Home » Modeling » EMF » Changed behavior of Undo/Redo menu's entries?
Changed behavior of Undo/Redo menu's entries? [message #1862176] Thu, 16 November 2023 11:37 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
While porting EMF Parsley from 2022-12 to 2023-09 many of my SWTBot tests fail: those that try to click on Undo/Redo Edit's menus.
In 2022-12, EMF entries for Undo/Redo used to have a description, e.g., "Undo New EClass", both in the "Edit" menu and in the editor's context menu.
In 2023-09, the one of the "Edit" menu contains no description, just "Undo", while the one in the context menu still has "Undo New EClass".
Is that a change in EMF or a general change in the IDE?
Just curiosity: I can update my SWTBot tests accordingly ;)
Re: Changed behavior of Undo/Redo menu's entries? [message #1862178 is a reply to message #1862176] Thu, 16 November 2023 12:29 Go to previous messageGo to next message
I never noticed that and never changed anything that seems related to that. It's more likely to be a change in the Platform than a change in EMF. The org.eclipse.emf.edit.ui.action.UndoAction.update() and org.eclipse.emf.edit.ui.action.RedoAction.update() methods are called and do update the text of the action. One sees that text in the context menu. But not in the Edit menu. Hmmm.
Ed Merks
Re: Changed behavior of Undo/Redo menu's entries? [message #1862179 is a reply to message #1862178] Thu, 16 November 2023 12:31 Go to previous messageGo to next message
I still haven't checked with 2023-12, but I guess that's what you're using and you see that behavior as well, don't you?
Re: Changed behavior of Undo/Redo menu's entries? [message #1862181 is a reply to message #1862179] Thu, 16 November 2023 14:20 Go to previous messageGo to next message
I saw it in 2023-12 and 2023-09. It looks okay still in 2023-06.
Ed Merks
Re: Changed behavior of Undo/Redo menu's entries? [message #1862182 is a reply to message #1862181] Thu, 16 November 2023 14:24 Go to previous messageGo to next message
OK. As I said, it's not a problem (I've updated my SWTBot tests, and it was easy (https://github.com/eclipse-emf-parsley/emf-parsley/commit/296b044031bdc7b5ead5de192d1e855f239cd722).
However, this new behavior is strange ;)
Re: Changed behavior of Undo/Redo menu's entries? [message #1862187 is a reply to message #1862182] Thu, 16 November 2023 15:52 Go to previous messageGo to next message
It's not an improvement. :-(
Ed Merks
Re: Changed behavior of Undo/Redo menu's entries? [message #1862239 is a reply to message #1862187] Mon, 20 November 2023 07:47 Go to previous messageGo to next message
Pierre-Charles David is currently offline Pierre-Charles DavidFriend
I noticed the same thing with Sirius's SWTbot test, and reported https://github.com/eclipse-platform/eclipse.platform.ui/issues/1314
The regression is due to a change in the platform itself in 2023-09.
Pierre-Charles David - Obeo
Re: Changed behavior of Undo/Redo menu's entries? [message #1862240 is a reply to message #1862239] Mon, 20 November 2023 08:02 Go to previous message
Thanks for the update. It is indeed a regression then.
Previous Topic:Incomplete EPackage from ecore file
Next Topic:Genmodel code generation via Maven build
Current Time: Sun Sep 15 19:50:39 GMT 2024
Powered by FUDForum. Page generated in 0.03494 seconds
