11 December 2023 10:58 Go to next message
I have exported run configuration in RCPTT (view screenshot).
I would like to run test runner and select exported run configuration.
Re: Run with exported run configuration [message #1862613 is a reply to message #1862545] Thu, 14 December 2023 12:54 Go to previous message
Is there a way to pass AUTs launch configuration to test runner?
Specifically in interface IPDELauncherConstants is launch configuration attribute key GENERATE_PROFILE which is default initialized to false, I need to set this attribute to true.
Previous Topic:compatibility between Eclipe 03-2023 and RCPTT 2.5.4
Next Topic:Can not start RCPTT tests with a bundle based on 2020-06
Current Time: Sat Feb 08 10:24:11 GMT 2025
Powered by FUDForum. Page generated in 0.04590 seconds
