Tutorial directions give error [message #1860346] |
Mon, 31 July 2023 12:02  |
Hello everyone. I followed the exact directions in the tutorial section.
When I try to Run it gives the following error. Please help.
Done in 1.3s
pnpm install finished successfully!
Running 'pnpm build:dev:watch'
> @contacts/ui@1.0.0-SNAPSHOT build:dev:watch C:\Users\mmkar\eclipse-workspace\contacts\contacts.ui.html
> scout-scripts build:dev:watch
'scout-scripts' is not recognized as an internal or external command,
operable program or batch file.
ELIFECYCLE Command failed with exit code 1.
WARN Local package.json exists, but node_modules missing, did you mean to install?
FUDForum. Page generated in 0.03525 seconds
