Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4DIAC Testing Problem(Problems when combine FBs using ANY Input/Output)
4DIAC Testing Problem [message #1861861] Wed, 08 November 2023 07:08 Go to next message
Hi, I am trying to create an application using FBs such as F_ADD, F_MUL, and F_MULTIME. I discovered that when an output of these FBs is ANY, it can't somehow transfer that signal to other FBs using ANY input. What should I do now? Is there any configuration might affect this result?
Re: 4DIAC Testing Problem [message #1861862 is a reply to message #1861861] Wed, 08 November 2023 07:13 Go to previous messageGo to next message
Hi.
which versions/branches of FORTE and 4diac IDE are you using?
Re: 4DIAC Testing Problem [message #1861872 is a reply to message #1861862] Thu, 09 November 2023 08:01 Go to previous messageGo to next message
It's 2.0.1 version of FORTE and 4DIAC.
[Updated on: Thu, 09 November 2023 08:04] by Moderator
Re: 4DIAC Testing Problem [message #1862220 is a reply to message #1861872] Sat, 18 November 2023 06:49 Go to previous messageGo to next message
Hi, it has been a quite long time. Any answer?
Re: 4DIAC Testing Problem [message #1862245 is a reply to message #1862220] Mon, 20 November 2023 08:37 Go to previous message
In 2.0.1 ANYs need to be "force-typified" with the concrete expected type.
So if you have TIME as a result you need a TIME2TIME FB between the ANY output providing the TIME value und the ANY input consuming it
Previous Topic:Build a freeRtos_Lwip to RT1060
Next Topic:4diac FB testing
Current Time: Fri Jul 11 05:50:17 EDT 2025
Powered by FUDForum. Page generated in 0.04780 seconds
