Home » Modeling » TMF (Xtext) » Accessing Enum from imported ECore model
Accessing Enum from imported ECore model [message #1860231] Mon, 24 July 2023 17:16 Go to next message
Thomas Chiang is currently offline Thomas ChiangFriend
I have an imported ECore model into my xtext grammar. I'm trying to maintain one list of Enum types for both my ECore model and my Xtext grammar. What I'm currently struggling with is how to create rules using my Enum types from my ECore model.
grammar org.mcmaster.pfcsm.operation.actiondsl.Actiondsl with org.eclipse.xtext.common.Terminals
generate actiondsl "http://www.mcmaster.org/pfcsm/operation/actiondsl/Actiondsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "http://www.example.org/pfcsm" as pfcsm
Domainmodel:
    (elements+=AbstractElement)*;
AbstractElement:
    PackageDeclaration | Type;
PackageDeclaration:
    'package' name=QualifiedName '{'
QualifiedName:
    ID ('.' ID)*;
Type:
	DataType | Value | Variable
DataType:
	type = [pfcsm|PrimitiveType]
Value:
	STRING | INT
Variable:
	'var' name=ID ' ' type=[DataType] '=' Value
Any instructions on how to reach the enum 'PrimitiveType' would be appreciated.
Re: Accessing Enum from imported ECore model [message #1860233 is a reply to message #1860231] Mon, 24 July 2023 17:48 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
I can't follow you.
Enums are not cross refs
So you need to define and use a enum
DataType: type= PrimitiveType
enum PrimitiveType returns pfcsm::PrimitiveType: ..
Twitter : @chrdietrich
[Updated on: Mon, 24 July 2023 17:48]
Report message to a moderator
Re: Accessing Enum from imported ECore model [message #1860236 is a reply to message #1860233] Mon, 24 July 2023 18:03 Go to previous messageGo to next message
This is the enum from ECore:
index.php/fa/43345/0/
So I'm essentially building a local copy of it in my xtext grammar.
	String | Int | Double | Boolean
I'm assuming since they aren't cross refs this is the only way to maintain the 'same' enums in both abstract syntaxes?
Re: Accessing Enum from imported ECore model [message #1860237 is a reply to message #1860236] Mon, 24 July 2023 18:11 Go to previous messageGo to next message
I've also run into this error trying to generate the xtext artifacts:
445  [main] ERROR xt.generator.XtextGeneratorLanguage  - [XtextLinkingDiagnostic: null:5 Couldn't resolve reference to EPackage 'http://www.example.org/pfcsm'., XtextLinkingDiagnostic: null:29 Couldn't resolve reference to EClassifier 'PrimitiveType'., TransformationDiagnostic: null:29 Cannot create type without declared package. (ErrorCode: UnknownMetaModelAlias)]
446  [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - Problems running workflow org.mcmaster.pfcsm.operation.actiondsl.GenerateActiondsl: Problem parsing 'file:/C:/Users/sirch/eclipse-workspace/org.mcmaster.pfcsm.operation.actiondsl/../org.mcmaster.pfcsm.operation.actiondsl/src/org/mcmaster/pfcsm/operation/actiondsl/Actiondsl.xtext':
How do I add my ECore model to path?
[Updated on: Mon, 24 July 2023 18:13]
Re: Accessing Enum from imported ECore model [message #1860238 is a reply to message #1860237] Mon, 24 July 2023 18:25 Go to previous messageGo to next message
yes you need to replicate in grammar. synatax could be different from ecore.
referencedResource in the workflow file to genmodel should solve this
[Updated on: Mon, 24 July 2023 18:25]
Re: Accessing Enum from imported ECore model [message #1860239 is a reply to message #1860238] Mon, 24 July 2023 18:29 Go to previous messageGo to next message
Does that mean I add the ecore model here?
index.php/fa/43346/0/
Not really sure how to do this "referencedResource in the workflow file to genmodel should solve this"
Re: Accessing Enum from imported ECore model [message #1860240 is a reply to message #1860239] Mon, 24 July 2023 18:30 Go to previous messageGo to next message
no, the workflow file.
and the manifest.mf
(dont know where your ecores are)
Re: Accessing Enum from imported ECore model [message #1860241 is a reply to message #1860240] Mon, 24 July 2023 18:35 Go to previous messageGo to next message
Currently my ecores and my xtext are all in my current workspace.
In my xtext manifest I've added my main ecore folder (not the generated ones) to my dependencies as required plug-ins and imported packages. And then in runtime I've also added the same main ecore project to class path, shown in the image above.
Is the workflow file the MWE2 file? Do I add something like:
module org.mcmaster.pfcsm.operation.actiondsl.GenerateActiondsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
import org.mcmaster.pfcsm
Re: Accessing Enum from imported ECore model [message #1860242 is a reply to message #1860241] Mon, 24 July 2023 18:41 Go to previous messageGo to next message
isnt there a referencedResource already in this file?
also: dont mess with classpaths folders etc.
go to manifest
go to dependencies
add plugin that contains ecore to the required bundles
[Updated on: Mon, 24 July 2023 18:43]
Re: Accessing Enum from imported ECore model [message #1860243 is a reply to message #1860242] Mon, 24 July 2023 18:56 Go to previous messageGo to next message
I just added the reference but I'm still getting the same error.
I've removed the ecore model from the classpath, but left it in the dependencies as you said:
index.php/fa/43347/0/
Still getting the
error. Is the MWE2 file the correct file to be editing or is there another one that I should be looking for?
[Updated on: Mon, 24 July 2023 19:15]
Re: Accessing Enum from imported ECore model [message #1860244 is a reply to message #1860243] Mon, 24 July 2023 18:59 Go to previous messageGo to next message
can you please share your project layouts, where the ecore and genmodels are etc, the workflow file etc.
there are 100000 possible combinations i cannot guess
e.g.
add
referencedResource="platform:/resource/org.mcmaster.pfcsm/model/whatever.genmodel"
to the language section of the workflow
[Updated on: Mon, 24 July 2023 19:01]
Re: Accessing Enum from imported ECore model [message #1860245 is a reply to message #1860244] Mon, 24 July 2023 19:08 Go to previous messageGo to next message
Here is an image of the project explorer
index.php/fa/43348/0/
I've also zipped up the projects together if it helps.
Re: Accessing Enum from imported ECore model [message #1860246 is a reply to message #1860245] Mon, 24 July 2023 19:12 Go to previous messageGo to next message
adjusting workflow to
language = StandardLanguage {
referencedResource="platform:/resource/org.mcmaster.pfcsm/model/pfcsm.genmodel"
works perfectly fine for me
Re: Accessing Enum from imported ECore model [message #1860247 is a reply to message #1860246] Mon, 24 July 2023 19:17 Go to previous message
Ok I didn't understand that it wasn't in the import section of the MWE2 file that needed to be changed. I've added that to the same spot and it works now too for me.
Thanks for the help and sorry for the confusion.
Also for anyone else reading this later workflow file is the MWE2 file for the dsl.
Previous Topic:Vscode plugin issue (OutPutStream issue)
Next Topic:Arithmetic defined in xtext
Current Time: Sat Jun 15 17:29:09 GMT 2024
Powered by FUDForum. Page generated in 0.04684 seconds
