Home » Newcomers » Newcomers » Cannot open Eclipse Marketplace
Cannot open Eclipse Marketplace [message #1860027] Wed, 12 July 2023 03:55 Go to next message
Hi All, I am a new user to Eclipse.
Using Eclipse 2023-06 with Java version 20, the problem now unable to open Eclipse Marketplace, the error as shown in the attached image.
Need help and thanks in advance.
Re: Cannot open Eclipse Marketplace [message #1860034 is a reply to message #1860027] Wed, 12 July 2023 10:47 Go to previous messageGo to next message
Are you behind a firewall? You could try adding these two lines at the end of your eclipse.ini:
-Djavax.net.ssl.trustStoreType=Windows-ROOT
-Djavax.net.ssl.trustStore=NONE
Re: Cannot open Eclipse Marketplace [message #1861172 is a reply to message #1860027] Mon, 25 September 2023 21:56 Go to previous messageGo to next message
Roger Hendri wrote on Wed, 12 July 2023 07:55
Using Eclipse 2023-06 with Java version 20, the problem now unable to open Eclipse Marketplace, the error as shown in the attached image. geometry dash
It's inconvenient but I can't see your pictures.
[Updated on: Mon, 25 September 2023 21:56] by Moderator
Re: Cannot open Eclipse Marketplace [message #1861176 is a reply to message #1861172] Tue, 26 September 2023 03:43 Go to previous message
It shows a "PKIX path" error that is invariably caused by a certificate problem which often happens when you are inside a corporate firewall.
I'm not sure what you are hoping to discover by seeing the picture that would not be better accomplished by describing your problem. You're not able to open this link?
https://www.eclipse.org/forums/index.php?t=getfile&id=43327&
Previous Topic:Problem installing or updating plugins
Next Topic:Open application using Eclipse Temurin OpenJDK
Current Time: Thu May 22 09:55:06 EDT 2025
Powered by FUDForum. Page generated in 0.37563 seconds
