Home » Eclipse Projects » EclipseLink » Spring orm toplink to eclipselink(Migration of spring.orm.toplink.* to eclipselink)
Spring orm toplink to eclipselink [message #1858511] Wed, 05 April 2023 13:54 Go to next message
Sanjana C is currently offline Sanjana CFriend
Member
As a part of migration from toplink to eclipselink we are using few apis of toplink from spring orm framework in project .
In few classes we are using
org.springframework.orm.toplink.UnitOfWorkCallback() class which should implemet doInUnitOfWork(oracle.toplink.sessions.UnitOfWork unitOfWork) abstract method and org.springframework.orm.toplink.TopLinkCallbackinterface where we implement
doInTopLink(Session session) method.
But when using eclipselink with spring jpa , how can we replace this above classes ?
Re: Spring orm toplink to eclipselink [message #1858524 is a reply to message #1858511] Wed, 05 April 2023 19:07 Go to previous message
You are not replacing TopLink with EclipseLink, but replacing Spring's TopLink framework with JPA centered ones - Spring essentially removed native TopLink/EclipseLink api support, and instead built EclipseLink support into its existing JPA framework.
In this case, you would use https://docs.spring.io/spring-framework/docs/2.5.x/javadoc-api/org/springframework/orm/jpa/JpaCallback.html and use the EntityManager api. This just wraps UnitOfWork instances - if you want to continue using UOWs directly, you just need to unwrap it:
UnitOfWork uow = entityManager.unwrap(UnitOfWork.class);
Or via api described here https://wiki.eclipse.org/EclipseLink/Examples/JPA/EMAPI#JPA_1.0
Best Regards,
Chris
Previous Topic:Ping test failed error
Next Topic:Exclude field when creating history table by using @Customizer
Current Time: Fri Feb 07 22:20:02 GMT 2025
Powered by FUDForum. Page generated in 0.03854 seconds
