Home » Newcomers » Newcomers » Openhab2 problem with script parameter in ' '(Eclipse error message in Openhab2)
Openhab2 problem with script parameter in ' ' [message #1859395] Mon, 05 June 2023 04:49 Go to next message
I have a problem when calling a python script with parameter between apostrophs.
If parameter is e.g. only 'info' all is correct.
But if a parameter uses points inside e.g. 'xcom.xt1.3000'
a error message appears.
val String answer = executeCommandLine("/etc/openhab2/scripts/openstuder-examples-python/cli/./sicli@@localhost@@'read xcom.xt1.3000'", 5000)
[INFO ] [lipse.smarthome.model.script.Result=] - *** Unknown syntax: "read xcom.xt1.3000"
Thanks for help.
Re: Openhab2 problem with script parameter in ' ' [message #1859424 is a reply to message #1859395] Tue, 06 June 2023 20:29 Go to previous messageGo to next message
Where does Eclipse and something from eclipse.org come into this scenario?
Re: Openhab2 problem with script parameter in ' ' [message #1859426 is a reply to message #1859424] Wed, 07 June 2023 05:54 Go to previous message
If you don't have a idea close the topic please.
Previous Topic:Java fx
Next Topic:IRC
Current Time: Thu Mar 27 07:39:21 EDT 2025
Powered by FUDForum. Page generated in 0.07786 seconds
