Formatting source code JDT [message #1858642] |
Thu, 13 April 2023 10:38  |
bretny relly Messages: 14 Registered: March 2023 |
I'm using JDT to create certain classes. After that, I'd like to format the entire ICompilationUnit, just as if I clicked Ctrl+Shift+F (Source > Format) in an empty Editor.
Here is the code:
private void formatUnitSourceCode(ICompilationUnit targetUnit, IProgressMonitor monitor) throws JavaModelException {
CodeFormatter formatter = ToolFactory.createCodeFormatter(null);
TextEdit formatEdit = formatter.format(CodeFormatter.K_COMPILATION_UNIT, targetUnit.getSource(), -1, targetUnit.getSource().length(), 0, null);
targetUnit.applyTextEdit(formatEdit, monitor);
Any suggestions for the JDT API to format the source code programmatically would be greatly appreciated.
I tried it this way, but the code remained unchanged. What exactly am I mssing?
Re: Formatting source code JDT [message #1858807 is a reply to message #1858642] |
Mon, 24 April 2023 05:29  |
Alan Scott Messages: 5 Registered: April 2023 |
bretny relly wrote on Thu, 13 April 2023 10:38I'm using JDT to create certain classes. After that, I'd like to format the entire ICompilationUnit, just as if I clicked Ctrl+Shift+F (Source > Format) in an empty Editor.
Here is the code:anti wordle
Hi there! It looks like you're trying to use JDT to format your Java code programmatically. Your code looks correct, but there might be some issues with the input parameters or the execution context that are preventing it from working as expected.
Here are a few things you could check:
make sure that the compilation unit you're passing in actually contains source code that needs to be formatted. If the source code is already well-formatted, running the formatter on it may not make any changes.
ensure that the monitor you're passing to the applyTextEdit method is not null and is configured correctly to track the progress of the formatting operation. You could try passing a new NullProgressMonitor instance to see if that makes a difference.
check if there are any error messages or exceptions being thrown when you run the code. You could wrap the formatUnitSourceCode method in a try-catch block and log any caught exceptions to the console or a log file.
Lastly, you could try calling the save method on the compilation unit after applying the text edit. It's possible that the changes are being made but not being saved to disk.
I hope this helps! Let me know if you have any other questions.
FUDForum. Page generated in 0.02890 seconds
