Home » General (non-technical) » Jobs and employment » Contract Property must be set
Contract Property must be set [message #1855692] Thu, 27 October 2022 13:39 Go to next message
Larissa Hamann is currently offline Larissa HamannFriend
Hi everyone,
I have created contracts and used the WBS Model from the CHESS download page as an example. I have created Fromal properties for assumptions and guarantees and than created the contracts based on this in the according component.
I have a lots of errors here. One says:
Error The required feature 'chesscontract::ContractProperty::base_Slot' of 'ContractProperty' must be set.
The other says, the syntax of the Formal properties is not correct. It's the same like the formal properties in the WBSI example.
I am using I'm using CHESS 1.0.0: Windows 64bit, Eclipse Platform Version Neon.3 (4.6.3) and Papyrus UML modeller Version 2.0.3.201703080851
The WBSI example you can find here: on https://websites.eclipseprojects.io/chess/download.html
Thank you!
Larissa
Re: Contract Property must be set [message #1855712 is a reply to message #1855692] Fri, 28 October 2022 07:10 Go to previous message
Please use the Papyrus forum to ask questions about it:
https://www.eclipse.org/forums/index.php/f/121/
Ed Merks
Previous Topic:[For Hire,Remote] PHP frameworks, WordPress
Next Topic:Node.js backend developer needed (Remote, full or part time)
Current Time: Thu Sep 12 03:47:02 GMT 2024
Powered by FUDForum. Page generated in 0.05311 seconds
