Home » Newcomers » Newcomers » Plug-in org.eclipse.jdt.ui was unable to load (Unable to run or do anything in the eclipse)
Plug-in org.eclipse.jdt.ui was unable to load [message #1854832] Tue, 13 September 2022 19:09 Go to next message
Shwetha Kolekar is currently offline Shwetha KolekarFriend
I have tried to add JDK using build path and by mistake selected some other file,
and my eclipse started to give my lot of errors and not able to do anything,
see the attached pitcher and log file and let me know what should I do ?
  • Attachment: build path.PNG
    (Size: 42.09KB, Downloaded 66 times)
  • Attachment: log.log
    (Size: 545.95KB, Downloaded 70 times)
Re: Plug-in org.eclipse.jdt.ui was unable to load [message #1854833 is a reply to message #1854832] Tue, 13 September 2022 19:15 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
I suggest you report an issue using the instructions at https://github.com/eclipse-jdt , specifically to JDT Core.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Tue, 13 September 2022 19:22]
Report message to a moderator
Re: Plug-in org.eclipse.jdt.ui was unable to load [message #1854844 is a reply to message #1854833] Wed, 14 September 2022 07:46 Go to previous messageGo to next message
The build path is stored in the .classpath file in the root of the project. You can use the view menu (the vertical ... in the package explorer view) for the Filters... and uncheck .*resources. Then you can probably fix the file (remove the "other thing") manually. You should still report an issue!
Ed Merks
Re: Plug-in org.eclipse.jdt.ui was unable to load [message #1854847 is a reply to message #1854844] Wed, 14 September 2022 09:59 Go to previous messageGo to next message
cristelle AMELDA is currently offline cristelle AMELDAFriend
If not, what would that entail?
Re: Plug-in org.eclipse.jdt.ui was unable to load [message #1854848 is a reply to message #1854847] Wed, 14 September 2022 12:15 Go to previous message
I overlooked the log. This workspace looks seriously hosed. I would start with a fresh new workspace and use File -> Import -> Existing Projects into Workspace and locate folder where your projects are located for the "Select root directory". Note the "Copy projects into workspace" checkbox; If you're used to having the projects physically nested in the workspace, you'll probably want to copy them from the old workspace to the new one.
But again, you should report an issue. The JDT development may have better insights looking at your stack traces...
Ed Merks
Previous Topic:Error during publish jetty 10.0.11
Next Topic:Eclipse 2022-09 no "import existing maven project"
Current Time: Wed Mar 22 03:26:52 GMT 2023
Powered by FUDForum. Page generated in 0.03161 seconds
