Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » How to use client fbd for http
How to use client fbd for http [message #1860926] Sat, 09 September 2023 12:32 Go to next message
I want to use 4diac http on linux(ubuntu). For this I compiled forte with FORTE_COM_HTTP.
I used pthon server example like this:
pthon3 http.server 80 -> this provides a http server on localhost
Then I tried to use client_1 and also client_2_1 fbds, there is no connection to socket.
There is an error occures:
ERROR: A client should ALWAYS have exactly 2 RD ...
I added screentshots.
What am i missing?
Best regards
Re: How to use client fbd for http [message #1860938 is a reply to message #1860926] Sun, 10 September 2023 14:10 Go to previous messageGo to next message
as the error messages says you need a CLIENT FB with two RDs (outputs). This for example a CLIENT_1_2 or a CLIENT_0_3. You can create these by copying an existing CLIENT FB and adjust the name as well as the interface in the FB editor. You do not need to generate C++ code for these FBs.
I hope this helps.
Re: How to use client fbd for http [message #1860947 is a reply to message #1860938] Mon, 11 September 2023 08:37 Go to previous message
Thank you for reply Professor
[Updated on: Fri, 15 September 2023 04:20] by Moderator
Previous Topic:Porting Forte.
Next Topic:Does 4DIAC support Bluetooth Low Energy connection?
Current Time: Fri Jul 18 07:16:17 EDT 2025
Powered by FUDForum. Page generated in 0.29403 seconds
