Home » Eclipse Projects » EGit / JGit » Pull doesnt work in Git Perpective
Pull doesnt work in Git Perpective [message #1859846] Fri, 30 June 2023 06:37 Go to next message
Hi to all,
I am experiencing an issue with the IBM Rational Business Developer (RBD) v 9.5.1 and eGit (org.eclipse.egit.repository-5.2.0.201812061821-r). When attempting to execute a "Pull" operation within the Git perspective of the IBM RBD tool, I encounter the following error:
Message: Unhandled event loop exception
Exception Stack trace: org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: org.eclipse.core.runtime.jobs.JobGroup
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(Unknown Source)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(Unknown Source)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(Unknown Source)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(Unknown Source)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(Unknown Source)
at org.eclipse.core.commands.Command.executeWithChecks(Unknown Source)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(Unknown Source)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(Unknown Source)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(Unknown Source)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(Unknown Source)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$6(Unknown Source)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Unknown Source)
at org.eclipse.jface.window.Window.open(Unknown Source)
at org.eclipse.ui.internal.views.log.EventDetailsDialog.open(Unknown Source)
at org.eclipse.ui.internal.views.log.EventDetailsDialogAction.run(Unknown Source)
at org.eclipse.ui.internal.views.log.LogView$15.doubleClick(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer$1.run(Unknown Source)
at org.eclipse.core.runtime.SafeRunner.run(Unknown Source)
at org.eclipse.ui.internal.JFaceUtil$1.run(Unknown Source)
at org.eclipse.jface.util.SafeRunnable.run(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(Unknown Source)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(Unknown Source)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(Unknown Source)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(Unknown Source)
at org.eclipse.jface.util.OpenStrategy.access$0(Unknown Source)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(Unknown Source)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(Unknown Source)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Unknown Source)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(Unknown Source)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(Unknown Source)
at org.eclipse.ui.internal.Workbench$5.run(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Unknown Source)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.equinox.launcher.Main.basicRun(Unknown Source)
at org.eclipse.equinox.launcher.Main.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.main(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: org.eclipse.core.runtime.jobs.JobGroup
at org.eclipse.egit.ui.internal.pull.PullOperationUI.<init>(Unknown Source)
at org.eclipse.egit.ui.internal.actions.PullFromUpstreamActionHandler.execute(Unknown Source)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Unknown Source)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(Unknown Source)
... 59 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.runtime.jobs.JobGroup cannot be found by org.eclipse.egit.core_5.2.0.201812061821-r
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Unknown Source)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Unknown Source)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(Unknown Source)
... 67 more
Session data: eclipse.buildId=unknown
java.fullversion=JRE 1.8.0 IBM J9 2.8 Windows 10 amd64-64 Compressed References 20160106_284759 (JIT enabled, AOT enabled)
J9VM - R28_20160106_1341_B284759
JIT - tr.r14.java_20151209_107110.02
GC - R28_20160106_1341_B284759_CMPRSS
J9CL - 20160106_284759
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=hr_HR
I kindly ask for your assistance in resolving this issue. I am using the Windows 10 operating system, and my JVM version is JRE 1.8.0 IBM J9.
I appreciate your help in advance.
KD
Re: Pull doesnt work in Git Perpective [message #1859852 is a reply to message #1859846] Fri, 30 June 2023 11:36 Go to previous message
We don't have RBD available. Please approach the vendor with this problem.
Previous Topic:Unable to connect using SSH in JGit
Next Topic:Using commit command on JGit cause no diff changes
Current Time: Sun Jun 15 08:36:46 EDT 2025
Powered by FUDForum. Page generated in 0.04317 seconds
