Home » Eclipse Projects » Eclipse Scout » Refresh a listbox with a LookupCall backend(Refreshing listbox contents when the linked data source is updated)
Refresh a listbox with a LookupCall backend [message #1862118] Mon, 13 November 2023 16:05 Go to next message
Hi there everyone,
I have several smartfields and listboxes on a form all of which are populated by several lookupcalls.
The smartfield contents update in real time when rows are added, updated or deleted in the data source BUT the listboxes do not update at all. At the moment, the only way I can refresh a listbox contents is to close the form and then reopen it.
This is an example of one of my listboxes:
      @Order(1000)
      public class DemandsListBox extends AbstractListBox<Integer> {
        protected String getConfiguredLabel() {
          return TEXTS.get("Demands");
        protected int getConfiguredGridH() {
          return 6;
        protected Class<? extends ILookupCall<Integer>> getConfiguredLookupCall() {
          return DemandLookupCall.class;
Is there any way to make a listbox refresh itself?
Thanks for your kind assistance.
JD
Re: Refresh a listbox with a LookupCall backend [message #1862120 is a reply to message #1862118] Mon, 13 November 2023 23:57 Go to previous messageGo to next message
There is no such thing as an automatic reload for listboxes (actually also not for smart fields however they work differently, they are only loaded after they've been opened and each data request will trigger another load e.g. typing in the field).
However you could manually reload the listbox by calling org.eclipse.scout.rt.client.ui.form.fields.listbox.AbstractListBox#loadListBoxData. You would however still need an event or a trigger when to call this method, out-of-the box there is no such thing like a notification when a list has changed (and this would also only be useful if the list does not change too often) maybe you could add a reload button? Or if you do know about the changes (e.g. add/remove elements on the form itself) trigger the load method immediately again afterwards?
[Updated on: Mon, 13 November 2023 23:58] by Moderator
Re: Refresh a listbox with a LookupCall backend [message #1862296 is a reply to message #1862120] Wed, 22 November 2023 17:26 Go to previous message
The reload button seems like the best option. Thanks a lot Matthias.
JD
Previous Topic:Error by maven build
Next Topic:Table with dynamic number of columns
Current Time: Fri Jul 18 04:36:39 EDT 2025
Powered by FUDForum. Page generated in 0.28850 seconds
