Home » Eclipse Projects » EclipseLink » Is there a way to ignore a field when writing history table with @Customizer
Is there a way to ignore a field when writing history table with @Customizer [message #1858623] Wed, 12 April 2023 09:09
Renato Freire is currently offline Renato FreireFriend
I have a class which is annotated with eclipselink @Customizer.
That customizer, uses a custom customizer that inherits from DescriptorCustomizer. In customize function I have a HistoryPolicy in order to create a history table for the annotated class.
Down below I leave an example:
public class MyCustomizer implements DescriptorCustomizer {
    public void customize(ClassDescriptor cd) {
        HistoryPolicy policy = new HistoryPolicy();
        policy.addHistoryTableName("public" + ".history_table");
        policy.addStartFieldName("start_ts");
        policy.addEndFieldName("end_ts");
        cd.setHistoryPolicy(policy);
@Entity
@Customizer(MyCustomizer.class)
public class myClass {
    @Column(name = "field_To_Track")
    private Integer fieldToBeTracked;
    @Column(name = "field_Not_To_Track")
    private Integer fieldNotToBeTracked;
I want to ignore a fields from being the reason why a row it's written in the history table. That way, every new row written in the table it's not because of an update on that column. Is that possible?
[Updated on: Thu, 13 April 2023 05:12]
Report message to a moderator
Previous Topic:Exclude field when creating history table by using @Customizer
Next Topic:Analyze Profiler Logs
Current Time: Thu Feb 06 17:27:49 GMT 2025
Powered by FUDForum. Page generated in 0.03093 seconds
