Home » Eclipse Projects » Eclipse Scout » Programmatically defined saved settings for table
Programmatically defined saved settings for table [message #1854255] Tue, 09 August 2022 06:04 Go to next message
Is there a possibility to programmatically define "saved" settings for the table in Scout Classics? So that users can choose from the author's presets?
And is it possible to programmatically switch between these settings (e.g. after pressing a button)?
See image:
index.php/fa/42388/0/
Thank you.
[Updated on: Tue, 09 August 2022 06:06] by Moderator
Re: Programmatically defined saved settings for table [message #1854264 is a reply to message #1854255] Tue, 09 August 2022 11:46 Go to previous message
Miloslav Frajdl wrote on Tue, 09 August 2022 10:04
The table view settings are stored in the ClientUIPreferences. Have a look at the code in OrganizeColumnsForm.java, especially storeCurrentStateAsConfig() and ApplyMenu. The preference key is derived from the class name of the table and the name of the setting.
Technically, you should be able to initialize these settings programmatically, but the API is not very convenient. Also, you would have to prepare the settings for each user, and they would be able to manipulate your presets.
It might be easier to simply add some custom "Change view" menus to the table that programmatically sets the desired properties to the columns. Alternatively you could replace the entire OrganizeColumnForm by replacing the OrganizeColumnsFormProvider bean.
Beat
Previous Topic:java.lang.NoSuchMethodError in okhttp3.RequestBody.create
Next Topic:Cannot create/update REST resource
Current Time: Fri Jul 18 07:35:15 EDT 2025
Powered by FUDForum. Page generated in 0.28860 seconds
