Home » Modeling » TMF (Xtext) » grammar for ignore string(xtext grammar )
grammar for ignore string [message #1855515] Wed, 19 October 2022 03:49 Go to next message
FeatureList:
        (elements+=Feature)*;
    Feature:
        name= ID';' selection=BooleanConstant ';' *;
    BooleanConstant:
        val=BooleanValue;
    enum BooleanValue:
        FALSE='FALSE' | TRUE='TRUE';
this is my grammar to parse a file where format is
ActSrv;TRUE;123;
xyz;TRUE;12av;
xyz1;TRUE;abc12;
xyz2;FALSE;123abc;34gh;
xyz3;FALSE;@cb98;xyp;
xyz4;TRUE;;
my requirement is to ignore all string after 2nd ';' or end the matcher and start from new row. but with the current code if there is anything after second column start with string getting stored in new name variable
Re: grammar for ignore string [message #1855546 is a reply to message #1855515] Thu, 20 October 2022 03:17 Go to previous messageGo to next message
Surely this is easily handled by emulating the single line comment?
terminal SL_COMMENT:
'--' !('\n' | '\r')* ('\r'? '\n')?;
You can just use ';' as the comment character.
Ed Willink
Re: grammar for ignore string [message #1855639 is a reply to message #1855546] Tue, 25 October 2022 03:03 Go to previous messageGo to next message
thanks for your reply . with the single comment logic its commenting the 2nd column too.
1st column : ActSrv;
2nd column: TRUE;
if i mention ";" as comment character it will comment 2nd column( True) too . but i need to comment every thing after TRUE.
[Updated on: Tue, 25 October 2022 03:03] by Moderator
Re: grammar for ignore string [message #1855651 is a reply to message #1855639] Tue, 25 October 2022 14:29 Go to previous messageGo to next message
It should work, but since you don't share your code with us we cannot see if you have done something stupid.
I suggest debugging the traditional SL_COMMENT which works and gradually evolve it to what you want.
Ed Willink
Re: grammar for ignore string [message #1855663 is a reply to message #1855651] Wed, 26 October 2022 00:42 Go to previous messageGo to next message
grammar com.contiautomotive.featurebase.FeatureReader with org.eclipse.xtext.common.Terminals
generate featureReader "http://www.contiautomotive.com/featurebase/FeatureReader"
FeatureList:
Feature:
name=ID ';' selection=BooleanConstant;
BooleanConstant:
val=BooleanValue;
enum BooleanValue:
terminal SL_COMMENT : ';' !('\n'|'\r')* ('\r'? '\n')?;
Re: grammar for ignore string [message #1855664 is a reply to message #1855663] Wed, 26 October 2022 00:59 Go to previous message
Firstly, since you are replacing SL_COMMENT, you must replace it else run the risk of allowing Xtext's built-in functionality to confuse.
Secondly, the traditional SL_COMMENT as shown in terminal is hidden. As a non-hidden token there may be a different whitespace interaction.
You should start by copying and pasting Terminais.xtext at the top of your grammar, then change the grammar name, then adjust the SL_COMMENT..
Ed Willink
[Updated on: Wed, 26 October 2022 01:11] by Moderator
Previous Topic:Xtext 2.29.0.M2 is out
Next Topic:Trying to resolve all cross-references of an EObject model from an .aadl file.
Current Time: Sun May 18 20:20:01 EDT 2025
Powered by FUDForum. Page generated in 0.04756 seconds
