Home » Eclipse Projects » Eclipse Titan » Fields declared after extension (...) are not set as optional(TTCN-3 ASN.1 compiler)
Fields declared after extension (...) are not set as optional [message #1858626] Wed, 12 April 2023 08:30 Go to next message
Dear Support,
Regarding to the ASN.1 standards, is a SEQUENCE, the fields declared after the extension symbol (...) shall be OPTIONAL by default due to backward compatibility.
For instance, ieee1609.2, we have the following declaration where the fields flags, appExtensions, certIssueExtensions  and certRequestExtension shall be optional even if it is not indicated:
ToBeSignedCertificate ::= SEQUENCE {
  id                     CertificateId,
  cracaId                HashedId3,
  crlSeries              CrlSeries,
  validityPeriod         ValidityPeriod,
  region                 GeographicRegion OPTIONAL,
  assuranceLevel         SubjectAssurance OPTIONAL,
  appPermissions         SequenceOfPsidSsp OPTIONAL,
  certIssuePermissions   SequenceOfPsidGroupPermissions OPTIONAL,
  certRequestPermissions SequenceOfPsidGroupPermissions OPTIONAL,
  canRequestRollover     NULL OPTIONAL,
  encryptionKey          PublicEncryptionKey OPTIONAL,
  verifyKeyIndicator     VerificationKeyIndicator,
  flags                  BIT STRING {usesCubk (0)} (SIZE (8)),
  appExtensions          SequenceOfAppExtensions
  certIssueExtensions    SequenceOfCertIssueExtensions,
  certRequestExtension   SequenceOfCertRequestExtensions
The C++ code generated by the TITAN ASN.1 compiler does not generate these fields with OPTIONAL decoration.
So I think there is an issue with the TITAN ASN.1 compiler.
What do you think?
Many thanks for your help,
BR\ Yann Garcia
Re: Fields declared after extension (...) are not set as optional [message #1858643 is a reply to message #1858626] Thu, 13 April 2023 07:18 Go to previous messageGo to next message
Hi Yann,
Thank you for reporting this issue. This behavior seems to be indeed missing. You can follow the status in this ticket: https://gitlab.eclipse.org/eclipse/titan/titan.core/-/issues/696
Re: Fields declared after extension (...) are not set as optional [message #1858671 is a reply to message #1858643] Fri, 14 April 2023 09:20 Go to previous messageGo to next message
Hello Adam,
Many thanks for your feedback ;)
BR\Yann
Re: Fields declared after extension (...) are not set as optional [message #1859261 is a reply to message #1858671] Wed, 24 May 2023 10:37 Go to previous messageGo to next message
Hi Yann,
This issue is fixed. It caused incompatible changes as till now this was not handled according to the standard. Could you please check whether it works as expected? Thank you!
Re: Fields declared after extension (...) are not set as optional [message #1859264 is a reply to message #1859261] Thu, 25 May 2023 03:19 Go to previous message
Hello Ádám,
Many thanks for your fix.
I rebuilt the test suites for both ITS rel.1 and rel.2 and everything looks fine.
BR\Yann Garcia
Previous Topic:Issue with XSD files (tool v8.3.0)
Next Topic:TITAN g++ compiler error
Current Time: Thu Jul 10 23:07:11 EDT 2025
Powered by FUDForum. Page generated in 0.03523 seconds
