OPC UA with freeRTOS LWIP [message #1859010] |
Fri, 05 May 2023 23:06  |
I want to use opc ua in my freertos system(esp32s2). I compiled opc ua for posix there is no problem in there. But when I try to compile opc ua (git clone https://github.com/open62541/open62541.git --branch=v1.0 open62541) for freertos lwip with esp32s2 gcc compiler there is a lot of error.
Can I use libopen62541.so (built for posix) in my freertos system?
I think in order to use opc ua in freertos I must to compile with own compiler. Am I wrong ?
Best Regards.
Re: OPC UA with freeRTOS LWIP [message #1859018 is a reply to message #1859010] |
Sat, 06 May 2023 13:20   |
yes you need to compile all code and all libraries you would like to use with the compiler, libs and includes of your target system. I don't know if open6251 has been ported to freeRTOS. But I think this is the first thing you need to check. So I would suggest to ask the open62541 people about this.
Alois
FUDForum. Page generated in 0.04541 seconds
