Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ToStringVisitorImpl.toString returning null
ToStringVisitorImpl.toString returning null [message #34554] Fri, 19 May 2006 14:26 Go to next message
Originally posted by: jgreen.upb.de
I observed the method ToStringVisitorImpl.toString(Visitable v) returning null.
While creating e.g. a Variable through the reflective API mechanism, the method returns null. Probably because not all
features have been initialized corretly. Changing the method as shown works fine so far.
public static String toString(Visitable v) {
return (String) v.accept(getInstance()) + "";
I don't know if this is a bug or if there might be more general problems with what I'm doing?
Joel
Re: ToStringVisitorImpl.toString returning null [message #34689 is a reply to message #34554] Tue, 23 May 2006 10:23 Go to previous messageGo to next message
Hi, Joel,
The toString() is really only intended for debugging purposes, because a
correct AST-to-Text convertor would have to account for operator precedence
and other constructs (such as if..then..else..endif) that require smart
parenthesization (as the AST has no parentheses).
However, I would like it to work reasonably well, and I think that returning
null is not particularly reasonable.
The only way that you should be able to get null for a Variable's toString
is if the variable has no name. This is not a valid variable, so there is
no corresponding valid text. I would rather display, in this case,
"<unnamed variable>" or some such for the name so that an expressions'
toString() will indicate where the problem is.
Would you mind opening a bug? Just click here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT& ;version=1.0&component=OCL&form_name=enter_bug
Christian
Joel Greenyer wrote:
> null.
> method returns null. Probably because not all features have been
> Joel
Re: ToStringVisitorImpl.toString returning null [message #34861 is a reply to message #34689] Wed, 24 May 2006 13:48 Go to previous messageGo to next message
Perhaps 125079 should be re-opened.
ToStringVisitor is just not fit for purpose as a debugging tool.
I created a RobustToStringVisitor to which I add more and more NPE fixes.
ToStringVisitor needs a major revision to assume that most things/anything
could be null.
Ed Willink
Re: ToStringVisitorImpl.toString returning null [message #34939 is a reply to message #34861] Wed, 24 May 2006 23:12 Go to previous messageGo to next message
Hi, Ed,
In my experience, Object.toString() isn't an API that production code
should use. Most objects don't provide anything useful (often just
"<class-name>@<memory-address>") and very few specify the content of their
string representations. I like JFace's and EMF's approach of delegating
the calculation of displayable strings to third parties (label providers).
Unfortunately, many APIs do seem to assume that toString() provides
something useful, so it behooves objects like OCL expressions to try hard
not to throw NPEs in this method.
At this point in the release, it's hard to do more for bugs such as 125079
than what they ask for. However, if you have a robust implementation to
contribute, I will be more than happy to accept it! It would be great to
have help to make the ToStringVisitorImpl more tolerant of invalid
expression models; it's a big job, and there is so much else to do ...
Perhaps you can raise a bugzilla and attach your RobustToStringVisitor to
it? And if you can provide JUnit tests, so much the better.
Eventually, EMFT OCL will have to provide a specific public API for
transforming expression models to text. That will be a more "correct"
solution. Until then, of course, we only have toString().
Christian
P.S. - there are other issues in the fidelity of the string rendered by
ToStringVisitorImpl, for which help would be appreciated:
- rendering operators with infix notation (not, e.g., "a.+(b)"), which
would incidentally require parenthesization
- eliding implicit iterator variables (no ugly "temp4"s)
- simplifying type references, to use unqualified names where possible
- (I'm sure there are more)
Re: ToStringVisitorImpl.toString returning null [message #35293 is a reply to message #34939] Fri, 26 May 2006 01:16 Go to previous messageGo to next message
Hi Christian
> should use.
I agree. My usage/problems arose while developing code that
generated OCL models and then attempted to persist them fully. My
code was not entirely bug free especially as OCL drifted towards strict
compliance. So I was particularly sensitive to the quality of the
toString() method as invoked by JDT, which has also improved. The
NPEs hiding debug output and sometimes even disrupting debug operation
were very unhelpful.
My RobustToStringVisitor was a pragmatic hack fixing apparent hazards
intuitively. It certainly didn't fix all problems, it had no tests.
But it did help me discover which 'optional' OCL attributes were
actually mandatory. It has been attached to Bug 143882.
Custom formatters are indeed a better approach.
Perhaps you should regard maximising utility within JDT as the design
goal for toString(). This might suggest retaining a.+(b) to more
clearly reflect the object structure.
Ed Willink
Re: ToStringVisitorImpl.toString returning null [message #35360 is a reply to message #35293] Fri, 26 May 2006 07:30 Go to previous messageGo to next message
Ed Willink wrote:
> Hi Christian
>> should use.
I agree. The toString() works great for well-formed OCL and debugging
problems with well-formed expressions, but was rather useless for debugging
bad OCL expressions, themselves!
Great! Thanks. I'll have a look at it ASAP. I have an idea how to work it
into our tests to ensure that well-formed expressions, at least, will
always succeed in producing a toString.
BTW, would you happen to know off-hand (or have a list in your back pocket)
of which properties are optional in the Ecore model but actually mandatory?
It's quite probable that there are still some mismatches in this regard
between the Ecore and the spec.
Good point. That sounds like the right approach.
Thanks again!
Christian
> Regards
> Ed Willink
Re: ToStringVisitorImpl.toString returning null [message #35393 is a reply to message #35360] Fri, 26 May 2006 07:54 Go to previous messageGo to next message
--------------090502000709080501010905
Christian,
Wilson, our new co-op student, is starting to work on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933 so we should be in
much better shape next release to weed out Ecore model badness before it
breaks downstream code that expects well-formed Ecore models...
> Ed Willink wrote:
>> Hi Christian
>>> should use.
> Thanks again!
> Christian
>> Regards
>> Ed Willink
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Christian,<br>
<br>
Wilson, our new co-op student, is starting to work on <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933">https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933</a>
so we should be in much better shape next release to weed out Ecore
model badness before it breaks downstream code that expects well-formed
Ecore models...<br>
<br>
<br>
<blockquote cite="mide56ort$icc$1@utils.eclipse.org" type="cite">
<pre wrap="">Ed Willink wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi Christian
</pre>
<pre wrap="">In my experience, Object.toString() isn't an API that production code
should use.
</pre>
</blockquote>
<pre wrap="">I agree. My usage/problems arose while developing code that
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">My RobustToStringVisitor was a pragmatic hack fixing apparent hazards
</pre>
</blockquote>
</pre>
<pre wrap="">Custom formatters are indeed a better approach.
</pre>
</blockquote>
Thanks again!
Christian
</pre>
<pre wrap="">Regards
Ed Willink
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------090502000709080501010905--
Re: ToStringVisitorImpl.toString returning null [message #35915 is a reply to message #35360] Sun, 04 June 2006 04:27 Go to previous messageGo to next message
The following is a vaguely remembered list of nightmare debugs that I have had over
the past couple of years. EMF error handling has improved dramatically in that time and
I have reported a fair number of bugs so it may well be that some of the following
no longer apply.
XMI semantic errors used to be catastrophic, now bad references are often
correctly diagnosed, but I still end up in the attempt to use the null feature
NPE more often than I like, and it's very hard to diagnose.
Derived Java code for a model can enforce a stricter type on a model element, and
it works just fine until a model is read that explicitly xsi:type="...:... ..." provides
an insufficiently strict class. The resulting CCE occurs in subsequent usage rather
than during the model read. I no longer try to use stricter types, though I think
MOF would allow it.
A null ENamedElement.name can be quite unforgiving.
A null ETypedElement.eType/EReference.eReferenceType/EAttribute/eAt tributeType can be very unforgiving.
EMF itself (create/loadResource is pretty good) it's genModel where the nightmares
begin. Bad models can/could variously cause models to be unloadable, or for
referenced genmodels to be unconfigurable or for code generation to fail sometimes
silently. It is unhelpful that the genmodel progress monitor is far from
uniform rate; the last bits are very quick especially for a silent failure.
A null EDataType.instanceClassName is really bad, and quite reasonable when
EMF is perceived as a generic modeling capability rather than a Java code generator.
A null EPackage.nsURI is similarly bad and reasonable.
It would be nice if genModel could automatically provide defaults for everything that
is missing from a model only file.
- offer java.lang elements for EDataTypes
- offer default URIs
rather than barf.
Incorrect containment is one of my regular problems. Using the Ecore editor, it is very
hard to check that relationships are correct. It is only when a UML-like presentation is
used that stipidities are self evident. I suspect that there are some useful diagnostics
that a nanny-mode might support - for instance, perhaps no model element other than the
root should lack a potential container.
Re: ToStringVisitorImpl.toString returning null [message #35949 is a reply to message #35915] Sun, 04 June 2006 08:13 Go to previous message
--------------000703020008020207090602
Ed,
The problems you list will be diagnosed as constraint violations when
this is done:
We've started work on it so it will be available early in the next
development cycle.
Keep in mind that in an open source community it's also possible to help
yourself by helping the community, i.e., donations will accomplish more
than will hand wringing...
>> pocket)
>> mandatory? It's quite probable that there are still some mismatches
>> in this regard
> have had over
> in that time and
> the following
> no longer apply.
> feature
> element, and
> usage rather
> though I think
> MOF would allow it.
> A null
> the nightmares
> or for
> fail sometimes
> failure.
> when
> code generator.
> everything that
> rather than barf.
> editor, it is very
> useful diagnostics
<html>
<head>
</head>
Ed,<br>
<br>
this is done:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933">https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933</a><br>
</blockquote>
development cycle.<br>
<br>
help yourself by helping the community, i.e., donations will accomplish
more than will hand wringing...<br>
<br>
<br>
Ed Willink wrote:
<blockquote cite="mide5u5h5$530$1@utils.eclipse.org" type="cite">Christian
W. Damus wrote:
<br>
<br>
<blockquote type="cite">BTW, would you happen to know off-hand (or
<br>
mandatory? It's quite probable that there are still some mismatches in
this regard
<br>
<br>
</blockquote>
<br>
have had over
<br>
in that time and
<br>
the following
<br>
no longer apply.
<br>
<br>
often
<br>
feature
<br>
<br>
<br>
element, and
<br>
<br>
usage rather
<br>
though I think
<br>
MOF would allow it.
<br>
<br>
<br>
<br>
A null
<br>
<br>
nightmares
<br>
for
<br>
fail sometimes
<br>
from
<br>
failure.
<br>
<br>
when
<br>
code generator.
<br>
<br>
<br>
<br>
everything that
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;- offer java.lang elements for EDataTypes
<br>
&nbsp;&nbsp;&nbsp;&nbsp;- offer default URIs
<br>
rather than barf.
<br>
<br>
editor, it is very
<br>
<br>
useful diagnostics
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000703020008020207090602--
Re: ToStringVisitorImpl.toString returning null [message #578354 is a reply to message #34554] Tue, 23 May 2006 10:23 Go to previous message
Hi, Joel,
Christian
> null.
> Joel
Re: ToStringVisitorImpl.toString returning null [message #578487 is a reply to message #34689] Wed, 24 May 2006 13:48 Go to previous message
could be null.
Ed Willink
Re: ToStringVisitorImpl.toString returning null [message #578544 is a reply to message #34861] Wed, 24 May 2006 23:12 Go to previous message
Hi, Ed,
Christian
Re: ToStringVisitorImpl.toString returning null [message #578975 is a reply to message #34939] Fri, 26 May 2006 01:16 Go to previous message
Hi Christian
> should use.
Ed Willink
Re: ToStringVisitorImpl.toString returning null [message #579028 is a reply to message #35293] Fri, 26 May 2006 07:30 Go to previous message
Ed Willink wrote:
> Hi Christian
>> should use.
Thanks again!
Christian
> Regards
> Ed Willink
Re: ToStringVisitorImpl.toString returning null [message #579052 is a reply to message #35360] Fri, 26 May 2006 07:54 Go to previous message
Christian,
> Ed Willink wrote:
>> Hi Christian
>>> should use.
> Thanks again!
> Christian
>> Regards
>> Ed Willink
<html>
<head>
</head>
Christian,<br>
<br>
Ecore models...<br>
<br>
<br>
</pre>
</pre>
should use.
</pre>
</blockquote>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
Thanks again!
Christian
</pre>
Ed Willink
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: ToStringVisitorImpl.toString returning null [message #579502 is a reply to message #35360] Sun, 04 June 2006 04:27 Go to previous message
no longer apply.
MOF would allow it.
rather than barf.
Re: ToStringVisitorImpl.toString returning null [message #579541 is a reply to message #35915] Sun, 04 June 2006 08:13 Go to previous message
Ed,
this is done:
development cycle.
>> pocket)
>> in this regard
> have had over
> in that time and
> the following
> no longer apply.
> feature
> element, and
> usage rather
> though I think
> MOF would allow it.
> A null
> the nightmares
> or for
> fail sometimes
> failure.
> when
> code generator.
> everything that
> rather than barf.
> editor, it is very
> useful diagnostics
<html>
<head>
</head>
Ed,<br>
<br>
this is done:<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
W. Damus wrote:
<br>
<br>
<br>
this regard
<br>
<br>
</blockquote>
<br>
have had over
<br>
in that time and
<br>
the following
<br>
no longer apply.
<br>
<br>
often
<br>
feature
<br>
<br>
<br>
element, and
<br>
<br>
usage rather
<br>
though I think
<br>
MOF would allow it.
<br>
<br>
<br>
<br>
A null
<br>
<br>
nightmares
<br>
for
<br>
fail sometimes
<br>
from
<br>
failure.
<br>
<br>
when
<br>
code generator.
<br>
<br>
<br>
<br>
everything that
<br>
<br>
<br>
<br>
rather than barf.
<br>
<br>
editor, it is very
<br>
<br>
useful diagnostics
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Previous Topic:QUERY for Eclipse 3.1.2
Next Topic:Grouping objects under a folder
Current Time: Tue Nov 18 05:05:52 EST 2025
Powered by FUDForum. Page generated in 0.06399 seconds
