cannot get remote repository refs [message #1856649] |
Wed, 21 December 2022 00:35  |
I am trying to upload/push a local repository to my GitHub at:
https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git
By choosing from the context menu of the repository I wish to push from the Package Explorer, Team>Remote> Push
And the Push to Another Repository dialog appears and I populate it accordingly to the attached screen shot..
When I press next Eclipse prompts for the username and password that I had previously supplied and after three attempts it logs me out with the following Error Message:
Transport Error: Cannot get remote repository refs.
https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: not authorized
I should also note that Eclipse>Preferences>Version Control (Team)>Git>Configuration>User Settings I have set the following:
[user]
name = rmit-s9905648-mike-little
email = s9905648@student.rmit.edu.au
[filter "lfs"]
clean = git-lfs clean -- %f
smudge = git-lfs smudge -- %f
process = git-lfs filter-process
required = true
[http]
sslVerify = false
What can I do?
Re: cannot get remote repository refs [message #1856655 is a reply to message #1856650] |
Wed, 21 December 2022 10:12   |
I don't have all the details, but github now requires a personal Auth token for remote connections. They don't allow a username and password.
I recently updated my version of Eclipse to the latest build, but as you can see from the screen shot "Push to Another Repository", the Authentication form only prompts for Username and Password, how do I get it to prompt for a personal Auth token for remote connections? Is there a configuration setting?
Re: cannot get remote repository refs [message #1856656 is a reply to message #1856655] |
Wed, 21 December 2022 11:11   |
You use the Github personal access token itself as the password when prompted for a password for your user ID. I know that's not obvious and kind of confusing, but this is how Github protects your actual account password...
Re: cannot get remote repository refs [message #1856717 is a reply to message #1856656] |
Sat, 24 December 2022 09:38   |
Thank you, but before I implement this change, there are some issues I wish to clarify:
1. For each local repository that I wish to Push to GitHub do I need to create a different Personal Access Token [PAT]; so that each project will have its own PAT, or will there be only one?
2. When I log into my Github... what do you use, my previously created Password or a PAT?
3. How often will I need to renew my PAT?
4. What happens if I lose my PAT? Is there a way to recover it?
Re: cannot get remote repository refs [message #1856719 is a reply to message #1856717] |
Sat, 24 December 2022 12:13   |
1. You should be able to use one PAT to access all the repositories for which your account has access.
2. Your account password remains your account password.
3. When you create the PAT, you can decide the expiry period.
4. There is no way to recover your PAT after you create it. You must remember it. If you lose it, you have to create a new one.
Re: cannot get remote repository refs [message #1856728 is a reply to message #1856719] |
Mon, 26 December 2022 01:48   |
1. OK created a Personal Access Token, defined a note, and defined an expiry date, but did not define any scope attributes.
2. Entered my Github username as the user for the destination Git Repository
3. Instead of using my Github password, I used the Personal Access Token that I had generated.
4. This time, Eclipse did not prompt for the username and password this time as it had done previously and appeared to be attempting to access the GitHub repository I had created.
5. Yet it failed, and it produced the following transport error message:
https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: git-upload-pack not permitted on 'https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git/'
And....
org.eclipse.jgit.api.errors.TransportException: https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: git-upload-pack not permitted on 'https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git/'
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:192)
at org.eclipse.jgit.api.LsRemoteCommand.call(LsRemoteCommand.java:131)
at org.eclipse.egit.core.op.ListRemoteOperation.run(ListRemoteOperation.java:116)
at org.eclipse.egit.ui.internal.components.RefSpecPage$2.run(RefSpecPage.java:254)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Caused by: org.eclipse.jgit.errors.TransportException: https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git: git-upload-pack not permitted on 'https://github.com/rmit-s9905648-mike-little/ST-AssInvPart1.git/'
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:692)
at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:465)
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:170)
... 4 more
And..
eclipse.buildId=4.26.0.20221201-1200
java.version=18.0.1
java.vendor=Eclipse Adoptium
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product -keyring /Users/mlittle-macmini-20200921/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.java.product -keyring /Users/mlittle-macmini-20200921/.eclipse_keyring
6. I am getting closer to resolution, but there are still problems... any suggestions?
FUDForum. Page generated in 0.05025 seconds
