Home » Modeling » TMF (Xtext) » Calling IReferenceFinder.findAllReferences in tests
Calling IReferenceFinder.findAllReferences in tests [message #1859831] Thu, 29 June 2023 05:16 Go to next message
Hi :)
I'm trying to use IReferenceFinder in one of my unit tests in order to find all the elements that refers to another element defined in the tree. In my test I'm using an injected ParseHelper instance to parse model from string, later on I pick the interested element from the tree and call findAllReferences on IReferenceFinder somehow like this:
ElementDeclarationNode element = result.getElements().get(0);
        var targetURIs = targetURIProvider.get();
        targetURIs.addURI(EcoreUtil.getURI(element));
        referenceFinder.findAllReferences(targetURIs, null, resourceDescriptions, new IReferenceFinder.Acceptor() {
            public void accept(EObject source, URI sourceURI, EReference eReference, int index, EObject targetOrProxy, URI targetURI) {
                System.out.println();
            public void accept(IReferenceDescription description) {
        }, new NullProgressMonitor());
resourceDescriptions is injected as well...
When I run this code the following exception appears:
java.lang.NullPointerException: Cannot invoke "org.eclipse.emf.ecore.resource.ResourceSet.getResources()" because "this.this$1.this$0.resourceSet" is null
	at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions$1$1.<init>(ResourceSetBasedResourceDescriptions.java:67)
I have some feeling it's like this due to the fact I dont have any real resource but just a string parsed... What can I do to make it work?
I appreciate any help here, thanks in advance :)
Re: Calling IReferenceFinder.findAllReferences in tests [message #1859832 is a reply to message #1859831] Thu, 29 June 2023 05:22 Go to previous messageGo to next message
Hello Lukasz!
You can take some inspiration from the DotReferenceFinderTest.xtend test cases.
Hope that helps!
Tamás
Re: Calling IReferenceFinder.findAllReferences in tests [message #1859835 is a reply to message #1859832] Thu, 29 June 2023 05:55 Go to previous messageGo to next message
Hi Tamas,
Thank you for your quick reply :) Unfortunately ReferenceQueryExecutor seems to be from "ui" module that is generated for eclipse based DSL project while I'm rather using maven project structure instead - in this setup there is just generic "ide" and core xtext stuff generated :/
Re: Calling IReferenceFinder.findAllReferences in tests [message #1859840 is a reply to message #1859835] Thu, 29 June 2023 08:22 Go to previous message
Ha! I made it work, so my full test looks like this now:
 // given
        some dsl code here
        XtextResourceSet resourceSet = resourceSetProvider.get();
        // when
        Resource resource = loadResource("test.mydsl", script, resourceSet);
        // then
        assertThat(resource.getErrors()).isEmpty();
        // given
        var element = resource.getContents().get(0).eContents().get(0);
        URI uri = EcoreUtil2.getPlatformResourceOrNormalizedURI(element);
        TargetURIs targetURIs = targetURIConverter.fromIterable(List.of(uri));
        // when
        resourceSet.getResources().add(resource);
        var resourceDescriptions = resourceDescriptionsProvider.get();
        resourceDescriptions.setContext(resourceSet);
        var localResourceAccess = new SimpleLocalResourceAccess(resourceSet);
        referenceFinder.findAllReferences(targetURIs, localResourceAccess, resourceDescriptions, new IReferenceFinder.Acceptor() {
I also had to create my own implementation of SimpleLocalResourceAccess (I copied it from here: https://github.com/eclipse/xtext/blob/main/org.eclipse.xtext.ui/src/org/eclipse/xtext/ui/editor/findrefs/SimpleLocalResourceAccess.java
and now everything works as expected :)
Previous Topic:Library in VS Code extension
Next Topic:[SOLVED] A (very stupid?) beginner problem
Current Time: Sat Jun 21 11:21:32 EDT 2025
Powered by FUDForum. Page generated in 0.03909 seconds
