Home » Language IDEs » PHP Development Tools (PDT) » SSHTunnel Configuration , How To setup?(Need help)
SSHTunnel Configuration , How To setup? [message #1860696] Fri, 25 August 2023 21:32 Go to next message
Carlos Sanchez is currently offline Carlos SanchezFriend
Can someone detail the proper way to setup an SSH Tunnel connection on a non-std port, say 22123, in Eclipse 23.06 in order to debug PHP website remotely?
I have tried to do it within Eclipse but the connection is not established and also setting up the tunnel with Putty in which case the tunnel is established but Eclipse complains port 9003 is in use or stays in Launching Debug ( XDebug) 72%.
[Updated on: Sat, 26 August 2023 16:55]
Report message to a moderator
Re: SSHTunnel Configuration , How To setup? [message #1860704 is a reply to message #1860696] Sun, 27 August 2023 19:10 Go to previous message
I give up. Eclipse does not even try to setup the tunnel when asked to debug through SSH tunnel.
Previous Topic:WORDPRESS Remote Debugging SSH Tunnel Putty
Next Topic:Show distinct column values in pyspark dataframe
Current Time: Sat Jan 18 14:09:24 GMT 2025
Powered by FUDForum. Page generated in 0.03158 seconds
