Home » Language IDEs » Java Development Tools (JDT) » Eclipse and JavaSDK Setup(Failure to clear errors during install)
Eclipse and JavaSDK Setup [message #1861145] Sat, 23 September 2023 14:33 Go to next message
I am a student taking a university programming 1 - Java. The course requests that we use the latest versions of Eclipse and Java. I have the following:
Eclipse IDE for Java Developers (includes Incubating components)
Version: 2023-09 (4.29.0)
Build id: 20230907-1323
OS: Mac OS X, v.13.5.2, aarch64 / cocoa
Java vendor: Oracle Corporation
Java runtime version: 20.0.2+9-78
Java version: 20.0.2
I followed this video tutorial to help install:
Bro Code. (2020, November 17). JavaFX install & setup (Eclipse) [Video]. YouTube.
If you get to setup step 6. The video states that the errors will clear and if there are no mistakes with installation.
I have followed the steps but still get the same results the errors do not clear.
I have been using Eclipse to complete my assignments but, feel that I am missing the use of the part that cannot be cleard with the video installation setup.
Is there anyone who can assist me with this issue?
Re: Eclipse and JavaSDK Setup [message #1861146 is a reply to message #1861145] Sat, 23 September 2023 16:50 Go to previous messageGo to next message
Have you read through the comments of the video? There are some addressing changes imposed by using Java versions 17 and higher.
[Updated on: Sat, 23 September 2023 16:50] by Moderator
Report message to a moderator
Re: Eclipse and JavaSDK Setup [message #1861148 is a reply to message #1861146] Sun, 24 September 2023 12:40 Go to previous messageGo to next message
I hope I am doing the reply properly.
I have seen the changes in the path required and have implemented the required one for macOS.
I did read some of the comments and saw one regarding locating the path from Class to Module and I have also done this.
The errors have cleared and I have proceeded to the next steps on running the program. What happens is that I get an the following:
ERROR: org.eclipse.equinox.p2.director code=10054 Cannot complete the install because of a conflicting dependency.
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:296)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.resolve(ProfileTransactionImpl.java:446)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:356)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:904)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3864)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:5200)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2453)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2478)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:5193)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3798)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3773)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3651)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:592)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:721)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1695558685407
ERROR: org.eclipse.equinox.p2.director code=1 Only one of the following can be installed at once:
ERROR: org.eclipse.equinox.p2.director code=0 Mylyn Java Bridge 3.26.1.v20230604-1755 (org.eclipse.mylyn.java.ui 3.26.1.v20230604-1755)
ERROR: org.eclipse.equinox.p2.director code=0 Mylyn Java Bridge 4.0.0.v20230804-1109 (org.eclipse.mylyn.java.ui 4.0.0.v20230804-1109)
ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1695558685407
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.mylyn.java_feature.feature.group 0.0.0
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.mylyn.jdt.feature.feature.group 4.0.0.v20230804-1109
ERROR: org.eclipse.equinox.p2.director code=0 From: Mylyn Context Connector: Java Development 3.26.1.v20230604-1755 (org.eclipse.mylyn.java_feature.feature.group 3.26.1.v20230604-1755)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.mylyn.java.ui [3.26.1.v20230604-1755,3.26.1.v20230604-1755]
ERROR: org.eclipse.equinox.p2.director code=0 From: Mylyn Context Connector: Java Development 4.0.0.v20230804-1109 (org.eclipse.mylyn.jdt.feature.feature.group 4.0.0.v20230804-1109)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.mylyn.java.ui [4.0.0.v20230804-1109,4.0.0.v20230804-1109]
A file folder pops into my dock everytime I run the program.
Re: Eclipse and JavaSDK Setup [message #1861149 is a reply to message #1861148] Sun, 24 September 2023 14:35 Go to previous messageGo to next message
It looks like you're trying to install/update into an installation with older version of Mylyn already installed. I'm not sure how you got into that state of what you did to get the above stack trace.
Re: Eclipse and JavaSDK Setup [message #1861168 is a reply to message #1861149] Mon, 25 September 2023 19:35 Go to previous messageGo to next message
Would it be best to remove Eclipse and Java from my MacMini and redo the complete installation?
Re: Eclipse and JavaSDK Setup [message #1861175 is a reply to message #1861168] Tue, 26 September 2023 07:40 Go to previous messageGo to next message
I'm pretty sure at some point a dialog came up and told it yes, you want to try to get the installation to match its description and to remember that....
If you go into Preferences -> Oomph -> Setup Tasks you can check-mark "Skip automatic task execution or startup", or can change "Install requirements on startup" to "Never", where you probably have "Always" or at least "Prompt" chosen right now...
Re: Eclipse and JavaSDK Setup [message #1861218 is a reply to message #1861175] Fri, 29 September 2023 22:28 Go to previous messageGo to next message
Thanks I will set for Prompt and try that.
Re: Eclipse and JavaSDK Setup [message #1861235 is a reply to message #1861218] Sun, 01 October 2023 16:00 Go to previous messageGo to next message
It seems that I have more issues with my Eclipse than I realize. I have an update come up and then when I do the update I get the following with lots of errors.
Executing startup tasks
Java(TM) SE Runtime Environment 20.0.2+9-78
Product org.eclipse.products.epp.package.java.2023-06
Workspace /Users/lacope/eclipse-workspace
Bundle org.eclipse.oomph.setup 1.27.0.v20230714-1137, build=172, branch=619f8be9a7f929a284db8759f923f2293a5612e2
Bundle org.eclipse.oomph.setup.core 1.28.0.v20230618-0610, build=172, branch=619f8be9a7f929a284db8759f923f2293a5612e2
Bundle org.eclipse.oomph.setup.p2 1.20.0.v20230617-1322, build=172, branch=619f8be9a7f929a284db8759f923f2293a5612e2
Performing P2 Director (Eclipse IDE for Java Developers (2023-06))
Offline = false
Mirrors = true
Resolving 26 requirements from 3 repositories to /Applications/Eclipse.app/Contents/Eclipse
Requirement org.eclipse.equinox.p2.iu:epp.package.java [4.28.0,5.0.0) (filter=(|(&(osgi.arch=aarch64)(osgi.os=linux)(osgi.ws=gtk))(&(osgi.arch=aarch64)(osgi.os=macosx)(osgi.ws=cocoa))(&(osgi.arch=x86_64)(osgi.os=linux)(osgi.ws=gtk))(&(osgi.arch=x86_64)(osgi.os=macosx)(osgi.ws=cocoa))(&(osgi.arch=x86_64)(osgi.os=win32)(osgi.ws=win32))))
Requirement org.eclipse.equinox.p2.iu:org.eclipse.platform.feature.group [4.28.0,5.0.0)
Requirement org.eclipse.equinox.p2.iu:org.eclipse.rcp.feature.group [4.28.0,5.0.0)
Requirement org.eclipse.equinox.p2.iu:org.eclipse.buildship.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.eclemma.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.egit.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.epp.mpc.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.jdt.bcoview.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.jdt.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.jgit.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.lemminx.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.logback.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.commons.activity.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.egit.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.git.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.github.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.hudson.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.ide_feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.java_feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.reviews.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.wikitext_feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.tips.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.tm.terminal.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.wildwebdeveloper.xml.feature.feature.group
Requirement org.eclipse.equinox.p2.iu:org.eclipse.oomph.setup.feature.group
Repository https://download.eclipse.org/technology/epp/packages/2023-06/202306081200
Repository https://download.eclipse.org/releases/2023-06/202306141000
Repository https://download.eclipse.org/oomph/updates/milestone/latest
Adding metadata repository https://download.eclipse.org/oomph/updates/milestone/latest
Adding metadata repository https://download.eclipse.org/releases/2023-06/202306141000
Adding metadata repository https://download.eclipse.org/technology/epp/packages/2023-06/202306081200
Calculating requirements and dependencies.
Cannot complete the request. Generating details.
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: artificial_root 1.0.0.v1696175529190
ERROR: org.eclipse.equinox.p2.director code=0 From: artificial_root 1.0.0.v1696175529190
Took 1 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
Re: Eclipse and JavaSDK Setup [message #1861239 is a reply to message #1861235] Sun, 01 October 2023 22:43 Go to previous messageGo to next message
To those who assisted with my Eclipse and JavaSDK Setup....thank you for your assistance.
I have given up trying to work with the Eclipse I had downloaded and removed it completely from my computer.
I reinstalled the basic Eclipse IDE Java which is working great at the moment.
I would like to know that when I re-installed Eclipse I downloaded the the following:
Version: 2023-06 (4.28.0)
Build id: 20230608-1333
OS: Mac OS X, v.14.0, aarch64 / cocoa
Do I need to install JavaSDK as I do not see it in my Preferences?
Re: Eclipse and JavaSDK Setup [message #1861244 is a reply to message #1861239] Mon, 02 October 2023 08:03 Go to previous messageGo to next message
Unfortunately Mylyn renamed almost all it's features causing conflict problems in the product definitions I'm not sure why you installed 2023-06 and not 2023-09....
I'm not sure what you mean by JavaSDK; you mean a JDK. It appears you have a 20.0.2 JDK installed, being used. For what specifically and where are you looking in the preferences?
Re: Eclipse and JavaSDK Setup [message #1861247 is a reply to message #1861244] Mon, 02 October 2023 08:20 Go to previous messageGo to next message
It depends on your needs.
Since you are a student, IMHO, what you have is enough.
Eclipse does support multiple JDK implementations.
See https://www.baeldung.com/eclipse-change-java-version
Re: Eclipse and JavaSDK Setup [message #1861309 is a reply to message #1861247] Thu, 05 October 2023 01:49 Go to previous messageGo to next message
Hello Ed Merks,
I installed 2023-06 in error and I seem to be having no issues with this installation. I know following the instruction for this course is to upload the latest versions and when I attempted this, I had issues from the start. I will stick with what I have for now and upgrade to 2023-09 after the course is over.
Thank you for your help.
Hello Eitan Rosenberg,
I think that you were right as the instructions for the course was a YouTube vid which was posted in 2017. I will be (see above reply to Ed Merks). I have booked marked your webpage suggestion and will delve into it. Thank you for your help.
To both Ed and Eitan....Again thank you both for your assistance.
Re: Eclipse and JavaSDK Setup [message #1861706 is a reply to message #1861148] Mon, 30 October 2023 09:56 Go to previous messageGo to next message
Peter Lacoste wrote on Sun, 24 September 2023 12:40
at Yoji Casino, the thrill of gaming knows no bounds. Dive into a world of slot games and classic casino gems, each offering endless excitement.
What truly sets us apart is our dedication to rewarding players.
Explore a https://yojicasino.ro/ro/casino-info/slots/magic-81-lines-- realm of bonuses and exclusive promos that amplify your chances of winning big.
With fan-favorite games like Mega Moolah and Gonzo's Quest, the possibilities are boundless.
I have exactly the same mistake and I see it constantly
[Updated on: Mon, 30 October 2023 17:01] by Moderator
Re: Eclipse and JavaSDK Setup [message #1861714 is a reply to message #1861706] Mon, 30 October 2023 13:27 Go to previous message
This feels like a ground hog day issue. There's no point in me repeating previous answers.
Try the following. Use Help -> About Eclipse IDE -> Installation Details and on the Installed Software tab, select all the Mylyn* features and choose Uninstall... After that you will be able to install newer Mylyn features without conflict.
Previous Topic:NetBeans Or Eclipse
Next Topic:Eclipse Gradle JUnit Test Issue?
Current Time: Thu Feb 13 16:51:05 GMT 2025
Powered by FUDForum. Page generated in 0.04112 seconds
