Home » Modeling » TMF (Xtext) » Create and configure instances(Declare a entity and create and configure an instance of the declared entity)
Create and configure instances [message #1855312] Fri, 07 October 2022 07:18 Go to next message
I am new in Xtext and the grammar syntax. Therefore, the question might be stupid, but I would like to express this use-case:
I would like to define an entity with features:
entity MyEntityDeclaration {
description : String
The Xtext grammer to define this is clear to me, it's part of the 15 minute tutorial on Xtext documentation site. The attached file contains the grammer of the entity declaration.
But now I would like to create an instance of this entity. Something like this:
new MyEntityDeclaration A {
name = "MyName"
description = "MyDescription"
new MyEntityDeclaration B {
name = "AnotherName"
description = "AnotherDescription"
How would I specify the grammar to achieve this?
Thanks for help.
Re: Create and configure instances [message #1855313 is a reply to message #1855312] Fri, 07 October 2022 08:19 Go to previous messageGo to next message
am not sure if i get your point at all. i propose to do the tutorial.
Instance:
"new" type=[Entity] name=ID "{"
propertyInstances+=PropertyInstance*
PropertyInstance:
attr=[Attribute] "=" value=Literal // Expresssion, whatever you have;
+ implement scoping for PropertyInstance
[Updated on: Fri, 07 October 2022 08:46] by Moderator
Re: Create and configure instances [message #1855380 is a reply to message #1855313] Tue, 11 October 2022 10:35 Go to previous messageGo to next message
Thank you for your help.
I tried to extend my grammar according to your proposal (see attached MyDsl.xtext). Unfortunately, I was not able to specify the scope for the FeatureInstance.
Therefore, I can specify something like this in my dsl file:
package my.sample {
datatype String
entity User {
firstName : String
lastName : String
entity Address {
street : String
country : String
phone : String
new User MyUser {
set User.firstName = "Ny first name"
set User.lastName = "Ny last name"
set Address.country = "this is the wrong feature scope..."
Can you please explaint how to implement the scoping for the PropertyInstance (in my file it's ther FeatureInstance)?
  • Attachment: MyDsl.xtext
    (Size: 1.07KB, Downloaded 91 times)
Re: Create and configure instances [message #1855403 is a reply to message #1855380] Wed, 12 October 2022 05:30 Go to previous message
would expect
new User MyUser {
set firstName = "Ny first name"
set lastName = "Ny last name"
FeatureInstance: // remove the bad return
'set' type=[Feature] "=" value=Literal;
in grammar and a scope provider like (untessted)
public class MyDslScopeProvider extends AbstractMyDslScopeProvider {
	public IScope getScope(EObject context, EReference reference) {
		if (reference == MyDslPackage.Literals.FEATURE_INSTANCE__TYPE) {
			Instance inst = null;
			if (context instanceof Instance) {
				inst = (Instance) context;
			} else if (context instanceof FeatureInstance) {
				inst = (Instance) context.eContainer();
			if (inst != null) {
				return Scopes.scopeFor(inst.getType().getFeatures());
			} else {
				return IScope.NULLSCOPE;
		return super.getScope(context, reference);
is it intentional you have this wired syntax set User.xxxxx
then you sould have also two references there,
but the user would be redundant / implemented as in
https://dietrich-it.de/xtext/2013/05/18/xtext-and-dot/path-expressions/
[Updated on: Wed, 12 October 2022 05:33] by Moderator
Previous Topic:Modern Gradle Setup
Next Topic:Limitation on recursive objects?
Current Time: Mon Mar 24 06:19:32 EDT 2025
Powered by FUDForum. Page generated in 0.03824 seconds
