eclipse fails to start after windows laptop restart [message #1856791] |
Tue, 03 January 2023 04:41  |
bln prasad Messages: 4 Registered: January 2023 |
I'm consistently seeing the issue where eclipse fails to start after my (windows) laptop restart. ive moved to latest version jee-2022-12 but still issue is seen. the only way to recover is fresh install of same version.
it always throws this error on fail. can you please do the needful to fix same.
it creates 7 err log files. just pasting start and end of it below.
!SESSION 2023-01-03 09:38:40.644 -----------------------------------------------^M
eclipse.buildId=4.26.0.20221201-1200^M
java.version=17.0.5^M
java.vendor=Oracle Corporation^M
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN^M
Framework arguments: -product org.eclipse.epp.package.jee.product^M
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product^M
^M
!ENTRY org.apache.felix.scr 4 0 2023-01-03 09:38:41.720^M
!MESSAGE FrameworkEvent ERROR^M
!STACK 0^M
org.osgi.framework.BundleException: Could not resolve module: org.apache.felix.scr [76]
Unresolved requirement: Import-Package: org.osgi.service.cm; version="[1.6.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.metatype; version="[1.2.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.component.runtime.dto; version="[1.5.0,2.0.0)"
-> Export-Package: org.osgi.service.component.runtime.dto; bundle-symbolic-name="org.osgi.service.component"; bundle-version="1.5.0.202109301733"; version="1.5.0"; uses:="org.osgi.dto,org.osgi.framework.dto"
org.osgi.service.component [889]
Unresolved requirement: Import-Package: org.osgi.util.promise; version="[1.0.0,2.0.0)"
-> Export-Package: org.osgi.util.promise; bundle-symbolic-name="org.osgi.util.promise"; bundle-version="1.2.0.202109301733"; version="1.2.0"; uses:="org.osgi.util.function"
org.osgi.util.promise [904]
Unresolved requirement: Import-Package: org.osgi.util.function; version="[1.1.0,2.0.0)"
Unresolved requirement: Import-Package: org.osgi.service.component.runtime; version="[1.5.0,1.6.0)"
-> Export-Package: org.osgi.service.component.runtime; bundle-symbolic-name="org.osgi.service.component"; bundle-version="1.5.0.202109301733"; version="1.5.0"; uses:="org.osgi.framework,org.osgi.service.component.runtime.dto,org.osgi.util.promise"
Unresolved requirement: Import-Package: org.osgi.service.component; version="[1.5.0,1.6.0)"
-> Export-Package: org.osgi.service.component; bundle-symbolic-name="org.osgi.service.component"; bundle-version="1.5.0.202109301733"; version="1.5.0"; uses:="org.osgi.framework"
^M
at org.eclipse.osgi.container.Module.start(Module.java:463)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1852)^M
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1845)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1788)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1750)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1672)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)^M
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)^M
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)^M
^M
!ENTRY org.eclipse.equinox.event 4 0 2023-01-03 09:38:41.749^M
!STACK 0^M
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.event [350]
*************** end **********************
^M
!ENTRY org.eclipse.osgi 4 0 2023-01-03 09:38:50.976^M
!MESSAGE Application error^M
!STACK 1^M
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFileEditor, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaIndexer, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication.^M
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:252)^M
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:33)^M
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)^M
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)^M
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)^M
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)^M
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)^M
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)^M
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)^M
at java.base/java.lang.reflect.Method.invoke(Method.java:568)^M
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)^M
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)^M
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)^M
FUDForum. Page generated in 0.03973 seconds
