Home » Eclipse Projects » Eclipse Titan » Issue while decoding COER packet(TTCN-3 ASN.1 COER CODEC)
Issue while decoding COER packet [message #1858700] Mon, 17 April 2023 01:34 Go to next message
Dear Support,
I got an issue while decoding a COER packet encoded by TITAN COER codec.
I attached the sample project to illustrate the issue. The error is:
hello_world.ttcn:211: Dynamic test case error: Unbound left operand of integer comparison.
It is linked ASN.1 files provided by IEEE 1609.2, IEEE 1609.2.1 and ETSI 103 759.
Many thanks in advanced for your support,
Best Regards,
Yann Garcia
FSCOM
Re: Issue while decoding COER packet [message #1859518 is a reply to message #1858700] Tue, 13 June 2023 05:51 Go to previous messageGo to next message
Do you have any feedback regarding this issue. It will become a blocking point soon.
Many thanks in advance for your support,
BR\Yann Garcia
Re: Issue while decoding COER packet [message #1859574 is a reply to message #1859518] Fri, 16 June 2023 05:08 Go to previous messageGo to next message
We will look into this soon, we'll let You know.
Lenard
Re: Issue while decoding COER packet [message #1860104 is a reply to message #1859574] Tue, 18 July 2023 02:47 Go to previous messageGo to next message
Hi Yann,
Finally, this issue has been resolved. It was a nasty one, see my comment here: https://gitlab.eclipse.org/eclipse/titan/titan.core/-/issues/701#note_1184064
Could you please verify whether it works as expected on your side as well? Thank you!
Re: Issue while decoding COER packet [message #1860113 is a reply to message #1860104] Tue, 18 July 2023 09:35 Go to previous messageGo to next message
Hello Adam,
I'll do it asap ;)
Many many thanks for your support
BR\Yann
Re: Issue while decoding COER packet [message #1860156 is a reply to message #1860113] Thu, 20 July 2023 02:25 Go to previous messageGo to next message
Hello Adam,
I did some tests and I guess there is an issue at runtime in relation with the issue https://www.eclipse.org/forums/index.php/t/1112865/.
I got the following error during test execution:
Dynamic test case error: Performing a valueof or send operation on a non-specific template of type @Ieee1609Dot2.SequenceOfAppExtensions
SequenceOfAppExtensions is only used in ToBeSignedCertificate data structure (Ieee1609.2) after the extension marker (...). It involves that the fields declared after ... shall be omitted.
What do yo think?
Many thanks in advance for your help,
BR\ Yann
Re: Issue while decoding COER packet [message #1860224 is a reply to message #1860156] Mon, 24 July 2023 07:45 Go to previous messageGo to next message
Hi Yann,
Do you have a simple test code to trigger this error? Thanks!
Re: Issue while decoding COER packet [message #1860291 is a reply to message #1860224] Thu, 27 July 2023 01:44 Go to previous message
Hello Adam,
I have some troubles: in my simple project, the decoding of the Ieee1609.2 certificates works fine: the fields in the ASN.1 extension are set to omit.
I'm going to investigate more :(
My apologies for the inconveniences,
Thanks a lot,
BR\Yann Garcia
Previous Topic:Crosstag with nested elements
Next Topic:COER encoding/decoding issue on EtsiTs102941Data ASN.1
Current Time: Tue Nov 18 11:09:20 EST 2025
Powered by FUDForum. Page generated in 0.05502 seconds
