Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » DRYVE IGUS modbus Comunication(I'm trying to communicate between 4DIAC and a motor drive with Modbus TCP.)
DRYVE IGUS modbus Comunication [message #1855970] Sun, 13 November 2022 05:00 Go to next message
I don't quite understand which method I should use. I knew how to do it with classic Python code (with the Socket.py library)
But I would like to integrate all that into 4DIAC.
I don't know which address I should use IW%
If someone has a great tutorial to explain me how to do it...
A big thank you in advance for your responses.
Re: DRYVE IGUS modbus Comunication [message #1856050 is a reply to message #1855970] Thu, 17 November 2022 02:53 Go to previous message
Hi Lorzenzo,
I fear we don't have a great tutorial. But here [1] you can find an example how Martin interacting with a Festo motor controller via Modbus. I hope this helps.
Alois
[1] https://git.eclipse.org/r/c/4diac/org.eclipse.4diac.forte/+/139744
Previous Topic:variable monitoring
Next Topic:How to import the created FB module from the outside world
Current Time: Mon Jul 14 10:58:13 EDT 2025
Powered by FUDForum. Page generated in 0.10605 seconds
