Home » Newcomers » Newcomers » Debugging using Eclipse IDE, source not found
Debugging using Eclipse IDE, source not found [message #1860003] Mon, 10 July 2023 04:43 Go to next message
Thank you for reading my post.
In the Eclipse IDE, I have a workspace with several interdependent projects:
- four dynamic Web projects,
- one Java project
- and three Web fragments.
After setting breakpoints, when I try to debug my project, instead of allowing me to trace the code step by step after the breakpoint has been reached, I get an empty window with a "Source not found" message and a button labelled "Edit Source Lookup Path".
What is bizarre is that I can trace the code with one of dynamic Web projects but not inside the others.
Can you please help?
Best regards.
Re: Debugging using Eclipse IDE, source not found [message #1860089 is a reply to message #1860003] Sun, 16 July 2023 12:07 Go to previous messageGo to next message
How are you launching your project for debug?
Re: Debugging using Eclipse IDE, source not found [message #1860110 is a reply to message #1860089] Tue, 18 July 2023 07:35 Go to previous messageGo to next message
I go to the "Servers" window which has an entry "Tomcat v10.0 Server at localhost".
I right-click on that entry and choose "Debug".
Best regards.
Re: Debugging using Eclipse IDE, source not found [message #1860381 is a reply to message #1860110] Wed, 02 August 2023 09:02 Go to previous message
I've faced a similar issue before. It sounds like a source path problem. Try right-clicking on the project, then "Properties > Java Build Path > Source", and check if paths match. Good luck!
Cheers!
[Updated on: Thu, 03 August 2023 08:41] by Moderator
Previous Topic:error message ' could not create the view'
Next Topic:Python code hierarchy tool?
Current Time: Tue Mar 25 22:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.09306 seconds
