Home » Eclipse Projects » Equinox » Suppress default behaviour of IApplication exit codes 23 and 24?(Suppress default behaviour of IApplication exit codes 23 and 24?)
Suppress default behaviour of IApplication exit codes 23 and 24? [message #1861328] Thu, 05 October 2023 20:10 Go to next message
Patrick van Berkel is currently offline Patrick van BerkelFriend
The launcher documentation indicates two predefined exit codes (23-EXIT_RESTART and, 24-EXIT_RELAUNCH) the IApplication implementation can return to trigger an automatic restart of the application by the launcher. My question is if there is a way to suppress this specific handling of these exit codes and allow these exit code to be used by the application for its own purposes. A command line argument for instance?
If not, could such an argument be introduced in the next Eclipse version?
Kind regards.
Re: Suppress default behaviour of IApplication exit codes 23 and 24? [message #1861331 is a reply to message #1861328] Fri, 06 October 2023 05:28 Go to previous messageGo to next message
It's probably better to ask here:
https://github.com/eclipse-equinox/equinox/discussions
Ed Merks
Re: Suppress default behaviour of IApplication exit codes 23 and 24? [message #1861359 is a reply to message #1861331] Sun, 08 October 2023 17:31 Go to previous message
Dear Mr. Merks,
Thank you for your advice. I will direct my question to the Eclipse Equinox community on github.
Kind regards.
[Updated on: Sun, 08 October 2023 17:36]
Report message to a moderator
Previous Topic:Source code for dll in launcher
Next Topic:Is there an easy way to install plugins?
Current Time: Tue Nov 05 19:32:25 GMT 2024
Powered by FUDForum. Page generated in 0.02808 seconds
