Home » Eclipse Projects » GlassFish » JNDI String Resource?(JNDI String Resource?)
JNDI String Resource? [message #1858706] Mon, 17 April 2023 07:07 Go to next message
Hi Everyone,
I have four environment entries that work with my app. I'm new to glassfish, so please forgive me if I'm wrong...
I added the entries both under JNDI -> Custom Resources and External Resources. When it's under Custom Resources, it's not found - when it's under External Resources, I get a StackOverflow exception. This code/config works with Tomcat, so I'm fairly sure it's not that.
Any ideas?
Re: JNDI String Resource? [message #1859072 is a reply to message #1858706] Wed, 10 May 2023 05:53 Go to previous message
Hi, which GlassFish version do you use? Could you paste the StackOverflowException, or at least some important part of that (I don't need repeating lines, but at least the cause, where it started)?
Previous Topic:MySQL 8, Glassfish 7 and SSL
Next Topic:Glassfish 7.0.5 <stopexecutable> is missing in configuration XML
Current Time: Tue May 13 13:07:48 EDT 2025
Powered by FUDForum. Page generated in 0.04056 seconds
