Home » Eclipse Projects » Eclipse Platform » Eclipse not open(Error in .log)
Eclipse not open [message #1856468] Mon, 12 December 2022 06:01 Go to next message
Hi everyone!
I have this error when i try to open Eclipse IDE for Modeling Tools. I was using papyrus yesterday and today, when i tried to open Eclipse, this was not responding and the .log file had those messages.
!SESSION 2022-12-12 07:47:49.411 -----------------------------------------------
eclipse.buildId=4.26.0.I20221123-1800
java.version=17.0.5
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=es_UY
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.modeling.product
!ENTRY org.eclipse.ui 2 0 2022-12-12 07:48:01.360
!MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.bindings' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2022-12-12 07:48:01.360
!MESSAGE Cannot bind to an undefined command: plug-in='org.eclipse.ui.tests', id='org.eclipse.ui.tests.TestCommandId'
Re: Eclipse not open [message #1856469 is a reply to message #1856468] Mon, 12 December 2022 06:21 Go to previous messageGo to next message
Those are just warnings. If there is a deadlock, more details would be needed:
https://wiki.eclipse.org/How_to_report_a_deadlock
If it's specifically a Papyrus problem, it would be better to follow up on the Papyrus forum:
https://www.eclipse.org/forums/index.php/f/121/
Re: Eclipse not open [message #1856470 is a reply to message #1856469] Mon, 12 December 2022 06:24 Go to previous messageGo to next message
Sometimes an open editor may cause problems (deadlock). If you delete the file <workspace-folder>./.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi the workspace will forget about any open editors and any changes you made to perspectives which may let you start that workspace when otherwise you cannot.
Re: Eclipse not open [message #1856471 is a reply to message #1856470] Mon, 12 December 2022 06:31 Go to previous message
Thank you very much Ed!
Mauricio
Previous Topic:Is it possible to use System.Logger instead of org.eclipse.core.runtime.ILog?
Next Topic:Change Colors for not hightlighted text in Dark Mode
Current Time: Wed May 21 21:13:43 EDT 2025
Powered by FUDForum. Page generated in 0.03898 seconds
