Moka BasicActiveObjectExample has warnings and errors [message #1859516] |
Tue, 13 June 2023 09:04 |
Pierre van de Laar Messages: 2 Registered: June 2023 |
Dear Developers,
After installing Papyrus (2023-03 4.27) and Moka (4.1.0), I started with the BasicActiveObjectExample.
Validation however gives warnings and errors.
I could remove the warnings related to the Multiplicity Element by clicking switch editors and explicitly filling in lower and upper Values.
(Yet, I still don't understand why entering 1 in the other editor is not enough).
However, I have no clue on how to remove the errors:
* Error [Moka][fuml] Operation - If an operation is abstract it must have no method. Otherwise it must have exactly one method. <<Create>> <Operation> Increment () : Increment model::BasicActiveObjectExample::Increment EMF Problem
*Error The object flow must link object nodes with the same upper bounds. <Object Flow> createObjectAction to callConstructor model::BasicActiveObjectExample::Increment::Increment_Factory EMF Problem
Especially, since the last error is within Increment_Factory (which I just generated as described on https://wiki.eclipse.org/Papyrus/UserGuide/ModelExecution#Your_first_executable_model ) if have serious doubt as a beginner whether I did something wrong and am hesitant to continue with fUML...
So could these warnings and errors be removed?
If so, could a new, correct version of BasicActiveObjectExample be provided?
If not, how can I do it myself?
Greetings,
Pierre
FUDForum. Page generated in 0.03327 seconds
