Home » Modeling » TMF (Xtext) » Xtext spelling not working on camel case words
Xtext spelling not working on camel case words [message #1854253] Tue, 09 August 2022 08:58 Go to next message
Guillaume Valvona is currently offline Guillaume ValvonaFriend
Hello !
The company I work at has developed a DSL and I'm in charge of integrating spellchecking on variable names, enum names, etc. I used the XdocSpellingReconcileStrategy class visible here. It is working like it should, with the exception of camel case words. I turned off Eclipse spelling setting for "Ignore mixed case words", but it then makes every camel case word flagged as wrongly spelled (see picture below).
index.php/fa/42386/0/
I saw on IntellIJ Idea that these words are separated by the capital letters and each substring is spellchecked individually. Is there a way to do the same with Eclipse ?
Re: Xtext spelling not working on camel case words [message #1854261 is a reply to message #1854253] Tue, 09 August 2022 13:50 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
you may digg which preference are used by spelling enging in this case
index.php/fa/42389/0/
Twitter : @chrdietrich
[Updated on: Tue, 09 August 2022 14:19]
Report message to a moderator
Previous Topic:Fomratting won't work correctly when save xtext resource programmatically AbstractFormatter2
Next Topic:xtext and ocl
Current Time: Tue Apr 16 16:33:26 GMT 2024
Powered by FUDForum. Page generated in 0.37986 seconds
