Home » Eclipse Projects » DTP » State of support for Sybase ASE in DTP 1.5.0
State of support for Sybase ASE in DTP 1.5.0 [message #34500] |
Wed, 15 August 2007 07:10 |
Originally posted by: jeffreyz.q-free.com
I have 2 years experience with the Eclipse IDE for various programming
tasks involving Python and web programming. I am now facing a large
project involving *database* development with Sybase ASE (primarily
version 15.x, but it will also be necessary to deal with 12.x).
I have been eagerly following the development of the DTP project, and
now with the recent v1.5.0 release, I decided to try using it to connect
to both a Sybase ASE 12.x server and a Sybase ASE 15.x server using
Sybases's own Jconnect 6.05 JDBC driver.
My experience when I try this is that I can connect to a Sybase ASE 12.x
server, but not all of its resources can be browsed properly.
But I cannot connect at all to a Sybase ASE 15.x server. When I try
this I receive the error:
JZ006: Caught IOException: java.net.ConnectException: Connection
refused: connect
My question is simple: Does the current DTP v1.5.0 support connections
to Sybase ASE 12.x & 15.x servers? According to the documentation I
have found, e.g., http://wiki.eclipse.org/DTP_1.5_Project_Plan , this
seems to be true. But perhaps this support did not make it into v1.5.0
and will make it in during a later 1.5.x release???
More generally, I would like to know what is the general level of
support for Sybase ASE connections with DTP. Just point me towards a
web resource if one exists - I have looked, but I have not located anything.
If I SHOULD HAVE BEEN ABLE to connect and view most of the resources on
the v12.x and 15.x servers, can someone point me towards a resource can
will help me pin down my problem? I am new to Sybase, but have access
to Sybase experts here; unfortunately, they have no Eclipse experience.
Thanks *very much* in advance.
Jeffrey Zelt
Re: State of support for Sybase ASE in DTP 1.5.0 [message #34674 is a reply to message #34500] |
Thu, 16 August 2007 17:15 |
Originally posted by: brianf.sybase.com
Hi Jeffrey...
Can you tell me which version of the jConnect driver you were trying to use?
--Fitz
Senior Software Engineer/Sybase, Inc.
DTP Connectivity
"Jeffrey Zelt" <jeffreyz@q-free.com> wrote in message
news:f9u8sb$jnj$1@build.eclipse.org...
>project involving *database* development with Sybase ASE (primarily version
> I have been eagerly following the development of the DTP project, and now
> with the recent v1.5.0 release, I decided to try using it to connect to
> both a Sybase ASE 12.x server and a Sybase ASE 15.x server using Sybases's
> But I cannot connect at all to a Sybase ASE 15.x server. When I try this
> refused: connect
> My question is simple: Does the current DTP v1.5.0 support connections to
> Sybase ASE 12.x & 15.x servers? According to the documentation I have
> found, e.g., http://wiki.eclipse.org/DTP_1.5_Project_Plan , this seems to
> be true. But perhaps this support did not make it into v1.5.0 and will
> More generally, I would like to know what is the general level of support
> for Sybase ASE connections with DTP. Just point me towards a web resource
> will help me pin down my problem? I am new to Sybase, but have access to
> Jeffrey Zelt
Re: State of support for Sybase ASE in DTP 1.5.0 [message #34789 is a reply to message #34674] |
Fri, 17 August 2007 13:33 |
--------------040208030207030708020203
Hi Brian:
Before I reply with the information you provided, I should mention that
the largest problem I have with DTP 1.5.0 is that I cannot view *stored
procedures* from a Sybase ASE 15.x database.
In addition, my original posting described a JZ006 error. This error
seems to have "disappeared" (I have no explanation).
The version of the JConnect driver I am using is:
jConnect (TM) for JDBC(TM)/6.05(Build 25828)/P/EBF13044/JDK14/Fri
Sep 30 1:05:16 2005
Is using this driver the best or only way to make a connection to a
Sybase ASE server from Eclipse? When I create a new Connection Profile
with DTP, I see 5 profile types:
Derby Embedded Database
HSQLDB Connection Profile
PostgreSQL JDBC Connection
SQL Model-JDBC Connection
Sybase ASA
I have been using the 4th choice: SQL Model-JDBC Connection
Is this the best choice?
*** Will there be a "Sybase ASE" connection profile in this list one
day? ***
I have attached a screen snapshot of some of the JDBC Connection
Properties I am using. See JDB_Connection_Properties.PNG. In case
binary attachments are not allowed for this newsgroup, the connection
URL is:
jdbc:sybase:Tds:192.168.6.40:5000
The password field is blank because there is no password set up for this
server.
I can connect to the server (ASE 15.0.1.13818) fine, but I cannot view
all of the resources on the server (most importantly for me, the
definitions of the stored procedures, but also other details I won't
mention here to avoid widening this discussion further than necessary).
I have attached a screen snapshot:
that will help explain the situation. As a comparison of what I
*should* have been able to see and do, I have also attached the screen
snapshot:
of a JConnect JDBC connection to the *same server* with another product,
"Aqua Data Studio". The database connection is to a Sybase ASE
15.0.1.13818 database named "master".
If binary attachments are not allowed for this newsgroup, the following
should still be understandable:
From Aqua_Data_Studio.PNG, you can see that this database has 15 stored
procedures, and I have expanded the 4th one, dbo.sp_autoformat. The
"Parameters" folder below the stored procedure name shows 6 parameters:
@fullname, ..., @trace. It also shows 3 dependencies. Finally, and
perhaps most importantly, I have used a contextual menu item for the
stored procedure to script this object to a new window as CREATE
PROCEDURE, and you can see lines 117-138 of this stored procedure
displayed in the tab beside the column displaying the database connection.
In other words, the Aqua Data Studio database connection works just fine
(and I believe it uses a JDBC connection using Sybase's own JConnect
JDBC driver that is included with the application and automatically
installed when the application is installed). I poked around in the
Aqua Data Studio installation and found that the name of the jar file
containing this driver is: jconnect60.jar
However, I do not have such success when I try to connect to this same
database with DTP 1.5.0. The file DTP_1.5.0.PNG shows a connection to
the same database with DTP. With DTP, the "Stored Procedures" folder is
empty, and instead the stored procedures appear under the folder
"User-Defined Procedure". In this screen snapshot, the stored
procedure "sp_autoformat" is highlighted (the same stored procedure
highlighted in Aqua_Data_Studio.PNG). Notice that the Dependencies
folder below it indicates that there are no dependencies, which is not
correct (in Aqua_Data_Studio.PNG it can be seen that there are, in fact,
3 dependencies).
The screen snapshot also displays the contextual menu for the
"sp_autoformat" stored procedure. This contextual menu contains, among
other items, "Edit...", "Run..." and "Generate DDL". However, none of
these 3 contextual menu items work properly. When I select any of them
the mouse pointer changes to an hour glass. This seems to persist
indefinitely and I must force-quit Eclipse, but sometimes after several
minutes I see the following error:
"A stack overflow error has occurred.
You are recommended to exit the workbench.
Subsequent errors may happen and may terminate the workbench without
warning.
See the .log file for more details.
Do you want to exit the workbench?"
I *really need* to be able to view, edit and then then update stored
procedures for Sybase ASE 15 databases. However, this does not seem to
be possible with DTP 1.5.0. Have I missed something? Or must I wait
for a future version of DTP (1.5.x or 2.x)?
Any help will be most appreciated.
Jeffrey
System Developer
Q-Free ASA
> Hi Jeffrey...
> --Fitz
> DTP Connectivity
Content-Type: image/png;
name="JDB_Connection_Properties.PNG"
Content-Disposition: inline;
filename="JDB_Connection_Properties.PNG"
iVBORw0KGgoAAAANSUhEUgAAArwAAAItCAIAAABU4j7yAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
dqdJREFUeF7tvT+IG9f+uD0vvMW+8Bb7wi1cpLiGW1zDLRy4RQxuVrCFDS5y YYtcyAthSbEI
F2ZJYUyasKQIi4sgXITgIqAUF7Q/CKyLgNxcWBcBbWGQi4BcuFDhYl5woS/4 B3o/55z5c+af
NJJGo/nzLCeOVjtz5pxnRvN59DlnZv4P9/3EsX7+n//3/3P+zz31xv/od81r +dn7v/S/8o7j
/G/9r/xJXvzv/wmXMUvKm/xAAAIQgAAE2knARE8VRPec//kfFTe93+RXP7ia QCmR1PvR8XQ2
df+XH3P1+/t/uVk5hCINpjgPxqp8PXMezfcfz298p8rN7+c3n84/lfJsfudH XeQFBQIQgAAE
IAABm4CJj8G/JmImioqn0aLi7Pcq7DoP587dsXP7KojL8+r9OKExfOkqY3g4 c75RrQ+94Yf5
TSlP57d+DIs4hCn2m7yGAAQgAAEINJ6ABERTTE+9X3XsN9+0VdC0i7xp/Wq+ kwfFBFxPGsQb
vpg5n41NaK6eM8yVNDgHI+fzqfP5xPlavMEqIhCqzEUjJP3gFfNa/g3eTL4I FuYFBCAAgYoQ
kFMZBQKFEJBDWupJHtgnc+fruXMyU9/Av5o5X86UAZh/5VfzzleuV+SLuryW d45c5wtd5B0p
R1PnYOzcrbg03Bs5X0zC8uVUdcYIhKcORiCyi2AKivCiQAACEIAABFpCIFAB 5QG6fDH1ikhA
rKhv6X55MHHu6XI4VkVeiDH8c+TcGFQ00yDDJ7rFkmyYeMXYg/GGQB2MQETM IJqWsO3JIKNA
AAIQgAAEGkkgcAL7hZGDmBMEWmDkICjGEkQRVF5BysgrYgwSl6X8pV/F4Qmv cTJCIbMgjTcs
kIbY+IX8alwhOCZSOfImBCAAAQhAYGsEOt+7T/4zO/ttdnaxoLhnF+7Zf8LS eewnA3TD+i/d
2WzlMC1reYkE7Qr939eq5HdXGUOgC3+/dP42qKo0/K2vvCEuDdP0TIORhkhS QS8ZOxSS2Rje
gQAEILBbAvb3P143iEDnu+npL+6dx+6nD91bJ+6tr92bUr4KyvTGl7p8ocvR dP/z6f6DyY3P
x90fp51H8lXZC/aT6fz0p/nx09m/vp/d/3Z2//Gs882s83h251FYPn04U+Vk duvr2Y0v3U+/
no7/nIkoBJXM303cH07dx8fTR/+antyffn1/+lVHlS/vhOXo06mUzz+dPrg1 Obwx/vxT98+x
qsQkGKT8dehIaP6/n6ysMNtfwZGBE9VEcRzJk4SZBksa7EGKBcM2C8Zvdnum YOsQgAAEYknj
BoXMSDK8lf2S5MGdb9z736nSeaxe33kkAjFV5cQrt76eqvLV9OaX05uiDp9P 9u+Nb9y7evLM
G02QaHv6fN67mPd+m5/9ql53n827P86OpTyd/VvKD6qIT/zrO6UUd75R6iC1 ffrlleQnzF6Q
Stynp+4vvdmvPfenM/X6+677Xdf99liVx/9W5Zt/K594qJXiqztiD+PDm5f3 PlWVmEzDP0a1
kgY1NqGNwUzsTBZvwmf2kASnJwhAAAIVJNDKgNoGpRBpkBzDv75T5f5jt6Ol 4c5D9WYgDZIS
EGNQxZKGvbvDs+ehNIgf9F7Mf34xP//P/MkvKuugvUHlHkxR3uBLgyQhJOUg te0fDsUVFOd7
Whq+PZ79pze7+Nl9fu7++ERlHSLecCzSoLzBk4bO9ItPx/duDW7vq0pEGqQo aRhVP9OgJ21K
t+WjrqRBOcH9b6eXv05G/xlf/TrqfTc8ezx88s3w3yfDW1+N94xV2BNETaah gmcKmgQBCEAA
As0lINIgoxKiC/e/tYzhRMYOZKjCcgWtCyrNcCSZhun+vcne3SslDZqMxGwR AtGF8wvfGLQu
BKJgEgxS1IDFN2rAQknDV9Mb97Q0PPClQZxAdOGXc/eZNgaTZngs2QUtCsYV VI5Bxiz0gIVk
Gh7cGvzzhpYGuW5i7EvDoOLDE3FpePJ0MvnvZHo9vXox/vnZSBvD5enDy+7X g+Ov+ne+uNxX
V1hYV5UgDc39TOKCEIAABCpLQEnD10oXTI5BJxjUO7e+clVewaQWRBSC8rmW hgeTvYOINIgW
PHnuGcPSuQEyNqFmNog0PIhIg2iBSjDoHMP8+krq8XRBzW+QmQ2SWrgjRd6f /T4QY5h8rqXh
szpJw1DlQz6LSMOdR9Pxi7H7ejr90x2+nPSfj2xj+PfRz/cf9G49GMTnP6pM g6v4BT9Tt7PT
UHr6h9o1p+u14RvXvh3X5Lcwj7KsWg1h132v7CechkFgNwQYnmgoASMNakjC jEqYHIMyBvem
FNsYxBW0MUSkwZ+OIFkEGY9QoxI/LnWG+S0xhlRpOLmvxiN0jiGMhLYxHH0a vv/5rcnntzKk
oboTIUUa5DpRffGoCa5fuP1n48nFePzfydWr6eWLyc/Prrwcw5d9Ywydw/M7 d8/27w11siEo
vjS8HOzdONv7y0ALxHTNmL1WpFfh3IrWOrqPT//SX+ckpaVh8ryn+vLgSgnE Kw/Rsmq1NLy9
uv/Xy3W2u1bH2RAEIACBdhIQaZBrJSTB4BmDn2bQxqCKyTHsf+6q6yaCksg0 yLiD6IKexLCB
NHzdUUMSZlTim3+HfmAuoPjCMoYHN6ef35ISSsNnExWO/z7WcxqqOzxhSYM3 p8Ed/Toa/3R1
+etocDH++afRk8d6VCJqDJ/+88mNz3627tCg1cFkGkQa/nGlDt9naqBo+M1a MXud2Km3/i4a
rf8h+rJWAwJpkDTM0bRz4YqP/PyF7peURdUiDcxugQAEIFASAU8aJMFgSiTN 4N7wpEGMwRTf
Gzxp8O6yIKFDpEFPeJwf/6Bu12AmMcibMufRm8Ggsws3v1Z/lX+9TIOZ03DP m9MgYxByvaWe
x6CkQUYrQm/4Uo1KmJ+pGMO9m+rfuDRM6iMNYgxqXoKa3jj+z2j4x1QVyTRI +e90IOXldPD7
pC9Fcg+/qXL+yyhbGkbqftrPFFz5su4c6Dj6x6ynLEJeKL1wvpkF+f/hs/g7 erlZ7xv9fnTh
yW/em9E6/crNPvnD1fkAVclpdg1ee+zFzML+FlWmQewv/LUfq9b/NdJaK9OQ 1s0jt/Nb5B4i
XveDTfMCAhCAAATyEVDS8KWaC2mkwZvNIPdp0MMTShq+cPeP/BJ4g5KG0dlz 74QvZ3AxA5kL
aS6tjEiDnvn46aPZrYezm1JOtDSIPUixJ0I+UOFN0gnm+gh9aaV3lUTgCp4x fK51wS/jeze9
iZAq0+AnG+T+ThW9T4OkQaShh/qyE/PYDC0NV0+HZ8HMx0SO4dY/Tm/87XT/ r6eRe0XbmYbb
8jALTxqGj8/2PpuaoYqfv5SM/eD0wZlcf6GS/xfDvb+c3X+uExJPXeex0ghv RODG2elLedvt
PfLf1wvvPR6rhb9XgTxe5+2RF61lMRlTuD3uvZNl9fCEFhSzuaAGHblnvSO1 8Onzq/sqIWGN
tgSNET7SF+vXsFqz/G1dg2rt5PSBn24xwxPWdsNuapcafq8GPvRa08nzgXNo D/Tw2ieQ76zh
eR4LQwAC7SNw9h91nyXlCkGRCQ2BNGhv2Le9QQRCTYScxqRBroaQ7ILciUHU IUUavpndeqSl
4aH66w1fGmSYXn51Plf3d1Jn8y8+VXMhH0mx7sfwdSfwhumRDElIgkGk4YYu N7U06Esu705U
OBZvkBEKGZ7YP4/ZRhV+ddTYSSAN5ilbX7mjX3JnGsyTu+QRXqpYwxMiDSao vxvd/8uZRERv
2OIvPUfC6oNR50K4uz+LPejv8eav8mwLTxoicbqfvnCiTqk58hX/yNWJBCUN 2g8Sm3tqvu7r
SC+N/0yEJp80+NUG2RR/X05/fqDMI2hG6nZ1cmJyqrGYZMzwG8lnaM2iQAAC EIDAKgSUNHwR
lQY9QuHdFFKkQRflDV+4e0e6fO7uBdKgtyXnYbkaQsYjjDd40mBGKORWTo9n nz6e3fpmdlO8
4ZGWhocz8YYbX8mlm4E0qErUrR5l2qPcvkl5g77G8uH9WLCfHtnScGN8eOPS 3Kfhs6kqIg1/
lZkNl1WVhk/UIzhVpkFPgdSZg5lMhBw9v/r58WVyHsOtv5/e/NvpjU+6+385 du5eeo/7DLzh
aBa9emLakW/2fxs65n2Z66AyEMowTq9N4BSHkAeD+n816QczIiCL+V/uT18l BEtVNYnV6dWj
vuKrLUrxpWFgDSL4VenGdP6jdrP6mc46sopnP/pFJNMw86O7spygWm/85T+X kjPQiQSRBtUj
XxqGvh9Eunn/VyMKA2lhYBXOYXTrdkt4DQEIQAACGQREGsQGRBEiyQbrTtI3 vtLSoL1hL/AG
Iw2/iDGoc6+ck+XO0DKDwXhDXBq+nX367ezW49lN8YZvQmnY/3K6d6iuq1QR 53P1vtwZWt2D
QbzB3JXBntPwtT+nYTZzj266n+tMw70b44P9y9t7qpID1znQ3vAPSTZcOn/p JSLf7t9wHJEG
aaKSBs8YRBrkNpxXv4wunw5Pv+4H10rIzEdvVMIYwz96SjLk2eEm2eAXL5DL 6IApYgz6T977
cnmn/rXzQvhKiB1E/vqVLw1yNYcs9q2XeLj/H7OwX6ep+Z++NPh1elsx0qC3 EkR3f3OxGnRj
Dnpm4GDyy1WkL/7W93RjtOWoXIVzL1atTmAcTPwFera7pHfzn2bcxPsZ/tDb E3mSYy5Kkl+t
JBZGBQEIQCCdgJYGmV6gpihK4D9/Pk0W8QYlDV+6e1KMN8jtmA7GZ794dcrp WGqQaQ3yyIn7
WhrkXymSZlCZBiMN385uPp4badh/ONs/makKzR0h9ddUJQ0yvVGukpBHTjxU 3hCc56cnnenX
d9yvwqsnRBrcB/vTw/3J3f3LfwTSIDnvikuDpEGUNMh4jMoxqCKh6+v58XfT oXjDj1enJ/3O
wXmKMRxNnJO5KuINQflq7svB2PlKfCIs8fe/neukgiTz550XAnbWk9AbSoM8 mHuuQ/5U0vh7
J/qWCS9l+GDuyIrTeUfXnNyWWkVJg4R/tUCYEtCbS6nhWrfQa0xvTywvaLP9 5k9q109+NdE9
rFa3XA0u+G96r/1Mw5Vfc7Sb37vaUfTFnLo49yKsYuj4FQIQgAAEsgicXcz3 j2Rag+cNGdIw
2/9KYvxsT4qkFuRLsoxKG2nQ53z5kRpkWoNcKyHeoKTB3P9RyncRabjxjVpY pGHva6lKzENn
GlSdai15AJWa1iDJhq/DUQltDJ40uF/eCkzCvSfSsDf+bO/y746qRAKxFMk3 SFBWj8auZqbB
SINcLqLGJvwvuyIBJ3N5aFjv2fjyp9Hgx+H9g3MZmFCTH2+fO4fyPd51Hs5V Md5g2UMYyG2Z
+NoK8MH7+oJM8+N9236sQ3v4Mzv9u7rfg5ISa+He46u9v1/Jmynbem6mKYhs zDtfW9KQWsN3
1uamE5l7oaQhaJ79V2nhj/rmE3qB0EXktZ8zGL7w7uvgPJjrrMN8+K1qpN3y jG7Oe99F3SuK
LqJl/AkCEFiPQPRrDDG4MQREGva0NNzQyYZUadj/WknDnhQJczrAe9LwqyUN X6irKCXZIN4Q
CURpv+w9nEttalj/rs40fCneoJabHNxQd1+QZMNXndl/L1UsUrqgjEHuGy2Z BpEG94ubatHf
f3bv7U0P9sb/dC7/FpMGV91MuqLSYIYn7pnrJrw0Q+gBxgwe+eWbuSMl+FVe mAUiAjF2JPrK
HSpsn1Cv097/XEdi823787nzvUk/hF/BlTEE9QQLy9d92UNL6xSxOJk6RjtM JckavrxS11OY
Nqjloxpk/9W00FvArla/Nl041LXJWI8s9k+/U/Z2/Up6L8beds0tsCSJ4vUo 2oA4Q/4KAQis
S2A91WCtyhM4+01Jg2QRRBpufK28QYq8CIoyhgXSoDsoP5KukBEKmQ6pnoUt 92bwy6dyvaXM
gtQTGm5IeTTbF2M40eFSrjo00iBK+qWWhrv7aoRCpkPK7aLtx2F/+elUyhe3 1GyGoxtqbOLe
vnu4N73rjG87AyMNMsPPJBs+04/Jrqg03JCrJ3xpMGPqOs2gSqoxGG+IqUO6 Paz+2Q6kwcTd
hpbO7zoP8VR7le6ymiKaolmNJdDUPUu/IACB8gmINEjmQAYdPG8QdbCKGpXQ JZJm+NzKNOhA
Iz9ySYW6CuMrlW9Qj5Z46BW5PYO62PLRTF0xoacyyMCEN+NKJkZ85kuDHuOY /HNPkg2TB+r+
0BNRh7Dc8i+2NPMf9yXHIMYw/cwZ/8MZ/NWXBuMNNZMG8QZbGoJMQ6ALebzB zkDkf/2Dn2mQ
4ZL8a9VwSX1/Sf/nWmcd5L6TNezI1tvcUHEs/8TKFiHQVAJPZE6DTEiUuY3m fgyJomY+6mLu
C6Am8MmEhntyq4bxmQxP6JPMbDa/9eVEnmJ142iiHoZpnnTllxtfTqXItRLq cokvVFEDE2IM
h2PvgVXqmgBVyejerdFn+6O7N0aHN4MyPrypi7q6Uq6VUOWumsogAxOSZrj6 uzO4qx9YpVTG
koaK3qfBzjTISE+QbIjlG+xBCnt4IngdH6RY91uyGRFodKbB++geWqMwpBmQ AwhAAAJrEej8
MO8+lwsoJs6D8Z7c51EVeRG8lvf9Io9YMuVQ/GDcfSbXWHqhqv9yNv5zduvo au/u5f7hMFnk
0kpTZOajc1eXz4ZiDKM/XVlXX0g4lxfum/Hl4a3+3/cGt/eTRS6tlAslVPm7 o8rf1MCEGIP7
ZtT/XV20WUNpUC5mXfsnwzb2XizKDNY6MpqqyfRrEYHKj6cyTRUCENg5AfEG GaRYXi7mMmvS
lCe/zjvf6gmM/klGQv7S+Y+xBSS1oIzBzLGVqr5Uv65TiRiD5BhicxqqnmmQ TIu6v1P4BAp1
iYRMjZTBG1OUQAQlLZFgXXjZmHm5dAQCEIAABCAQISB+YCzhC32xpbkcI3ih b/RkbvfkvdB3
cfDekZGR4K+2KJgpkPZEyEpLg7nq8u7IORjJII1XgkxOkNuRmaLiFgseyi5/ pUAAAhCoIAEZ
9KRAoBAC+pmW6YeT3AzQFLnVclDMr/afzDty7+OgyN2jzYMn1M2k9dUTNZAG MQZTAm9Y+iJY
ftUVl9bMAhAQAsExyQsIQAACbSBg7ghZ6Usu/znZP5Gpp9H7Kq06LMPy7SAw +M/P0lH3/YQC
AQhAAAKFE5AnFaiUw18r+5RLuXoCaWhHvC+kl0hD4ecIKoQABCAQEEAaCglV VFIVAkgDZzcI
QAAC2yOANFQl2tGOQgggDds7WVAzBCAAAaShkFBFJVUhgDRwUoMABCCwPQJI Q1WiHe0ohADS
sL2TBTVDAAIQQBoKCVVUUhUCSAMnNQhAAALbI1B7aXjyfEipF4Gt+gXSsL2T BTVDAAIQaII0
bDUIUXmxBMRviq0wVhvSwEkNAhCAwPYIIA1bDWFUHieANGzvw0zNEIAABLZN AGkgrpdKAGnY
9kea+iEAAQhsjwDSUGrIZGNIw/Y+zNQMAQhAYNsEkIaMOP7y1NE/py/n87e9 zmGPR18UYjxI
w7Y/0tQPAQhUkMDw+30pZTbs6tWVlMK32CBpKDK0D0+dTu+trwtBzWtsYtVV Vl2+kEheYiVI
Q+Gf4Q0rHJxoOz7pb1hPBVdvcNcqSJsmLSAguiDP0StfGuTUXrg3IA1pAVMi t3MazvJHGoqz
iipJQ79rskn6p3sxca/POtY78rLzdOidCBJ/Usv7z9IcPb1jrXfn/DrlGZt5 linltDs8P1CN
DbpWTGRN8NmFhWynazwxFQKbETDGsCtpKNwbmiMNvUPvvN35aSiv1bCC+tE5 g5cyvnB66i/g
/UmZgfnRSYXwR1axfmRgwpOGibWJiRqzsFfXy/QeqQEN65rChauotjmdn/S4 h6pNmhFdvrhQ
XZ2aqiQNJrR76mBJgxf1I9HUC4r6TxfHes+bxbxA5RycjVRt+tf4t/Y8y5T2 LO94ZC3GVGw+
PtJQuTY75+Zu4Xa6VlLjSzsA2FCpBLQxTE0xIxSxkvvwXtJsMxhhl8uLfnDm LzDf0BxpiMw8
kBkJj3TsNi+8kKwBqskKEtclYPvRPTkiEEstpGQaEqtrh/BNxYrRYeVpW/RS GuIKvrgwPLGZ
4Kx+n4ZMacj0iUyBMJ/q4fnTaKo/IhnRZSJf0P0UhffmcdcMHARZgaz3LfUJ syZeqItkU8Rs
BpGkiCx+PPCadzyQVVZqjx1NI9Iw8XxLiVSIV7+5wlYs90rkhKK2Z2o+X9w1 vyVxRF73o6gR
BQgUQeDy8f58NllcZJlUb4gmPZ3FbiFOsPTEucAbRn9c2WXxtmogDXv/nOyf uHtH6TMRw2+u
kXDrRejho+RMRj/3ENkndnrAmvlo6kxKQ5hmMLWcDrOCvb1u2hYnP6mEhZdv MCmHRk+6rFGm
IcwiSOYgRRRU/LOiY+b3gMxlfAlQ0doLadob/MgdT35kve+tq+Oxn/nQoyeW D5lNqCie+Doe
SMOq7VkqDSrj4rWhc2BGcI4HebYSabmpIbN3Yc0LupaFyPTdyxJNZAip9OxI qd96i/pSSz15
CGhjGC0tWdIgmwgixtLNiRDMcvzk8Yal21LScHfifNJ39s+Xmkr5CzjOjdFa 0jDXuuB/uY/7
hBmwyL4gYmmmYUFyIgZp6XwIfZkG0lDUsVVopsF3glAaQu8z0WUTaYhNJjC/ qmqXhFUTPk0o
VZLhzZbwx0SCX70XfkT0zwWZ0uAlNvx6lrcnUxpsWfGlwZ8dkq/XIfms3oU6 Esw7yZYGLwmR
hcjMaCnimyWVQCAgMHi0L3MflxZZbAE0+ZDnQapswJ0uLYsHKSTZkGdbzZKG 2OxFe8ZAoAgS
pNVrNZ8gZTTBxK4F0uBtIrH6gkxD1irelAszVmINT0RmRRQVTKtSTxMyDcE8 hpN+4dKgcvIp
0mDP07SlQb3vtSGWzQzaljHBIvxK7WcaUqVhUXtSpCFshB+GY9kOy8P06qFD RHodvp/Vu0Qe
JcyyZHYtgSioJPgL9pAnbLBMTgLaGwaLy2JpyLkhsYHpdLK4FDWtoUHSIJMe 1TzE4Ft7dKJA
eL6wpjIEb8ayDlnSYG/CHqGwhzAS0TlsVWwVW1y8mRbaIyK9qEqwL6odtZKG ZXMk5Uu8PSHA
C6JZcxpMsA/nNMS+Qy/8Zr9IGmL1xK/pyJ1piH0dX96e7OEJ60wXl4Z8vfak QcJ/Vu9WkoZY
11JOxMFkjiZeepoz8LDYNggob5j+bIq8TpaiNpqcCDn49efp27EpRRmDGjRp zvBELKx5GYVo
5qCo0Ec96xKonDSkTANcdvVEJA0euzJCR7slV0/4y6wwDLFIGiLzLUwgvzi2 hjmC3LuZ0xD/
ru9fDLJ0tkE8wxE52UUnQi6QhlyDL3ZtyZpN7+IzNqJ5C59DdCKFdTWsrsSe xBBKEuMUECiU
wOBEvOFcirwoShHy1KPSD0UbQ5OlwZsCGRtuWDfUsV5RBKojDdZNGmKXLcQn LqjP58L7EERT
6HZGIRwpT19m4dUK1tyFhdJgzX8Mmu6n6ONXT+jrQu03V7h6It6etTINCZiZ 8K2RAt/M/O5l
ScOirgWDSlYl0ZtnWLflKDRm5Dm/s0yzCfTFG96eyb9ldtNIQ4E5BtP45mYa iopy1FMogepI
Q5mfXra1nEB0TsPy5YnrEKgVATGG8qWhcGNAGgqNh1SWgwDSQDhMJ4A01CoE chi3lkATMg0S
hyg1IpBDLdZfZPVLLrnWrhoEkAakAQJ1IFB7aVg/vLBmEwkgDa39AkTHIQCB EgggDU2MnC3u
E9JQwlmDTUAAAq0lgDS0OMA2setIQ2vPZXQcAhAogQDS0MTI2eI+IQ0lnDXY BAQg0FoCSEOL
A2wTu440tPZcRschAIESCCANTYycLe4T0lDCWYNNQAACrSWANLQ4wDax60hD a89ldBwCECiB
ANLQxMjZ4j4hDSWcNdgEBCDQWgJ1kIbbk/0Td+9o0uJQSNfzEjDSIP9SIAAB CECgcAJIQ95o
xHK1IGCkgR8IQAACENgGAaRhG1Spc2cEGJ5obdaUjkMAAiUQQBp2Ft7Y8DYI IA0lnDXYBAQg
0FoCSIMVuV6eOsHPo+E2Qhp1bpsA0tDacxkdhwAESiCANHhRbPJTx3FOA1MY PgpfbzvOUX+B
BJCGEs4abAICEGgtAaTBBKxJ77DTe5sIXm97ohL6RzuE/Hp4enqof38pq5gX 2e+bVeI19HqP
/LdkXX4KJYA0tPZcRschAIESCCANOmSp0J5MLQxluEI5gTiF5CFkwEItpt1C DWT4Lw57k6z3
56k1eHWqSmTdQkMmlSENJZw12AQEINBaAq2QhuDafYmpydeeNCTjt8or+EHd WEXwTuzF0vcD
L4nViTQUrTlIQ2vPZXQcAhAogUArpCFHYJKUQGJ4AmnIAa5qiyANJZw12AQE INBaAq2Qhjw3
/EmbCJk2uGByAzkzDanDE3b2gkxD0dKBNLT2XEbHIQCBEgi0QhpyBibtDf6P ueQybRrjKtKQ
XYNtHjnbx2I5CCANJZw12AQEINBaAq2QhjyZhhzxiEVqQABpaO25jI5DAAIl EGiFNNQg1tHE
ggggDSWcNdgEBCDQWgKtkAYyDQVF5BpUs0VpuD7rHJyN3k+2eLLY0iYujs2o W/eioMav3c61
V0zFXmxtW92zVA6BphBohTTUINbRxIIIrC8NEoH8CS2dp8MUM8gfovIvGTuP JFdcu6qw5n7X
uXN+XYQuBI1Zu1Vrr4g0NCXkbNG5QVQKgVZIA5mGgiJyDapZWxqsyNrvnvSr Ig2bnwWUDB0P
Nq9HakAaCsFIJRCoM4EaSINze7J/4u4dce/EGsTsnTdxA2lIRNYw96C/qdsh 08tJBN/g5du8
99O9GJ4feK/tjMXo6R1/kcT3fivJ4cgIiN7Q+YksfjwwG40EftmWbmpa87y1 ImmG8JIgqTxc
IFzdr+3guKtbHnQhOpxh9evk2G+hNeoRa499WlzQwUhH4i1JH1KJ1ZZegx5I CrlJ4z2YmkCs
2QVlYuocCUgAQCAngVZIA5mGncfy0hqwtjQMTCwJcwx+bA6+YXvSkHj/vYqm kfi6OAkvMwwi
mQwlHN7qoSJE33k/keZ5y3irpzUvddZC1HX8doYbVTYj7VHxVcdONQHCfxGb w5FalSyvFkti
CQZEFnZQreh1Ld4SIa8aE5O5RG3JGvzGSIXdk2Pd5X7Xcy8Lo+ld0HFCPgQg kINAK6Sh4Ijl
P0HbPJZi0Y99T8lly8b/vsm6q26rQTeNWFsaPMs2cwa9IGp9R4986U97P/bF OjllMvn92Kxi
G0YgDcHqwV991Ric+GkPuxVB85Kf+dQxhdhG7dUXjEEsqMrunWqYFelzdjBI DESUy5uQEeRp
OjrJ4U1HTcWlN20oDU50dsHsTfNvEmyOs2TOb2AsBoE2EGiFNCzPNIQ3cVIn vIU2kHbD6awg
nXwmhb2ktdHOT4nBly1JQ7Sn6umdZkOLm7qGhexolU2lQYUQ/aU5mS1Ihqhk 1F/wTjAbMVZz
3piqE+zmG3NMNbI2Gns/K2SaHH5SCLIILBWdWBjO20F/NCFNGsJz8dLatDSo HMOFYaW5Xeh8
A9KAIUFgYwKtkIbl8Sv+mIlsb0h/HmbGFhZFYls+hqfmBpQxpdjGTaazXKT1 0qC+iUairJUG
X/x+6vBELKluhSv1pTmShwivbvD+lBHbTLLdnyeR1bzEVRLpmYO0QYGYjqRK QzCdIv6VPdGe
yLwKb9JASgdThyeCyr2xD7tTCVwpwxPKD7oHdwyr0dNj4RaZlWJ7D8MTG0eR Nny9po8BgVZI
Q65Mgx2h7Qjqz2lTT8TWz5Lwfg57w/C20/phV8knWHrvTHqHfi1hRkGqSn8Y t1n09CeVAOg9
8lb0kh9hniDY4umprvz0pbeV8FnekZb7PpKUhkimIdrUlM2ZJiVbvlzMylli 7UxDMHvRG9GP
TK9zgvmJ/ii4fxiE4+KR6XVmhoQ9EdKbMyFv2gl2c77276Pg/WlxSiA4xdsj Av70yZTbSGQN
N4SrB9MPozmMpDToqRWqX8kxgiQuOxQt6GBkxdgEz+gwR1BhrLZkDV66yJ/e GJhHKlikAWmA
wCoEWiENy8NVPJSaiG7F9cVfxGWWg6QKMqUh6hN+a4ZGCMIcgwrY4ciIDtje r1K/cppEe9Qy
2h7UNAv/RSw/YdoW/KwwPJG6ucVjN8tJb3uJtaWBbxJVIZAmK1Vp2yrnVtoM gUYSaIU0mECS
9a8KY6nSkIyvsSXtBexpAcFieXL+ZlplzDmSGzL1R+a++dMR7IVTciSOFo6c mYboAzyzNrft
yL9B/UhD7c9TSANqAoEKE2iFNCyPQTFpiM0NTJ1qEHzLTyrCStKgKtff6VPb YDad1Z6klARL
msRD0oeWDE8knvqd2vflQHe2BNJQe2mo8OkSthCAQCukYcU5DWrigh4XCF5Y ITAteaCeqe1l
ArzB/vAd8y0/OX1S3glGDaypD5HhiSBD4C2QaM8CafDX9VqyUqbBm7KQvbmd KcHyDSMNnNQg
AAEIbI9AK6RheaiJZP797+hesA9nPnrh34/H3qQEmU3w6FRdtTifqwitf7x3 rK/1ZmHr0spw
yqE3HSG6OTMR0htWyBp0yJIG8R1/BmXQNg/C0kyDv65q6oLxl+VMd7ME0rC9 kwU1QwACEGiF
NCzPNOwmwLHV4gkgDZzUIAABCGyPQCukofjQRI1VJYA0bO9kQc0QgAAEWiEN ZBqqGuKLbxfS
wEkNAhBoLYHpu/H07WhBmfx5ZZfokmNZfSm6VkhD8aGJGqtKYG1pePJ8SIEA BCBQIwKxAK9C
/rvxk2eDm0dnzt3Tlcr+gyfHP/Td6didJu4qG72gqRXSQKahqiG++HZtIg3F t4YaIQABCGyH
gMhNXBreKmP417f9q+vEw4yWtWH81pUVZXUyDctQ8fdmEUAamrU/6Q0E2kJg 6s7H7+ajP+dX
r2fD13NVrmeq/DG7DMqr2eDVbDJVTFKlQXIMw9WNwSCWFWX1mTtd7A1kGtpy RLakn0hDS3Y0
3YRAwwiIMUzfz0UI5IVX3iqHCMrVG/EJCe1z0YgMaRjJkMSaWD7OZ7OZrI40 rAlw0Wrmxs9L
nqCtK0jeFGELzYlXWeZGt7StDapFGko4xNgEBCBQOAGRAzGGiRhDmiuILihj MNJwnSUNYyUN
H+drFDGGmesiDd5uXT6nIfpYh/C2jCnHhf1I62WHzeJnT1gb9W76tEGwDJuS vB11+AiJop9O
uWGDs56msZjbQupIw7KDkr9DAAJVJCCjEibBYGcXRm8CUTC6kEcaZvOPqxVl DB9c9/0Uach9
ZNjBT0eyTG9I3hB6wUYWBT9bPoan5pbSG8Zg05KkNAR3lvSelpkby9IFN2xw 1urVl4YNO74U
LAtAAAItI1CUNCgDWOMHabCPt1yZhtRHQYZfhc29pdXjGLyfw97Qv2m0dx/o mHmEz70M7xht
3UbaevC019boYuGmdXpAV95TN4f2f/XaYT2YympbxmMtwydjpVUV5CHCbip5 ikOw39GP0Mzo
+KLWpvpNYDxehVlAdJdjQPz9XUymIZkEip2/ipcGv7O24QU71H64eeFn0qy+ +MNw1kEbbDs4
QlKOmfC26LEDO/GkVk/Ns/J8fgOiT5CPHn6pfl/83ikcOhVCIE5Ahh7UwIQZ m3gTFivBkCvT
sIYwkGlY/XCMn2VMRLfi+uLvvnJ2iz3b2iy/cC3v8RB2PAibET4sSj3PwlQe nh+TDbMeLpWd
abAerBWkUhIbmqvoZSVacmwrVRoWtdbfQdFooXwok1uiGRkJoSKkIS0JtHVp iGSJ9ENMwrGk
4aOix5Xs7qSGWBWwMzcqh645QryDU71MSnAUWWzPGkE0B0ny+PEe45JBILZ8 ntlFq58SWAMC
JROQmQrBwMT9r87M68AY5J3LfMMTa0qD67pThiei3z5NOEn+q5ZKlYZkSIst aS+Q/YU79pir
+IFovk7Fhifip8Xog7OzYq2pOikNsQxE2jnaWzH1Cd3hlAid58jIK0SerZU4 rVt1WKEoGa6y
pGFxly2mBUlDLF7aIqWV4qVI4enpofd4MvMU8uBxZcFX7fCd8GGnkVXiB4MH RDZnPTUtWCiE
EEs++dNy9eo6wWNN1A3XCuq0M0mpaTB54FlaA7yWpMn0GtIQHKv2YWD8W5lr dgNStTjsu6We
off4bY7RsNcqOUSwOQhECcg1EUYUxA9MMZMfxRWCd3xvWDQRch1pkLEJpGG1 AzL7NBS/R0aw
pDr7WEMDa0uD/S3Nrtx+xGVqqLZ7mOUBKT6U/sVukTTYAzdJbVrc8dQG2FEw tfIkhyy9SOzm
IqTBf0aonQTygtl8HmSV/L0ff/i4NClcxpMPnSpIjbXRDgTOlPItf2HyycxW Cb67mzYotsmN
xjJJqTNprGG4lO/xdlIheB2ukjac4W9luZ37Y0/ZeY4Fih+Od+jjKsiIeHsk ScMmttopg6Uh
UDCBQBpi3mAbwwrS8MGVuY35i+QZ5F6QTIT0duqKcxqCs7OV80/GOev0Z6X9 vSARvhN+xYx+
eZXVg5gUERGzWFqECONrsmFhRj0ew5aE2zzDE7FpoYltqTNvRsejfcn4Ym29 ncw0eDUnupzs
l66mEGnwGmQngfx448WheColNtFET/XwZsD4+z2ZLEmec2LdX+CF+VM+CxJF pv4UklHViMfv
VGkI2moP7mTvWe8vuqqk8mbsXG+lLPNIPkreVz0vcZLcBYs3VHBQoDoILCIg d3AKpjJIgiFw
BfNCdCEo2fdpUJdcyqWTqqxiDOrSCaRhtcMzcjax8qL2+0H4989N3qQESUY/ OlUzGKwEtfeO
dUoyC1tfwsK0sD1xLFws3HSYi45Mb4wNOgTT1vzGZJxhF4xfpIS36ERIEwv1 t1j9k6fjXlha
PknTCmCp3GL7ogRp8IwnyBaIPFlZ7mQqKJZ5CuNiYlgn6+j0OpUWd5OasjjW ZvlHrpyNrQXJ
kYLFKZPssZVYUirwlUiTTOUZ5pFqOcmehhVKY3RtiQ9v5qdjtRMHS0OgMAIi Der2TVYJvMHc
IDL0hsybO2lpWFEXzPJqRgOZhmBnLs80FLbfqWjHBArINKQmgUyEC7TPinPh TFVfI4I80+lP
RvNMHE1LXMVo+dfEpk2EXJh8ygycyY2mDU8kxgJEXsN7h4QX7Nj+pDtmZulq j7QuhUibQRkM
oCQTZrY0LCLgw4pLRuZsStPCU9Fob0fkzVft+CBm860kcPlqpiYxJLxh+MbS Bck3/CFl4ZwG
Wxpen3ec7qV5J+u1kYb30+k7hidaeeS1vNMFSIO+fsT/safjWd+hkykoPYIe TcAkhvnT1tL7
K1gy3Jw1rdKaJ+vPcQyuwl00/zQ++9JPFFnNMJE+kQYzohOds6nWSl5gmZGd Co/CaNdSU3qR
N0PhSCFgqs2qJDk84S0cnXtrJ70Ynmj5+aJK3R/8Vz1ywkx+tNVBSYOkGXQZ XM8HSMPCveY4
N0bO7cn+ibt3tPJju4KayTRU6aOx3bYUIQ0ZLSz81ljbJUHtEIBAnQhsRRry DVWoSyfINNTp
YKGtxRHYnjSEU/GLay01QQACEDAElDTInRiCZ0yYJ034OQaVaZA0g8k0vMo9 PIE0rHd4kWlY
j1sd19qeNNSRBm2GAATqQkCkQeYrJO//aM1/VMYwkMdkL5QGyRmsUWRCw/St mUfJo7HrcsjQ
ziIIIA1FUKQOCECgbALyfEuxAbmcMlZk2mNYXiljmLzLyDS8G+8/eDJ8NZLw v1KZvB1P3owu
Xw5ldT0pcrKgOPfkCdoT55O+s39eNqMc21NzGvaY05CDFIt4KT5938/FB33q X58811cB8AMB
CECgDgTklBU/lb0bH3/fv/+o17+4HL++WqFcX12+uLz/sNf9oa+ekI00FHwA +HcpWPgEbb3N
Dedm57qkPl/nNmxJvo1UYalNMg3yIaRAAAIQqAuB9O8/Pw1uHp3JQMNKRXIM 3afKGObyH9Kw
fE5D5CKu7Odiq6i48LYzsbAZhOp4zLYv6vOv0/MuJbeqWEMaoh1Z+AioKoT4 4tuwtjSskZxg
FQhAAALVITBzJzN3qm7JoGN/evk4m9vFLGa9IzUgDTkiU/x2e9neELlafVnN mdLgr7g4AbCe
NMSe5mA2tbQly7pSl78jDdU5hdESCECgeQSY05A2jmCHWD8RoJ9kaD3I57A3 VM8vtm6AEzOP
8Ka56Q8STI5fxB+TqCqMPkoxs2HZFhK5V2C0JWFawn9KkPeMxG0+iHnL9oE0 NO8kRY8gAIHq
EGiFNCyPU/Hv9MEN8K0b3mXdvl5qD55qGLsn3dLv91mZhqxHKXrLZ9/8f4Xh iUQlet3lEzWW
09zlEkhDdU4utAQCEGgegVZIgwkkWf+mzVj0H74Xe0JgbG6jHaHXezR2TBoW Vxg8DzBpBkGY
zhrRSOpLll7sMuIXsG2koXknKXoEAQhUh0ArpGF5LEoG7+QT+ZKTA2JPNcwc nsi+jCI+l8J/
9EBkTMEfQLGlIXXiQsxp7AanSkOsksUTLJZDrMQSSEN1Ti60BAIQaB6BVkhD rqsnkg/f0zMY
4un6tBGH4KmGwRN9wnfChwalTRRIeoaOvPHVg8cJhsMTGeMIeTIN3mOHmvnE v1ZJQ10uDKOd
EIBAjQhw9USOb8CRXL31YMPYeEH0q3ziqYY62OufjjyNN5qrSHuQYDwDEa9w wdaTf4olQmID
FpZMhC1ZMBqSg1k1F2mbNFRzL9AqCECgpgRS7hkVvW0DmYaa7lmanU4AaeDI gAAEILA2AaRh
bXSsWEsCSEMtdxuNhgAEqkEAaVD7YfmchmrsLVqxOQGkYXOG1AABCLSWANLQ 2l3f0o7vUhqu
zzoHZ6OFt20vdio1D9lq6VFOtyGwNQJIw/JMw+jZHZm6yL8VJ5DzM7K2NAR3 95SDoXuR/WTY
BWaANOTcSSwGAQhUlQDSsHzPSJD49OSKUmUCso+W70i9xPrSECQJJPYv8Aak IeeeYDEIQKCG
BJCGXJmGKsdL2iYEJAuS89NXgDTI+IJvBqOnKgulf+6cX0v6YXh+4D9u5Okw /le11nHXW8As
P0nUYL1jNEU7irUJ8463+uLhDIYnch4VLAYBCOQk0ARpcG5P9k/cvaNJzj6v uhiZhup7SamZ
BjUpod91jgf27ISLY+ekr0J4aqbB/NUK9soVYvMbwmW8mgcn8sLaUFAz0rDq Z5jlIQCBgggg
DfkzDaP+VFOfTv79/cQ2lKvnevAi9U15/7lZTf+8HscD8OK/FjgsIs2Tlpt2 mhf5S6Rr07P8
K+ZfcpPmlZ9pCGJ5mAZwPAmwpSH21/iftBzEaxBLkB/fSOy/2u/nm01JpqGg 8yTVQAACHgGk
YfmhEMk0mNhmx10dUJU3xN7Ugfnfv7tiGUGUPXsdibiL/7pCUM8Tm9dwhaBa e12xnFWdY9vN
O7kqO9Ngwr/9jd9OA4TDCv4gQrB8ZGLE8SC1Bi+TodVhs7mTSMPyjzdLQAAC qxBAGvJnGvx0
Qkwagu/usciqkgqSnHD732d9p8/4a/i1XhuGrrb/2turgZ1E3onkOYItjq/8 Q+HquZ8mkadU
vJ6GKQdvgYwNpUrDiVQ7PQtb5a8br2p65WdYEpkY3cJIDYub5/VIO5af7ImK SLlzGlQyQF1A
YUX0cLhBeYCfQvAVwftrbHkzYJFYpvt0qGcqyPQIcQ5/W3ZqgeGJVc5xLAsB CBRIAGlYDnNJ
pkFFLz+OhpX5cdFKM8QzB0oOkql+FelNlFUxUswjyGSYkQ5/cMSLxN73ft0A E0c9d1Fh2Fsm
8n6wQI4NpUmDalWsDar7yTb77qLGX6RtiRba/bIHTbz2py7v9TGWsJFel5Fp CB+DHk5CHJz4
0x5PjoPwb97sPB3G/5ocy3g/SdRghie8GrxJEsGmkzmMheMUZBqWf7xZAgIQ WIUA0hBmGsy8
+uS/8i02jPfJ4QlbGoK8ffpi0ZRD6nhBfODD+07vTUFIHRxJzLFQQTpZeWzS QJ4N2dIQHFXJ
iRGLq1K64PafR2aBpLQw2bzIcWy0Q37SZ1SUkGko9rZL5dSGNKxyMmRZCEBg OQGkYTmj5ZmG
FEUwX5R1vMwcnkj7a55Ynpw8sUARktmC9GkZaXaSPjxh5zPSXseVxZeG2EyI WJsXOE1kJCJd
HUrINJQT5ovdCtKw/OPNEhCAwCoEkIYw05DFLZJpCAYIwhDoJ+fTZguuPhEy LdW/IIERJvOj
gxFqOkVieMJ8TU+sEo6DxDaUUxpShyeCqsIBlIzhkmD0JKN5Xprn+8nV7yP9 OmUuCJmGVNtA
GlY5GbIsBCCwnADSsJyRzjQEkwqDyQrBin4uIZzAGMmih9P35O3EJZcpf02b CLlkeCJ2wWcw
guC30UxuONOzKRdPhIxsKK802JebxuZFWihsPsnJpIuapy9zDXfBfOLZQzjc Q6YBaVj+SWYJ
CEBgYwJIw4qZhjxXD7JM6nSNbWIh05AlDfIJp0AAAhAokMDiUVTn3sy5O3E+ 6Tv75xsrSvEV
OM6NEXeELPiODptH99KlgUxDsZMhqA0CEIDAegRaIQ3miolccxo2D6jUsAUC ZBrW+3izFgQg
AIFiCbRCGhZnQORbbMWfCk0LyTQU+7GnNghAAALrEWiFNCzONBQ/qEKNuyOw 9lMu1/v8sBYE
IACBVhFohTTsLoSx5bIJIA2tOn/RWQhAoGQCrZAGMg1lh+7dba9V0lDgfGmq ggAEIGAIcPXE
7iIYWy6dQNukoXTAbBACEGgygSZIw97tyf6Ju3ckT6he82d5puFtr3PY8zcw 6R12em9X2VZk
9VVWZNmiCSANRROlPghAoEUEkIacO9sSBQwgJ7NKLoY0VHK30CgIQKAeBJAG tZ+WZxrk7ss/
dTo/6VzDy1PvhdiD/xBjlXjQMtF7JG+dDvXy3h8lRRF4RriKWsZaRS17+rIe B02tW4k01Hr3
0XgIQGC3BJCG3PxfnjqPVKAfPjLRfXiq5UD9GCfQQuAFfvXa++vw0enQkwZZ xVtAKYXUZq8i
9YcjILlbxYIrEkAa4sCCo7fAw6/kbFzJm1vxkGNxCDSJANIQZhpMOEn+6+9v YwkyTuEnCbxM
gvlfYAZmceUHJuUQsYrgvGyswj7ZceIr5YO1tjR0Ds5G7yfetOHrM/Wr/Bse A3fOr/VfzZ+C
JXf6IuUpl8nDrAbSIB+6yIdNfvGyffbnK9fxMzwN3ch8SKOfU387kfojNds1 qLyjWSM9+5hs
Umz5tDbL1xL/+0OihbGWhFTMLKvk8nneyQWOhSBgCCANKxwJw0ed3steR+cb vOyCvXZK1PfV
IXleRhpWAF/kogVLQ+AHSiCOB9WXhiTLGkiD3+gssc4n3N6IoScNSkS8vGCQ 5Ht56g8Ryic3
ZbJztAZjDP4XA9VGa+ZTauIwvnzKgS3G0Hl0aqZd+0lNPdZpTjtxabC3nrJ8 soZldRb5WaOu
RhJAGlbZrfpbgnVaic5CiKYNTs0ECHMeEdVQZ4G04Qk791BgfniVbrVq2W1J w/t+N0salE/4
eYhyEw/xTIP5mmsOs3B6jX5HHb2np94X+iBeBt9T9aGuVvH+FJmyow5y+3Nh Dvh4beEq6ZXY
TfIbYG0xxdRjXYhNJPL6GI394YfUGl60hxq9D0P2FVLWx1x9i3hrf3qWTJdO LB//5HkTp8LR
zGiqMt4juwvyt8SAaa53WvXpp7MFEEAaVoIY/ZSmnHaDyzLDs63KWy6cCOld yZnv29JKzWXh
JIFtScPFsWOyDsnhiepIg4k6UX+1ZuRYQqCWsVVAgwxCeGzKjvzJn/HjvYjp RcyGzcLxSpIx
L6IpCWkIFdzqgjWRaLk0BCE/oQgLPowR7QiHB+zvEma8InFVdnhOSJ31HE61 TkpDEP4jFhU9
yUTUx8BMitFiVeKEAYHlBJCG5YxYokkECpaGIGrY4xTVn9OQnEwTeyc+Ryd2 CESn7Kg/etHI
y34na0vmNpLzfmKThJKHXbLZZhnLhKLjBYkq4g0LNmnn+dPHJry6UnMVvgD5 yX89CSM+oBC1
osi4htSdmLdx2AkmU0eyCCmfRtPgPIqANDTpZLabviANu+HOVndFoGBpCLIL Zmyi+nMakjMY
Ut9ZIg1m70XUQcdLPyalKkjw5TvyPT4672fxYbFEGlJaFa8vNYUQb8/CW7el D3DYo5Bmm8kB
DjtgL7xB3ILhiXQ+pjaGJ3Z1UmnXdpGGdu1veru2NHSteQmjp3eck35kJEKG J6o/pyHypTw6
GGEFTn/a3aLhiciUnbf+1337IgJ/SCK8uth+R8+iiFZiDTcEh2kkGx+bfRzm A9QmUipMjG6E
3bc/B6qb1rUPiTkQsZSABUpNWjRTl7xMQ3TExKwYGYWJLR/5a9gmfxMpkxZt IMG0zXieI5w4
yURIzniFE0AaCkdKhZUmsLY0KEWIDUZEpy8okxCxuLCvw/Svp6jIREg7agbX /pm5+irw+D+R
C4P9qxIjEyFjo+mJ79ZptakrCc1ov3d1QKKS5FqLpMG63HFRhaEEWDMx9bTN xNWP9gLeVZRW
yFfZg+CObd6E6GBMwZ656fXSm9MQqSF1+cgVEJ6CeLsgQGTNiLQTNv4eS8yo COpM1JByWWal
P7A0rmoEkIaq7RHas10C60tDuRc+FPI025T7NGzvHmLbq3m7RwS1QwACKxBA GlaAxaININBi
aTBfOld81lruXR5kwnOvwYIQgED9CCAN9dtntHgTAi2Whk2wsS4EIAABRQBp 4DhoFwGkoV37
m95CAAKFEkAaCsVJZZUn0DZpkE84BQIQgECBBBbPuHLuzZy7E+eTvrN/XsGA 4Dg3Rnu3J/sn
7t6Rd2fFCraSJlWHQKukoZDZlFQCAQhAID8BpKE68Y6WFEAAacj/4WdJCEAA AqsSQBoKCFRU
UR0CSMOqpwCWhwAEIJCfANJQnXhHSwoggDTk//CzJAQgAIFVCSANBQQqqqgO AaRh1VMAy0MA
AhDITwBpqE68oyUFEGiVNBQ4X5qqIAABCBgCXD1RQCiiiroQaJs01GW/0E4I QKAWBJCGWuwm
GlkYAaShMJRUBAEItI8A0tC+fd7uHiMN7d7/9B4CENiIANKwET5Wrh0BpKF2 u4wGQwAC1SGA
NFRnX9CSMgggDWVQZhsQgEBDCSANDd2xdCuDwNrS0Dk4G72feNOGr88ivwbv V+yFfLw5ECAA
AQgUSABpKBAmVdWAANJQg51EEyEAgaoSQBqqumdo13YIFCsNo6d3HPNj8hCS gfB+v3N+rX89
ODs/kbeOB9EshX5T/XQvVPYirMcJVjzuHpgFhufeC53niG3Ce0evlchzJDMN k5/8Bh725Alv
4a9Op/d2O8SpFQIQaBABpKFBO5Ou5CBQpDSo+O3ZwOBEXvS7gRyY8Qsd4I0W hMV+8+LYs41g
AXnnpK/NQHuA/Bq8UF6S2MRK0vC213FOzYjF8JH3wmP28tR5xFhGjgOIRSDQ bgJIQ7v3f/t6
X6Q0qBBuZRHCHIBJIhwPUqc+2G8Gr+11jW0EqQv7RXITC2dRJDINw1PVMEsX lEb4Pzr3wA8E
IACBBQSQBg6PdhEoVBpM/sBXh6Qi5JSGIK9g0gaLpcGej7ls3mXGREhfHZQx +KMS8hppaNdH
gd5CYB0CTZAG5/Zk/8TdO+Jr0jpHQNvWWVsaumaYQMdpNQVBDyJ0n5rbsMu0 A/mrsofIYER+
afBVQNW8QBq0oKSNd+Sb0/C2d/qT+ZhMeoed3stQFNTkBqShbR8G+guB1Qkg DaszY406E1hb
GqwZiP60Ry/HoNL7HWMPWaMMsTkNQbbAt4qBPy+yc3K8KNOQ3MRKcxrmJseg G6ztYfjI//XR
KZmGOh/XtB0CJRFAGkoCzWYqQmB9aVg2FpD/0bGlLcl9Gipy1NEMCDSGANLQ mF1JR3IRQBpy
YWIhCEAAAmkEkAaOi3YRQBratb/pLQQgUCgBpKFQnFRWeQJIQ+V3EQ2EAASq SwBpqO6+oWXb
INA2aZBPOAUCEIBAgQQWz8py7s2cuxPnk76zf76Nc/iGdTrOjRGXXG4IsVWr t0oaSptxyYYg
AAEIGAJIQ6tCavM7izRwaoMABCCwPQJIQ/PjaKt6iDRs72RBzRCAAASQhlaF 1OZ3FmngpAYB
CEBgewSQhubH0Vb1EGnY3smCmiEAAQggDa0Kqc3vbKukocD50lQFAQhAwBDg 6onmR0p6GBBo
mzSw6yEAAQgUSABpKBAmVdWAANJQg51EEyEAgaoSQBqqumdo13YIIA3b4Uqt EIBAKwggDa3Y
zXSS4QmOAQhAAAKbE2iCNOzdnuyfuHtHk81xUEPjCdQ403B91jk4G63yhG4e jd3445kOQqBk
AkhDycDZ3I4JrC0NHSf4OR6sErkLuwQLadjxscPmIQCBOdLAQdAuAutLQ/At /+LYWfEbfzHe
gDS061CltxCoIgGkoYp7hTZtj0AB0vC+33VUsmH09I6ffLhzfq2e1BK+o60i 8msQ8uWFXt19
Pzw/0C/UO+bH//Xg7PzE+jXIcRhZUct7W1ysIwxPbO9AomYItJMA0tDO/d7e Xm8uDUoFYpkG
yT2c9HUs90YuBifHg9ivlmp0T467FyIN/a6qRxTE0b9qyfDq8d5Ry/h/VfUj De09cuk5BCpB
AGmoxG6gEaURWF8aYl/3IxkCR2uECvBetkAlEmK/TgYnKj3g+YSRA/NvoCDG M2Lv2H9dcViE
TENpxxUbgkBLCCANLdnRdNMjsL40xAK2PUYQmW2QqQ6SSOhemOyCHpi40PkG pIFjEwIQqA8B
pKE++4qWFkGgSGnwNcIbsLg+6z41d2UXJ7hzfhH9VSY9yAIHdzp6mdHTYxmk 0DMh0oYnQkGR
v1oTJhieKOIYoA4IQGBtAkjD2uhYsZYECpOG9zLQ4I1YdE6O9RCDyTGoH20G sV+NH/gTGO1L
MNImQob3Y5AlTZ3eVpgIWcsDj0ZDoBkEkIZm7Ed6kZfA2tJQzGWT5d7ggTkN eQ8LloMABPIR
QBrycWKpphBAGpqyJ+kHBCCwAwJIww6gs8kdEkAadgifTUMAAnUngDTUfQ/S /tUIIA2r8WJp
CEAAAhYBpIHDoV0E2iYN8gmnQAACECiQwOIJXs69mXN34nzSd/bPKxhdHOfG iKdcVnDHVLZJ
rZKGOk7epM0QgECtCSANlQ1/NGwdAkhDrc9HNB4CEKg4AaRhncjEOpUlgDRU /IxD8yAAgVoT
qIE0OLcn+yfu3tGksoGKhlWHANJQ6/MRjYcABCpOAGmoTryjJQUQQBoqfsah eRCAQK0JIA0F
BCqqqA4BpKHW5yMaDwEIVJwA0lCdeEdLCiCwtjTc+PwsT6n455nmQQACENgq AaShgEBFFdUh
sIk0TN6O/TKZvtNlOnXfT139M/vgilVs9dNI5RCAAAQqTgBpqE68oyUFEChC GtKNYfZh1nBp
kKdxhs/slod2UiAAAQjECSANBQQqqqgOgY2lIdMYZrOoNIQPvDZPyt7s5GLV 5jjHgw1rW291
pGE9bqwFgTYRQBqqE+9oSQEENpOGRcYQk4auc+f82ohCv3vSL0Aagm/5F8fO Tr7xIw1tOvVv
esTCqq0EkIYCAhVVVIfAJtKQOo9BRiXMz/zj3B6e6CbyAaOndxzvR/uESh4E OYO+t3yYUQic
Q5tHJGB7C8crfD8J39FWEfk1qCHc7vD8QDcg3Kj/68HZ+Ym0NfZXZzey0taT L2EbAnUkgDRU
J97RkgIIbCoN0ZmPtjHEpGGggq7jpOYYJFWg35dluhfaCbx3fHWIW0JEGpQK xDINZnXLQgYn
x4PYr5Lw0BIgq3dPjvV2+11Vj7zvNUPV7NXjN8z6a1RcNhttwQMgAIGGEkAa CghUVFEdAhtJ
w0JjkD6mTISUcB6ogz0vwUT90B6C3IOfjFD/t+YuJNeNZAhMDkCFf2ut2K/i KGornk8YOTD/
BgpiPCP2jv3XnQyLNPTcWscvkbQZAksJIA3ViXe0pAACm0iDfXVlLMdgWpZx 9YT+iq/isT/i
EEZlM0BgvvHHxiCiX+WT8wnSK9T5gwx1UDmGC7Mtvd0LnW9AGpASCECgOAJI QwGBiiqqQ2Aj
afDvx5BqDDFpUF/izefQRGUrNtvjC2awwL+8IhwpiOt8qjT43/u9Cq/Put5l GuIEd84vor/q
WRTdgztmW6Onx7JdPVUzbXgizCjIXz3XSRkWKe5Es/TrCwtAAAK1IIA0VCfe 0ZICCGwoDXIH
pyxjiEnD+UEw0OAFXW+Wg+N0xBJiIwJB9E0dhshIQiQqNDkG9aPNIPar8QM/ 22FfgpE2EVJl
PkwxIyyxZqMLEIAABNIIIA0FBCqqqA6BTaRhsTFkD08wZxACEIBAWwggDdWJ d7SkAAKbSAPP
nqhFdpRGQgACOyRQA2nYuz3ZP3H3jiYFhBSqaDqBtaVhhx9CNg0BCECgLgSQ hqZH0Zb1D2mo
y6mHdkIAAnUkgDS0LKg2vbtIQx1PQ7QZAhCoCwGkoelRtGX9QxrqcuqhnRCA QB0JIA0tC6pN
7y7SUMfTEG2GAATqQgBpaHoUbVn/kIa6nHpoJwQgUEcCSEPLgmrTu4s01PE0 RJshAIG6EEAa
mh5FW9Y/pKEupx7aCQEI1JEA0tCyoNr07iINdTwN0WYIQKAuBJCGpkfRlvUP aajLqYd2QgAC
dSSANLQsqDa9u0hDHU9DtBkCEKgLAaSh6VG0Zf1DGupy6qGdEIBAHQkgDS0L qk3vLtJQx9MQ
bYYABOpCAGloehRtWf+QhrqcemgnBCBQRwJIQ8uCatO7izTU8TREmyEAgboQ QBqaHkVb1j+k
oS6nHtoJAQjUkQDS0LKg2vTuIg11PA3RZghAoC4EkIamR9GW9Q9pqMuph3ZC AAJ1JIA0tCyo
Nr27SEMdT0O0GQIQqAsBpKHpUbRl/UMa6nLqoZ0QgEAdCSANLQuqTe8u0lDH 0xBthgAE6kIA
aWh6FG1Z/5CGupx6aCcEIFBHAkhDy4Jq07uLNNTxNESbIQCBuhBAGpoeRVvW P6ShLqce2gkB
CNSRANLQsqDa9O4iDXU8DdFmCECgLgSQhqZH0Zb1D2moy6mHdkIAAnUkgDS0 LKg2vbtIQx1P
Q7QZAhCoCwGkoelRtGX9QxrqcuqhnRCAQB0JIA0tC6pN7y7SUMfTEG2GAATq QgBpaHoUbVn/
kIa6nHpoJwQgUEcCSEPLgmrTu4s01PE0RJshAIG6EEAamh5FW9Y/pKEupx7a CQEI1JEA0tCy
oNr07iINdTwN0WYIQKAuBJCGpkfRlvUPaajLqYd2QgACdSSANLQsqDa9u7WR huuzzsHZ6P2k
jmcN2gwBCLSWANLQ9Cjasv5tIg2jp3cc/6fzdJh5Ugji/SaBf5N111ONQpq9 3qZZCwIQaAoB
pKFlQbXp3V1bGpQxhF/9+13HyfSGQuJ9IZWsdBoqf4srNY+FIQCBOhBAGpoe RVvWv7Wloevc
Ob+2BgtMiFX/HncPvPxD90IWGJ77v3ZOjr0hBlnMW+R4IB97ve75ib3WxEpj 6A3FQnhyQ2El
fp3xTcQapuv0lgk3oZshNSxuttf3sJHGn1SFUSx1OKm1Nm9MxyFQAgGkoWVB tendXVsaEjMM
JNlwPLCj5sWxjr5WvPcCv0pLaJ/QZnDSN8HbvOPKWrG5C/KOWcZ+P7khu5L3 qZvww7nXMN1g
E9QD4wmakd7s5PLeO4OTwFSQBuadQAACIQGkoelRtGX9K14aImMW0SRBmI3w pzSqSK9VI1jL
nkkQzJjwchjWRMiIQ0j4v3N+kVaJ9+0/ugmlFHr5oH71IrZMwnXCtIRZTSxB qYknRmQUIAAB
CKQRQBpaFlSb3t21pSF7eCII7To22yML+aXBTiQk17LTAOpTuq40xFIaKSMg /qBD0lrCswPq
wNdKCEAgkwDS0PQo2rL+rS0N6RMh7bgbDDSYdEIY6dPGDmKZBqseb0NZET0Y 0YjnHhIjIMEm
vIaFzfDGNVNGQNKbHSzf9a4ZkQkQvh4xp4GvmxCAgEUAaWhZUG16d9eWBm9G gp/h92YkRHL4
/gyA95OBnuS4eCKkdw8GP3KbVcK1UiJ6MLoQnTkRTFOITYQMByOsqQkLRkAW NdvREy9MjkE3
0tgDEyGJFhCAQJQA0tD0KNqy/m0iDSkTj2OhfXunj1U3tOry22s5NUMAAm0i gDS0LKg2vbtI
QwnXXLEJCECgtQSQhqZH0Zb1r2BpaNMXiNaeBOk4BCCQnwDS0LKg2vTuIg35 P/wsCQEIQGBV
AkhD06Noy/qHNKx6CmB5CEAAAvkJIA0tC6pN7y7SkP/Dz5IQgAAEViWANDQ9 irasf0jDqqcA
locABCCQnwDS0LKg2vTuIg35P/wsCQEIQGBVAkhD06Noy/qHNKx6CmB5CEBg hwQmb0ajP4aj
V7sv49dXeTggDS0Lqk3v7trS8OT5kAIBCEBgewSSIVmMQYq8P5u5uy2uOw0a s1gdkIamR9GW
9W8TaWgZKroLAQiUR0BcJBmMJcdQBWMwviItMe1BGso7LNjSzgkgDTvfBTQA AhBIEkiXhlfD
3SYYYluXURKkgaO3XQSQhnbtb3oLgZoQQBrK2VGOc2O0d3uyf+LuHU3K2SRb qTUBpKHWu4/G
Q6CpBJCGcvYs0lAO5+ZsBWlozr6kJxBoEIGtS8N0OLgYTu0Jlcl3lk23ZHii QUccXclHAGnI
x4mlIACBUgkUJA2T0UWvH5MDowJIg96fZBpKPawbsDGkoQE7kS5AoHkEipEG ZQaD4UV/NE1c
ook0IA3N+9iU0COkoQTIbAICEFiVQCHSML3uD64n45c9+de78EFc4Zde3xST gUi+s2xUIriG
guGJVXcry9eeANJQ+11IByDQRAJFSIOMTegcw58Df4RiNPylN/zTHp5IvrPC baOQhiYeevRp
IQGkgQMEAhCoIIECpCEcgBAz0PZgD0mY18l3cqcZJN+ANFTwyKFJ2yWANGyX L7VDAAJrEdhc
GmRswhuG0IMRaoQCaUjsCyZCrnV4tnglpKHFO5+uQ6C6BDaWBnXdhDcSIckD b4TCTznMXKUU
ak5D8h2GJ6p7VNCy3RNAGna/D2gBBCCQILCpNMQvjvDlQOzBJB5eDrz7NCTf yT1CwfAER27r
CCANrdvldBgCdSCwqTTkDvybPMwCaajDoUQbCyWANBSKk8ogAIFiCCANxXBc VgtzGpYR4u9R
AkgDRwQEIFBBAkhDOTsFaSiHc3O2gjQ0Z1/SEwg0iECWNLjudJMBhQLXlZYw PNGgI46u5COw
iTTIp5oCAQhAYEsE3PeTWBm/vpq8GcmbBcb+9aoSY5CWSHuSjYy949ybOXcn zid9Z/8831m5
1KXINJSKuwEbW1saln5UWAACEIBA4QQkVI/+GMpX/J2XPMYg3UcaGhAo6UJI AGko/KRGhRCA
AAQCAkgDEbdRBJAGzm4QgAAEtkcAaWhUyKQzSMP2ThbUDAEIQABpIM42igDS wEkNAhCAwPYI
IA2NCpl0BmnY3smCmiEAAQggDcTZRhFAGjipQQACENgeAaShUSGTziAN2ztZ UDMEIAABpIE4
2ygCSAMnNQhAAALbI4A0NCpk0hmkYXsnC2qGAAQggDQQZxtFAGngpAYBCEBg ewSQhkaFTDqD
NGzvZEHNEIAABJAG4myjCCANnNQgAAEIbI8A0tCokElnkIbtnSyoGQIQgADS QJxtFAGkgZMa
BCAAge0RQBoaFTLpDNKwvZMFNUMAAhBAGoizjSKANHBSgwAEILA9AkhDo0Im nUEatneyoGYI
QAACSANxtlEEkAZOahCAAAS2RwBpaFTIpDNIw/ZOFtQMAQhAAGkgzjaKANLA SQ0CEIDA9ggg
DY0KmXQGadjeyYKaIQABCCANxNlGEVhbGp48H1IgAAEIbI9AUjim78bTt6PN y+TPq/VKdNNj
ac9SK0IaGhUy6cwm0gA9CEAAAlsiIC4Si8cqQr8bP3k2uHl05tw93W3Zf/Dk +Ie+Ox2708li
b0AatnSEUO1uCCANu+HOViEAgYUEUqThrTKGf33bv7qe7Bze+K0rLZH2kGnY +b6gAaUSQBpK
xc3GIACBfARSpUFyDMMKGIPpgbRE2jNzp2Qa8u1SlmoEAaShEbuRTkCgaQTS pGEkQxJV6efH
+Ww2k/YgDVXZI7SjHAJIQzmc2QoEILASgdRMg5KGj/MqFDGGmesiDSvtUxZu AgGkoQl7kT5A
oHEEsqVhNv+446KM4YPrvp8iDY077ujQMgJIwzJC/B0CENgBgSxpUAG7Cj9I ww4OCjZZAQJI
QwV2Ak2AAATiBAqThje9zmFvHHhG7Ne1/QNp4JhtJwGkoZ37nV5DoOIEqi4N rutOGZ6o+EFE
87ZAAGnYAlSqhAAENiWwXWlQ+YZu99AxP90XKyYcJM2ANGy6h1m/ngSQhnru N1oNgYYTWCIN
H1yZipirvD7vHJyPg4XNr/Kv0+m91jW86Io2XOaszV9M8gxyL0gmQjb8KKR7 SQJIA0cFBCBQ
QQLZ0uDKxY65dMEE+CxpCE1i0A0EIrc6IA0VPGZoUhkEkIYyKLMNCEBgRQKZ 0pA7rntisTVp
mJJpWHGfsngTCCANTdiL9AECjSNQmDR8iCQSxj92nIeDSPpBhifs8Yt8UiI3 aZi+Y3iicYcd
HVpKAGlYiogFIACB8gkUJw16hMKb8uh4fmC/s/qEBnNnJ6Sh/KOCLe6eANKw +31ACyAAgQSB
IqUhmTyIjVnkyy4EEynUpRNIAwdtOwkgDe3c7/QaAhUngDSUs4Mc58Zo7/Zk /8TdO9r9E8fL
6TNb2YQA0rAJPdaFAAS2RCBLGuQrfhWKjE1M347VJZcfeDT2lg4Bqq0kAaSh kruFRkGg7QRS
pOHdeP/Bk+GrkUTr3ZbJ2/Hkzejy5VDao+c3TBYU5548QXvifNJ39s8ruFPJ NFRwp1S6SUhD
pXcPjYNAWwkkpcF9Nz7+vn//Ua9/cTl+fbXLcn11+eLy/sNe94e+ekI20tDW o7SN/UYa2rjX
6TMEKk8gRRp0bH7y0+Dm0ZmMC+y2SI6h+1QZw1z+QxoqfzjRwMIIIA2FoaQi CECgOAJJaZi5
k5k7VZcw6FC9Ufk4m69XzHatdaVJSENxu52aKk8Aaaj8LqKBEGgjgaxMw+II XcG/MqehjYdv
g/uMNDR459I1CNSXANJQzr5jImQ5nJuzFaShOfuSnkCgQQSQhnJ2JtJQDufm bAVpaM6+pCcQ
aBABpKGcnYk0lMO5OVtBGpqzL+kJBBpEAGkoZ2ciDeVwbs5WkIbm7Et6AoEG EUiVhuk7ua2T
3Nxp0zL582q9Et30WNqzdOolEyEbdFTSlfkcaeAogAAEKkgg9Y6Qcn+nJ8+q cp+G4x/67nTs
ThfdDlKUAmmo4NFFk9YngDSsz441IQCBrRFIffaEGMO/vu1fXe/+yUrjt660 RNpDpmFrhwAV
V5IA0lDJ3UKjINB2AqnSIPeCHFbAGMy+kZZIe7i5U9uP1Lb1H2lo2x6nvxCo BYE0aRjJraOr
0viPcmdIeRLVKdJQlT1CO8ohgDSUw5mtQAACKxHIejT2/OO8CkWMQZ5UhTSs tE9ZuAkEkIYm
7EX6AIHGEciWhnUfG7HewybS1lLGoJ6IPUUaGnfc0aFlBJCGZYT4OwQgsAMC WdKgAnYVfpCG
HRwUbLICBJCGCuwEmgABCMQJrCMNb3odJ/zpvtimXCANHLPtJIA0tHO/02sI VJzAmtJw2Bsb
VdACsUVvcF13yvBExQ8imrcFAkjDFqBSJQQgsCmBTaXBeINxiDAD0b2Mv6/f mY17h91LvXzv
oZerWCQckmZAGjbdw6xfTwJIQz33G62GQMMJLJGGD65MRYyX1+edg/Nx+P6g 63QvP8i/knJQ
C49/7DgPBzP1jryvfu0+7Oo/DbqyoqzuLzl70XUiVcW3JXkGuRckEyEbfhTS vSQBpIGjAgIQ
qCCBbGlw5WLHFGMQV0iVBvtNpQVKFy4fdnqv5d/upbwjGhH8G4hCvCqkoYLH CE3aBQGkYRfU
2SYEILCEQKY0pOYYzJuxSG9+TZMGlWN4obMLH0a9g+7lC51viC25LNMwbUym wbk92T9x9452
f3duPhbVJ4A0VH8f0UIItJDAxtIQjEokhyeUH3QPOp0fR3rMoiuDFJJ4WE0a 3k+n75oyPIE0
tPADtnaXkYa10bEiBCCwPQJrSkN4xaUagPBGMfRkBf2jxib0m2IS/gLB9IWV Mg1Iw/b2PTVX
mQDSUOW9Q9sg0FoC60jDgpGLQv+kLp1AGlp7aLa840hDyw8Aug+BahJAGsrZ L45zY8TwRDms
m7EVpKEZ+5FeQKBhBLKkQb7iV6HIhIbp27G65PKDtGeyoDj35GGYE+eTvrN/ XsF9hDRUcKdU
uklIQ6V3D42DQFsJpEjDu/H+gyfDVyOJ1rstk7fjyZvR5cuhtEc/uQppaOth 2sJ+Iw0t3Ol0
GQLVJ5CUBvfd+Pj7/v1Hvf7F5fj11S7L9dXli8v7D3vdH/rqCdlIQ/WPJ1pY FAGkoSiS1AMB
CBRIIEUadGx+8tPg5tGZjAvstkiOoftUGcNc/kMaCtzxVFVxAkhDxXcQzYNA OwkkpWHmTmbu
VF0wqUP1RuXjbL5eMdu11pUmIQ3tPERb2mukoaU7nm5DoNoEsjINiyN0Bf/K RMhqH2i0bkUC
SMOKwFgcAhAogwDSUAbl+ZyrJ8rh3JytIA3N2Zf0BAINIoA0lLMzkYZyODdn K0hDc/YlPYFA
gwggDeXsTKShHM7N2QrS0Jx9SU8g0CACSEM5OxNpKIdzc7aCNDRnX9ITCDSI QKo0TN/JbZ3k
5k6blsmfV+uV6KbH0p6lUy+ZCNmgo5KuzOdIA0cBBCBQQQKpd4SU+zs9eVaV +zQc/9B3p2N3
uuh2kKIUSEMFjy6atD4BpGF9dqwJAQhsjUDqsyfEGP71bf/qerK1zeatePzW lZZIe8g05EXG
cs0ggDQ0Yz/SCwg0jECqNMi9IIcVMAaDWloi7eHmTg078OjOEgJIA4cIBCBQ QQJp0jCSW0dX
pakf5c6Q8vjKU6ShKnuEdpRDAGkohzNbgQAEViKQ9Wjs+cd5FYoYgzypCmlY aZ+ycBMIIA1N
2Iv0AQKNI5AtDes+NmK9h02kraWMQT0Re4o0NO64o0PLCCANywjxdwhAYAcE sqRBBewq/CAN
Ozgo2GQFCCANFdgJNAECEIgTWC4Nb3odJ/jp9N6UqxJIA8dsOwkgDe3c7/Qa AhUnkEsaDntj
owpKILqXZWqD67pThicqfhDRvC0QQBq2AJUqIQCBTQmsJg2zy24gDWEGQqcf 5NfDbvdQ5SS6
L8Y970WgGiZXoYUjYh5+hbHajJdImgFp2HQPs349CSAN9dxvtBoCDSewRBo+ uLPX552D87G8
kPKi63ivB8oezJtmAfnX6fRe62WCF2phWVI0Qi05/rHjPBzIi8uH3jtqYfVO ojZTs5KGqdwL
komQDT8K6V6SANLAUQEBCFSQQLY0uHKxo+cEwZSGwB6UItg/3cvALWIvbOdQ a2nV8FxB7EF7
RrI2pKGCxwpNKpMA0lAmbbYFAQjkJJApDX7YDjMNQciPpR/sfIP9pyADEVEN k58Y9Q7kxaBr
/mSLRbBdP9MwJdOQc1+yWJMIIA1N2pv0BQKNIbCCNJgMgTcqEQ46mHGEiFtE VCBleMIMVXQf
djs/jvTqidqCTMP76fQdwxONOdzoSG4CSENuVCwIAQiUR2A1aTDzEsyUBXtM wcxpiKUN7He8
oQx/GoSRjGBWhPerP94RZCb09ZZIQ3lHA1uqDgGkoTr7gpZAAAIBgeXSEB0v 8PIKpbypLp1A
GjhY20kAaWjnfqfXEKg4AaShnB3kODdGzu3J/om7d7T7J46X02e2sgkBpGET eqwLAQhsiUCW
NMhX/CoUGZuYvh2rSy4/SHsmC4pzTx6GOXE+6Tv751titUm1SMMm9Nq4LtLQ xr1OnyFQeQIp
0vBuvP/gyfDVSKL1bsvk7XjyZnT5cijt0U+uQhoqfzzRwKIIIA1FkaQeCECg QAJJaXDfjY+/
799/1OtfXI5fX+2yXF9dvri8/7DX/aGvnpCNNBS446mq4gSQhorvIJoHgXYS SJEGHZuf/DS4
eXQm4wK7LZJj6D5VxjCX/5CGdh6j7ew10tDO/U6vIVBxAklpmLmTmTtVV0no UL1R+Tibr1fM
dq11pUlIQ8WPJZpXJAGkoUia1AUBCBREICvTsDhCV/CvTIQs6IigmmoQQBqq sR9oBQQgECGA
NJRzQHD1RDmcm7MVpKE5+5KeQKBBBJCGcnYm0lAO5+ZsBWlozr6kJxBoEAGk oZydiTSUw7k5
W0EamrMv6QkEGkQAaShnZyIN5XBuzlaQhubsS3oCgQYRSJWG6Tu5rZPc3GnT Mvnzar0S3fRY
2rN06iUTIRt0VNKV+Rxp4CiAAAQqSCD1jpByf6cnz6pyn4bjH/rudOxOF90O UpQCaajg0UWT
1ieANKzPjjUhAIGtEUh99oQYw7++7V9d7/7JSuO3rrRE2kOmYWuHABVXkgDS UMndQqMg0HYC
qdIg94IcVsAYzL6Rlkh7uLlT24/UtvUfaWjbHqe/EKgFgTRpGMmto6vS+I9y Z0h5fOUp0lCV
PUI7yiGANJTDma1AAAIrEch6NPb847wKRYxBnlSFNKy0T1m4CQSQhibsRfoA gcYRyJaGdR8b
sd7DJtLWUsagnog9RRoad9zRoWUEkIZlhPg7BCCwAwJZ0qAC9oKfN73OYW+8 ZKEV/2zqjNWM
NOzgoGCTFSCANFRgJ9AECEAgTiCvNLzoOsHPw8tZMdIw7h06TiAfSAOHJwQC AkgDBwMEIFBB
AnmkYfys4zjdSz9xcPmwe1mINKhKut3DTu+NrjpVGlzXnTI8UcEDhyZtmQDS sGXAVA8BCKxD
IIc0SD7Aj+vBgEMgDfLCy0B4y2jDMD/6Hb1k76H8GmqHqUaW7DwbXz505N90 aZCxCaRhnb3K
OvUngDTUfx/SAwg0kMASafjgzl6fdyTeywu7yJsH5+MPg27wJ+8dazEZ0Xg4 0Ks73RfR1VVV
o95Bp/fancliqiq9IXkRrUfyDHIvSCZCNvDIo0uLCSANHCEQgEAFCWRLgysX OypRSNqAHeDD
mQ46l+BJhv9uQgJC8wirFfPQ9oA0VPD4oEm7IoA07Io824UABBYQyJSGMK/g B/VkpiHpEyqv
oA0gI3MQSMP4x2AUQ49k/DjKkoYpmQaO4BYSQBpauNPpMgSqTyCHNLg6wIcj FGoiZDg8ER16
sDRCrZWZaZCxCWtFM0KRmml4P52+Y3ii+scRLSyaANJQNFHqgwAECiCQRxok PRBJDJiZCsFE
hGCEQr8jExu9aZAPu8k5Cl6mIZ6i0MmMF2lzGpCGAnYyVdSQANJQw51GkyHQ fAI5pSEyCzI2
KXJrv6pLJ5CG5h+D9DCNANLAcQEBCFSQANJQzk5xnBsj5/Zk/8TdO9r9E8fL 6TNb2YQA0rAJ
PdaFAAS2RCBLGuQrfhWKTGiYvh2rSy4/SHsmC4pzTx6GOXE+6Tv751titUm1 SMMm9Nq4LtLQ
xr1OnyFQeQIp0vBuvP/gyfDVSKL1bsvk7XjyZnT5cijt0U+uQhoqfzzRwKII IA1FkaQeCECg
QAJJaXDfjY+/799/1OtfXI5fX+2yXF9dvri8/7DX/aGvnpCNNBS446mq4gSQ horvIJoHgXYS
SJEGHZuf/DS4eXQm4wK7LZJj6D5VxjCX/5CGdh6j7ew10tDO/U6vIVBxAklp mLmTmTtVl0vo
UL1R+Tibr1fMdq11pUlIQ8WPJZpXJAGkoUia1AUBCBREICvTsDhCV/CvTIQs 6IigmmoQQBqq
sR9oBQQgECGANJRzQHD1RDmcm7MVpKE5+5KeQKBBBJCGcnYm0lAO5+ZsBWlo zr6kJxBoEAGk
oZydiTSUw7k5W9lEGuRTTYEABCCwJQIVnKCwRpOY09CceElPhMDa0rDGh4dV IAABCLSNANJA
qG0UAaShbacw+gsBCJRJAGloVMikM0hDmacPtgUBCLSNANJAnG0UAaShbacw +gsBCJRJAGlo
VMikM0hDmacPtgUBCLSNANJAnG0UAaShbacw+gsBCJRJAGloVMikM0hDmacP tgUBCLSNANJA
nG0UAaShbacw+gsBCJRJAGloVMikM0hDmacPtgUBCLSNANJAnG0UAaShbacw +gsBCJRJAGlo
nG0UAaShbacw+gsBCJRJAGloVMikM0hDmacPtgUBCLSNQA2kYe/2ZP/E3Tua EBEhsJQA0tC2
Uxj9hQAEyiSANCwNQyxQJwJIQ5mnD7YFAQi0jQDSUKeISFuXEkAa2nYKo78Q gECZBJCGpWGI
BepEAGko8/TBtiAAgbYRQBrqFBFp61ICSEPbTmH0FwIQKJMA0rA0DLFAnQgg DWWePtgWBCDQ
NgJIQ50iIm1dSgBpaNspjP5CAAJlEkAaloYhFqgTAaShzNMH24IABNpGAGmo U0SkrUsJIA1t
O4XRXwhAoEwCSMPSMMQCdSKANJR5+mBbEIBA2wggDXWKiLR1KQGkoW2nMPoL AQiUSQBpWBqG
WKBOBJCGMk8fbAsCEGgbAaShThGRti4lgDS07RRGfyEAgTIJIA1LwxAL1IkA 0lDm6YNtQQAC
bSOANNQpItLWpQSQhradwugvBCBQJgGkYWkYYoE6EUAayjx9sC0IQKBtBJCG OkVE2rqUANLQ
tlMY/YUABMokUANpcG5P9k/cvaPJ0oDBAhBAGso8fbAtCECgbQSQBuJsowgg DW07hdFfCECg
TAJIQ6NCJp1BGso8fbAtCECgbQSQBuJsowggDW07hdFfCECgTAJIQ6NCJp1B Gso8fbAtCECg
bQSQBuJsowggDW07hdFfCECgTAJIQ6NCJp1BGso8fbAtCECgbQSQBuJsowgg DW07hdFfCECg
TAJIQ6NCJp1BGso8fbAtCECgbQSQBuJsowggDW07hdFfCGyDwPTdePp2tNsy +fOq5BLt71gg
JNkiDY0KmXQGadjGCZQ6IdAqAipYvhs/eTa4eXTm3D1tYdl/8OT4h747HbvT SWzXIw3E2UYR
QBpadXKnsxDYBoHpW2UM//q2f3Xd0scXjN+60n2BQKahUQGSziQJIA3bOIdS JwRaRUCkQXIM
w7YagzmvSvcFwsydkmkg1DaZANLQqpM7nYXANgjI0L4MSTT5RLm0bx/ns9lM ICANS1GxQL0J
IA3bOIdSJwRaRUAyDUoaPs5bW8QYZq6LNNQ7HNL6PASQhlad3OksBLZBwJeG 2fxjG4syhg+u
+36KNOQJOixTbwJIwzbOodQJgVYRMNKgYmdrf2otDXu3J/sn7t5RS2ex1juG l956pKFVJ3c6
C4FtEIhKw7h36MR+Os/Gy3XiTa9z2EtZ7kU3rO3h5fJ61l4iaEBWSxbUjDSU HrzY4G4IIA3b
OIdSJwRaRSA907Bq6E1bfvys4zjdwBQuH4av13aDzBVXbbBdkeu609oOT5Bp 2E34redWkYZW
ndzpLAS2QSCXNEhI9jIGnd4bFW+1EOgflWAI8xNWWkLe9BaORPqwKu0QOtj3 HnqVdV+kvWMW
izZgNrsMkhjdF1YDHna9nMfSDZlmSZqhwdIgOkSBQGA4SMM2zqHUCYFWEYhI wwdXgqgqr887
B+dj79dBVxIG9vvyV/8dlT+IL+/XEKwVVPtBqnK6L9QC4x87zsOB2pD/zkzG MmSjyXfUWtEG
fBj1Drx64g32Wp5jQ36rVEyZTuo6EbLYTIOwqOdX6Ma2+ucXE/eDctugrNpV e58iDa06udNZ
CGyDgC8Nrlx3GJ6abGnQUdz6kfitQrIaekiXjKR2pLmIMY/Yhow0BL5iXicb EHGa6OaCVexK
UjfUEmmYuvPx2/noz/nV65mU4bVf/phdmvJqNng1m2hbmLxT/zOrmL8OFxav hqCqol9sdes7
rFw2vRSdLDN5p3ZK72ISk4Y19qlRDaRhG+dQ6oRAqwh40mB9k4lnGpIROsxA +OqQsoyIRaf3
2hKRWEJiJWkI0x4ZRhI0YC1pmDY40yDhf/p+Lk4wfqeLFoigXL0RmZA7Ys4l RElQGb1RV2GY
VUbypzeRhe0VvdeywAZFbX1hSdmi1fjFm95q5QbOgrKk5dKLhdwMefE52R1n v45j0rDGPkUa
WnVap7MQ2B6B5dJgjSkEYwHdH0f6tQwTaDOwBiyC85sagLCyEXogI23UIJlX iL2TbEDq8ITZ
1oLhiXi1ntDITRqm75o7PCGxR4xBvrPaunD/qzOjC8oYjDRcq/g0/ENJg1lF hb2l0mCH8DVe
LxWONeoMVtlq5cui/nJpWNw1Td6Y3JPncl2SzgTqEuwge5/KDvU8JmOfIg3b O4dSMwRaRSCH
NBgn8H9U6DXDE+qn49mDe6knMwa/GnXQ3uD/yAwGE9T9WY/xyRCpSQIT6eMN iLxjJkl4DZCJ
kPFVErMuonmRhkvD1ZuZyTEEYUwCjCnaFYKi4tPlf8fyr4xiqOVN0F0a25bG 5k0WWHHr7ky1
Oflv+tf6FStfLaeyVHeWYolIQzibWO2g6D4Nd6jnfyn7FGlo1WmdzkJgewTS pSE2WtHcX9Wl
E83ONEgiQeUYzKjEm3mGMXiZhsHvoTQsTe9XcAHRhfPflDTE/q1gU/M0yco0 RKQhtk+zd6sS
QbNPkYbtnUOpGQKtIpCUhvjdnRzHHlFt2OsWSMP1bEGO4TKaaegjDcsmK+QJ 9kUtE0hD5B7v
6qms4T41O1cyRoEOpu5TpKFVp3U6C4HtETDSIN+2W1tkQoNvTjV8NPbSSy4l 8Ji4EgQVM5VB
QktQgomQ/RfqW6nEJElOeJFPL5xZth1iV9z6apmGFStfTQUWVy5/XYpOxhr8 OQ1xafD3qdmz
wd6Je4Ne3exTpGF751BqhkCrCEzfjfcfPBm+GkngbGGZvB1P3owuXw4Fgn5y 1cQuzj15ZPbE
+aTv7J8HJ97qvHCcG6Ol0iCX9gWD8fbgty0N6rupFWDMF1kVivzJkou8YWl0 3MQ5Vqy8SGlY
uunFUX/p6kuVJSIN1lNoZerJH7Okc9jG4O1cvU9/Rhqin+pWnd/pLASKJ/Bu fPx9//6jXv/i
cvz6qnXl+uryxeX9h73uD331hOwGSsMruT1D+L029IY3VrLhDxWHggCDNOSS pB1KQ3SfikCk
GUNkn5JpKP7UiYtAoMUEnvw0uHl0JuMULSySY+g+VcYwl/+aJw2D/85k3pwX BXWcCwOMDFK8
ng+u54OYNOjst7oUs4ZFpkBKs5P/1rEvxuTkksv5x0imIbZPIyKYsU+RBqQB AhAohMDMnczc
qZreqKPmzsrHWWTctoRfTWetDQmHhkqDjD4El+9rD5AwI7qgihiDkQZ9HyGT ypbXsUkPsbEM
fi2JgN4pT34JJyV4sV9EMLpP1QW0Zodm7FOkoZDTJZVAAAIQWECgBnManNuT /RN370jdlCn1
R76VXv5h34/Be+0PeytjGOibSQeT5uSu0hKTzALReznEf9127Nzq1ndYeYB3 AUC1jH9HyNie
XWOfIg2c6SAAAQhsm0ATpEHuGyixJ/mchfDZB6+UMUze6Wv69c2d5HaQZvml z55Y/PiGpX/N
8/yFpZVkLbDVypc+PGLtZtvkzU7p/RY3wjX2KdKw7ZMF9UMAAhCovTRcvVnh qZWDV+o52tW5
OISWaI2bylMubRSb7FMeWMVJDQIQgMD2CNReGiTeSNSRr6rnv07kuUcyOi6z 6sIiv+oif5Jl
ZGH1mHB3Kj9Xrycyv4GyWwKXr8Zmj0TK6vuU+zRs7xxBzRCAAAQCAnWSBvkS SYEABCAAAQhA
YFcE6iQNJPMhAAEIQAACENghgTpJAwkiCEAAAhCAAAR2SABpiNxVe4d7gk1D AAIQgAAEKk4A
aUAaIAABCEAAAhDIRQBpyIWp4upH8yAAAQhAAAIlEEAakAYIQAACEIAABHIR QBpyYSpB39gE
BCAAAQhAoOIEkAakAQIQgAAEIACBXASQhlyYKq5+NA8CEIAABCBQAgGkAWmA AAQgAAEIQCAX
AaQhF6YS9I1NQAACEIAABCpOAGlAGiAAAQhAAAIQyEWgBtKwd3uyf+LuHeXq T8UdjeZBAAIQ
aBiB6bvx9O2otDL582p7JdqLsXQtdWe1sMsBB6QBF4EABCAAgTUJqLD6bvzk 2eDm0Zlz97Qx
Zf/Bk+Mf+u507E7jZFrYZduckIY1PyoN+65AdyAAAQisQWD6VhvDg7PRdN6w Ip2SriWZmC7/
69v+1fVkh0+bLHzT47eudCq1y0gDogABCEAAAgUQkAgqOYbhm1kji3Rt5k5j 3uB1uVnGYBRk
eD1J7XJbpGF0fdW/GJ5+//O/vjqTIi/kV3lzDZtmFQhAAAIQSPvaPZIhieHr mZTCv/vusELT
I+lamjSoLu+wbdva9Mf5bJbe5VZIw+XLUfdxTyxh/GYiIORHXsiv8qb8iQ8/ BCAAAQhsTkC+
dksEvTTS8HHemLJQGlSXG9PToCMqTLpuqic1XxpEC3rPB9OpK0ZmXEHK1FW/ ypvyJ7xh85MF
NUAAAhDwpOF6dnkt0tCQItFTuiMlI9NgpKEhnTUdUT8fXPf9tI3SIAMQkk6Y aGM4fz7ofPHk
3yfnUuTF8NVI3pQ/yQKMU3C+gwAEILAhAU8a/phd/mFSug35ke4sloYq9vNN r3PYG6/dstZK
g8krKDl4OxVRkKkMZgRIvEFmNpjXZpkNPy2sDgEIQKDlBIw0DP6YDV6tHawW rTh+1nH8n84z
HRDt0PiiK3/svih+09IdKQsyDZtuUrfc+3l4uWltZn2kYT53nBujVW/uJJYw euNdCSNDEmZU
QniafIORBllAFmv5p53uQwACENiQgCcNr9xtSIMyhvCr86WEWeUNQWiUF06n 96aYgBurZaB6
lD7Ab7q8yVa1CXUDU7h8GL7epNpNpcGVeNnK4QlJJ7izyDze8dupuYDi6nps pEEWUIu9L+CK
IyqBAAQg0FoCJoL2/+tK2SjgpawslhB1AqMLwb9bMwYZ3Tc92k6mYdw7THEd K6ei/6q72Xvo
JSP8bIoyJ/Oj3lHaZH7CVdYcnpCxCaTB9gNRBFGH4EoVpKG15zg6DgEIFEjA k4aXbv+lK7G2
yPL6vHNwPo7UOejKF3T1fkflGF4Xurlo46U7UpZLwxpdlvZLLxasKCMXDwcz tZiYge6jvKNQ
jHoH/jtqdU3D1GNYpRBbAZHKy08nbZwIaYYnJNVgiryWmQ0ygyF4x7zJ8ESB Jw6qggAE2knA
SMPPv7s/lykNYgw/mji6QlBcSWhUj35fLA3y3XOtrWeFdm0J3k/MAFKdwF5e px60Tq3PpL3S
8PPFUEqgCDKnQX61NUL+ZJZp54ecXkMAAhAoikAoDb+vFUEXRX35Jh1NJ0Rj 5/jHjvpGvh1v
WC4N62830S+TKgg6m1SELGmIKcLG0jBtZ6YhuOTSeIPkGCTTYGsEl1wWdb6g HghAoOUEjDT0
Xri93wqXBldpQRgXJdY6nR9HXipexWyVrlfvrB+/M9usevRiYaZhg42qflkj FGoipBXvvV7b
BuC9Tg5P2KMV/iDFug2TmzRM37VyeEI+w4MXl3KHBpEDkQZJIYk0TFz1Woq8 KX+SBVr+Uaf7
EIAABDYn4EnDb9Peb9NtBG8dX4Opf9b4vRcafZNYN1JmtVm6I2XRnIbNtmj3 y+RLLv05j52H
3fgEhUAgrCEJNd1hwYjG6s1rtTQYb5A7OJmBCT30NJMX8qu8iTFsfqagBghA AAJCwEjD+cVU
yjakYSd1ymUEpkfbk4ad9GvBRtWlE23ONJgPs4xTiCXYD6xSDsEDq7jQFAIQ gEBBBJCGqoX/
9dqDNHADBghAAAIQ2DoBWxrkq2pjSphp+JDyaGzJQDSmp0FHZEKDd9+qRJft pJpzT26UOXE+
6Tv73s0St/XUzbXqXeeOkOQMIQABCECgHALTd+P9B09MiG1eka7pxzhF3Mt0 WZ5kJCG2MWXy
djx5M7p8OUztMtKwdfsu5+PKViAAAQjsmMC78fH3/ZsPzu5/e9X9zm1SkU51 f+irx0XHhnJ0
l+8/6vUvLsevrxpSrq8uX1zef9hL77JFgEwDAgEBCEAAAhsRePLT4ObRmSTt G1PkC3f3qTIG
eXBRqpa1sMuGA9Kw0Udlx45f0FQmegEBCEBgPQIzdzJz9XUTOr6WUT7O5tsr pgtW/dK7GJkW
dpnhCUQBAhCAAAQgAIGVCZBpWBnZej7OWhCAAAQgAIG6E0AakAYIQAACEIAA BHIRQBpyYaq7
G9J+CEAAAhCAwOYEkAakAQIQgAAEIACBXASQhlyYNrczaoAABCAAAQjUnQDS gDRAAAIQgAAE
IJCLANKQC1Pd3ZD2QwACEIAABDYngDQgDRCAAAQgAAEI5CKANOTCtLmdUQME IAABCECg7gSQ
BqQBAhCAAAQgAIFcBGoiDZ9P90/cvaOJ88BdrciTvykQgAAEIAABCBRC4O7E +cfQ+aTv7J/P
q/fjODdGe7cne4eT/aPJ3r2Jc7Bike5RIAABCEAAAhAohMA/x9WWhr8MlNFQ IAABCEAAAhCo
CIEbP1c10/AX1TIKBCAAAQhAAAKVIlC90Yn5/w946hPcNT5APgAAAABJRU5E rkJggg==
name="Aqua_Data_Studio.PNG"
filename="Aqua_Data_Studio.PNG"
iVBORw0KGgoAAAANSUhEUgAABTIAAAOiCAIAAADMhL96AAAAAXNSR0IArs4c 6QAAAARnQU1B
/45JREFUeF7svT9o48q//+0HniIPPEWKW6S4xQ3c4hu4xQnc4hs4zRq2OIFT nMApTmCLJWwR
zBaLSRHMNsFssZgUi0kRTIoFb7HgFAtOEVCaBacIOEXAKQLaIoWKFCpS6Ad5 QM9nNNJ4PPrj
kf9K9tsMXlkejWZekrN66TMz+r9c1y1Ir/9r+7bwf6+wFf/HW8uX6bXy/3jv tKZQ+P+8d/qK
Fv6//9PPw3PSSrxAAARAAARAAARAAARAAARAAARAYIEJcGVm5rxS+D//h8my /4k+8qXAjkmf
/Zcn0Y7l/twYAENazl+FP3ssvXMKH9zVQ3ftiKX1T+76sbtJ6cTd+uIlWkAC ARAAARAAARAA
ARAAARAAARAAgSUkwKVYvHNNDiUm0YOJyfUn5tqF927h917ht05fxvtO/sZm Tv7eKRywrH0z
/+yuUzp2N770E1k6T/JKLIMACIAACIAACIAACIAACIAACIDAYhAgC+aJN8f/ 6Nk1D2AzU5YT
rZQ+8lC3SNyyfS0nM//HKfy75/s4i5O/6hb+sgp/mYV3ZOZSIkVnySVRpxC6 n/gyvYuV4QWR
GQsgAAIgAAIgAAIgAAKLRICuDJFAAARAYEkI0F9vamn4b/i+W3jnFvYdFth+ 6xTeOMyx+Tt9
5Gve2n6i+Dct05q/7cI/XqI1lP62Cq96hd9NpuS+lv/RLfxj9tMbi23JFd2X c67o8YnqJBJV
DgkEQAAEQAAEQAAEQAAEQAAEQAAEFomAkG1m2l76x/ITabaSWPA7SH+ahT+8 9LrHEi2Qk/9v
t7DW8qZ7+63jfU0Bc9NP3M+5mQs554o+4N6DoXX5ZgCvHxIIgAAIgAAIgAAI gAAIgAAIgAAI
5JeAsG55geu3Yt1CvLl+i8Q9nCScxcYpdf1ETk4yTuk/mp6WU6J+7DTfGzfz BC1XernTR27j
gnJkpbESBEAABEAABEAABEAABEAABEAABMYjsHdiW7aYKE13gbbqx7T/sUYv RLLxvS8j1eST
Vfh3lwXJuYb/q13475an5f/djNJyKzpazrV8IDDu5VTghsP3WAMCIAACIAAC IAACILAABOTo
EJZBAARAYIYEyIRNyy2funvHzs4nZ/ujs33oFA+c4qGz9aGfNt87LO07G++c tTf25jur9+DQ
tjy4PalC3EfT/ly2D/esDzvW/rb1btt6W2TpzVY//b1pUfpr0/pzw3y91vtr 037o7ZGZcyen
9F8G8/H/t1KgvuzsM0XSKbDej5ZLWi53ZU/oSZ/QpX4B/gdCE0AABEAABEAA BEAABJROmzO8
HB/oLIr9ggAILCUBCo6Xz9z6uVv/4Va/seXSiVv6QsrtkKjvUvrMEhn7zhGT 9q0DJufrb6zN
Nx2KsfM/I5MqxD4u21/rzre6fVply59K9lHJ/rjH0uEuSwe7zNjfe9L+dov8 vPd6vf3HpvXk
+tHy/+nGa/k/ZvuiXf1UoVT5VGbpkC0bV8bgPHLxHdfxPxYIgAAIgAAIgAAI gMCiElhKGcBN
ARAAgSwQIKMmA69fuI0Lt/bdrXxlkXPPzFn8nCdm5oGWUyCdwuYbb6zV1wab Vi3Q8nEL+YO5
Pem3873unDfss5r9pcIi5wNmvkdazszc1/Ki9c9m74+N1m+rrCbUiZ0S0/Ku Ei335oKjiv5t
kYQ7jm3+6pm/ut57j8y8+KqoDiNX5p3j0fJF/R8I7QIBEAABEAABEAABEAAB EAABEJgfARJa
Um4S8tp54OSekAsV50FySqxb+wHr1s60/K219oen5V7Nxy3kT6vAtZysm4T8 a80+8Zych8oP
KULuqTi3cRYnp57tXrd2ipb/udH63zVPy2kO9l6g5S25E3tfy0nCXdfZ/We7 8a1KC5RI1KHl
uOMAAiAAAiAAAiAAAiAAAiAAAiAwLwIktCTelTPfyffIyUVsnA8ypxHm71kS w8vZCHPS8j8H
tFwuZOiscVTCQCGBlpN4syC5Fyd3bztUji/kbJw5jTCn8PgWJVrvXLbIyc2/ PC3/d6yWGyyA
/u+BaDlFyBtnjea3pmUZ5i+j+qlcfLU1ONNb6Cltg9Hy4g/HvfGekD6ldGCz x64HL/PHpHc0
UL5THrUVjIPr1A9Y9co37KCkLMpmZ1AiSa9Y72XZxWH1pMwyK6960iu8oz4H 3gq1PiM0Kn4T
r3CNVvCTSmbLKyY1zSuKvXz40zoPhwHHfkEABEAABEBg0QigEzsIgAAIzIkA XdxTJJx6rbO+
6yxOzoLnLEIuObk/2RvZuEhCy4NO7HIhQ7XcL0cUIrR8f5v1Wvfi5KIQb+63 wMn/3uyv/2vD
/GsjRsv9Kd9Iy+kRat5z1TzHqH6qsnRYrf+x2fhjvfnHKr03/lpv/LHW+Gut +c9a459VSs23
LDX+WS/8Q9PN89Tvx15ngX2z/D+daf1X5OmieVZfWauu/Nlhin7t1z9yj0wF tX2vwAs/N1b+
o7ryHy3jV2eb5qznXq1fSF8d7cafderq4Olor+wVpZUCJTbO6tsxJLmalv+H 6llv/HLdX71Y
Mw9KM7/VV+guzED1qgwjT8qOZM7/Qa3wdPeqJbLpNErhJm8y+JVXONH+r7YO H6/tjG3x3HEt
x7Bc46rnPloBgU7xjM5Ci8PXKRB5QAAEQAAEQAAEQAAEQAAEMkuAXIF6p5OQ +05Os7sdOTvB
fOx+l3Vu4++c9XeBmYei5XIho2v5uyLruM77rh/s9g2cT8b+j+Tkf65bf21Q 6mv5v03m4P/q
eWPL/U7skpZ7Y8srn1gndkqk4ubJin1SsM9WHErfVp3zNedixb1aZ+ma0mbr 7Yr/0HLZzIVP
HmgrqKapimxCFz3DLJ7bTMD+ibsL4Pneo67vFU5YDNk4qAb62in8N4liykJC Ws7Ob+bPmkx4
vJe0k9ky684QgcgLEX9r8jI9TbUaf0c5rRT8Z/cyVC2PF9dBzj6EdFoexc3n oHw1opb3+wuw
o9wVVi+8HVqe2b+tqBgIgAAIgAAIgAAIgAAIaBLgWu5N7SZ1X/dGklMPdlnL ycl5YooeGlsu
F0Jl8hHpkYXQt2ohFPDzxpZTVJyejuaNJ2daTn3a+2b+hvVd5y+LnPyPdfau arkZo+Xk5Czc
bVePq45jWVav8YqFxylIXv9rvfnXCguY/7Vef0sB8xUKkjferjUoYP7P6qCW s7A590PjioVV
C6+oK7ufBvSJvJee6t7vFM2Wg27JbFnKTP2Q+4X4pR04frSc7jRQ+f7HJoVz wxt6ofvgxfpp
axXOIttS5cOFBN3L1ZpT+QOZvYhuUCvqxO61xaswf3EOSuLdy9mtAS9GHc7A 1vRvH3gQ/I9R
+Wl3N13ercDTci+/D1ycMk4xVI0AbH+TIFre5SVIoW8m1caN6BXvHzWFm8wh GqkfLR9AZP7o
Ewiz9WP4vyxqnXFYXfHuoQSt410VYgCG24s1IAACIAACIAACIAACIAACmSRA 3kLuTR3X+YPQ
+jOuk5Z7c7xtfnA23jvrlOi5aCL1tZxJgVLIgJaHCmFazssRhVAn9j89LX+z xeda9x6E5s+4
Lmmn5+R/eUIepN4f6/6UbyxaHgTM/9X2pnyjuDmtfc2e4cZk5h+7ckid2Gv0 Xv+02bNd03FN
262flUzbodRzaLlMa9hXtls73PK1nCZm5wFzbtrX7e0zarPVeNPlKz2bcsq/ eT2lD3vMOQ+r
hddBp+jfWLZ+ePNPrygvc5n0nvrD8zUiHUpaTiuVj8qGf1t+72jqlE579/aV VPg/kreTxvvt
UgoxfUEN1dxrqV3+L7avbdGP+k+7/kjrvU7s/CaC10ney+Aax4OtU8Xek3m5 +d6yr+4eRvat
p+Vk3f5HJf+f7ZU3TFx9LQ9KYMF2YkJ99Wnjn55sJ3DmB5ei5ZwhgboNGsW/ +tUp/kbRe69H
PT9qKvxen4P6lYeUa7mEyD9bPrFbCdFsP9iG5dT/pJ3a5llLNF89nUIAw0ix BgRGIZDJ/7ei
7+WhqiAAAiAAAiAAAiCQWwLkCjR0nHVcJzOnUeXiQWhCyw+cjQ+elr931vZZ 4ka96s/E7mu5
XEiElkuF0LdqIX/Z/OHn1E2dzfr2gZL0fPJ3RWHm1t/UcZ2C5KTla15a97Tc e0Da7yZzcDJz
6sdOndhXa4NaTt7yhmk5L6txuNWzHZtC547bOCvZNIDXpY9i2XUcp364UXjr FP7hqS+HLMzr
S2CzQG7Gtflr3etuHcR1k7Xck8zgRSOEvQ11tDxqQ2nQcr+SsYXzvbzxhqyz l81D3AOFDApq
3wA/DLRUNkNPKZmWByupkzxTTS66Ay7NV7LMwaBxUtyQmcdpOSs2UkGVmxc8 z7+9SLh/J6JX
DnzbL0HZZKiWk7F7wWq/R7131BRugkM0Uk/LoxHtx7It/EmjMuqFP016X/m3 f8sAWj6KYeLm
BQiAAAiAAAiAAAiAAAhkkgDT8n3W4ZybOXun/ue8C/pHZ+vQ2Tx0Ng6cdTLz D84amTmXc6Hl
XqOUQnwtjymEablSCNNyVghNrs4mePuwQ4nk3Hso2rYksGzR+lvW8rXe67U2 f275vy2WSMv/
i0aYtz0t/88ek3WKltPQZU/L6XFoFNY2f3Wah+sUGG9S+rbXOik1Tthy44yW 95ontFCqn1Xq
n9aZlvfN3PHCpyb5ZOG14/sYWZ/c3ZoEnn9kWu7l8aOvTt+jvniB3+/twYCz 8H9nMDweFEj3
Aj4xRuENAzM0Cn/7mZMK9+8yOIU/DS9WTxFmUs2gOf/lFcI/xtTcG5dOriu1 6E8n0NGW15Gb
EJFGquX4NzhE4f/Roh0FHdrZcnAHxFuQMMof+a4j0oBjqxmCuPfgXpRNBltN u5C3igbyp8pN
cIhGyrTcUMY7sGNAqI/YwY1kG9leScujaEQiwkoQAAEQAAEQAAEQAAEQAIFM EiAXoLncqL+6
b+aKln90Nj86G4fOOpn5gbPGzXzfWX1jrbxmDzDjyqAUomr5YCFCy/uFkJH9 xQqx/txgzyQn
M+dPKZfHlr8LxpY7jv33uv2XFy3/Y633arX92wqrCY2VfuWZ+f9QwLxdIDFk Wk6fmZbzZ57R
U8ppbLlNWl77sEVxchYkp6j4WZmUiE1sTU+cOinTSvroOG71gxctl1LwYCpx p4AmITMKp0H/
6j+8zN5HpuV/BHJLD2l76xQvgrm1/Um2qyuvTE/8vBHChEDs6GPQiZ3mkH/L 5ZDNjsYm5ebT
pA1u2Nfy/l7iC5db1N9R0ImdtNzL4FvoYM37Pcm9looWUeWFjnorKf7fCpcj Gsgyk4h6hcu4
BmgHdSOMwb68GyIccjgNQlMy9AU7uvmMs9LqgDxF9VlbooHItzO8Evpazjfx PLxfuPcxQCRN
EU897fk9F+qlH2Ib2V4ZfjSQSEpYCQJpCWTy/63oe3OoKgiAAAiAAAiAAAjk lgC5wPpbNrUb
PRGNguRCOOWFjY/O+qHLtXz1vbPKtNxeec20Q2i5UgiLtx+xeDsLuXMtDwqh rdRCvAAt03Ka
yI1mXH9HWs7MvG+/+0Xr3Zb9tj8TO2m5/eeq9XrV/H21/T9Cy6nbsqzlFDdn Ws5i8eTklCqH
FC23TatT/bBFvbiZfrtu7bhCEk42PrDsuLUPxcI7t59OqT40yjewKX+OMerJ 7Pq9sumuwFu3
wLJxLffWk4nRBPFvXT5ymD3y6oeX4YBUnK/0l9m2PH10/WHSVKBXGnvu13/E bsgKYb7XoW2L
F8MKf+vS07aKfEescO75llwIfRVZc6Wl3r74PQXeEM9g/cozLF4Gj5hHQCRP KXvlPhbu264n
z65x6uf0Z1zzqPIh/TRKnJaVbBHQvH3R3s0LiSdjyDaP5uyt90q2Gm+92noN ca9bfKtAy9lX
asMD+MFR5ibvMZG+Ciy945d8RZ0UvL0Eh0M+i+RdDNQ5qP/QDJFbYSUIgAAI gAAIgAAIgAAI
gEAGCZB5rL1xaGQ4zbtOZp6g5WsH7uoHZtQr75wVmtf8lRct9zQhXAjF3nk3 +OLRgJZTIfRS
C6GbGp6Wm6/X2PByCpi/6/ddt5iT+1puv9kQNbT/IC1f6f17pf2vAqsJ2Tcl ipmTif/W8aLl
XMtpnnfWg50FM6uelltWp/J2iyLntU8VemQaJf4882DZ+3hcLu9vFPZdP73z LOuxt03l/uO7
uu9d5I3vvAm9pBfT8j/dApsZTn55D5omiWUTpHkKeuE/opxlFrcAjjwhDF7G lxabt4ztJWbD
s+CwkeDF5YkpvP6BtNNr0WAh0TVnDVdaGtJy2tGJd7OBN/Azu6EgiIk2lq9F Fqf8LzYrG33l
+zZH51VYgHJvzQKNRSeTj8rGMnvQ2JRvHihKxTMJ422PPac9+MqvRmgTVni/ Yq75o8u28nba
13IqWdyPCHHr356gOgwi9Vv3scP2LiGqH3ZW/uWtjGQbnGwDd4iUOsg3j7AM AiAAAiAAAiAw
MgH59j2WQQAEQGCGBJhR/8OeeUYBczLzQYv0P218dClazrV85b27Qr0gabD2 7160XGj5sELk
ktVC3lDUnX1vvlpjTyOngPnbovOzTWs8IWdObr1l0XLScvufdZb1smH/sWK9 Wun9b6H934qW
24X/6Uqd2P/gk5x5Wv6JpnxzzPuOZXXNXyxR/Lz4qlj44BYOvEQLIr13CyJx PyeBJIMSrr5v
SWt6zBvlmdj/8jb5y5NqkchRqbV8Q29l4XWHuR/1tO8X69KUbGxlsFWBF8VS zIZiL6x6aQr3
6zNYVd7G6JpTzqClvHpyi8iueT2lbaXKi1Z4C/8bNFBsFayMbC/TY4HI21Yt mUOTSVI1BEZ5
c17Op8DkFfiiYtS6/ldeq0Uhr73bDexQSo0V8MMcOFK52gKRfAii2Q5y8ypf vKQfgXdPhNcB
CQRAAARAAARAYHwCI/s8NgQBEACB8QjQxf3q3zSzukMTv5GZ0xPRRNqkp6PR fG/ewPI1vwe7
u7LvDeylJ45xLff2Pm4h5PZvPC3/fZX1Y6eJ3/7ZYnLeT5vWG1q5wUaV/73G erD/sWq/XrF+
L/R+K7S4ltMUYzxg/m96QBiPlq/RA9IoWu5puTeisn3R3vr3ZvHVVvEVvXsL /y6Sq/tOzs1c
kXOy9LCfJ/zdP/OixBTy7bs0rCmTBOK0fPz/1KdfArQcdyJAAARAAARAAARA AARAYGEIkEKu
/GWv/WNvvGUxc5Jz6tDOEz2unD0aLZiAnYaUU/d1f2JyetL4vz0t9wRk3EKC kLv5vysUMDf/
3DD/2jBJzvtpI3g0Gp/pbZXi5OTk1r8Lvf8ptP4r0HJu5glazmrPlUmYNo+N CyHXMXPZ0sPL
XwMt/3vQ55O3wrezJ/BZ9HJ36p/zdLCCERNetJx+PLNHhz0uD4Hp32NamP9N 0RAQAAEQAAEQ
AAEQGJmAZbsbb8zVP821v831f6z1NwNp7Y1FiaZMZ7Om/8MS675OTv66t/Zn X8vHLYRC7m9d
KqT7x0b336vd39e6r9dF6r1e9xJ7FhrNu87S72xIOXVfp1B551+F1u9r7AbB X/TML0nL2QPS
5Gg5jV/nUxDz3gWRci73YI/sza55her1T0a0fOSTcnYbisECAz3JMxnbHzj3 gnEEOat29sGi
hiAAAiAAAiAAAiAAAiAwBwJ7Z07vwdn4u7Pye3v1tRFO9CA0nmiOt8LvXvq3 QU7efbBpWy5Q
YxVy6pnyW3fv1LHve+3XG81/rbR+Ww0nehAaTbrO0r8KLP03675OTm7fd/e+ sEesDdNy9ox1
6dla1B1fVh1lGLmmgSMbCIAACCwwgfFGSSlTFeIjCIAACIAACIAACIBAHAHy 4ciZ3hJWUmSb
tpILHL0QPr8dTVz1xt07Gakm5OQUJ1fGlg9Eyym+T1F+ivWz5D3D/K03CRx1 yueJKbpIUXdH
xLXpDKfjy+DE/agSCIAACIAACIAACIAACIAACIBA7gmQgXMP/8d/7Dk9HY0/ /5wtUKK4N3/n
CyKxeDg9gzz4VlZxPtmbPOVbX8v5M9J+7xZedanzvZ/+MAs8/RkkmsWO7J3e 4xJ9iwQCIAAC
IAACIAACILCoBOgJLEggAAIgsCQEyJEpRTb2lVng6Xcp8Y/yV3zNv6X0v94y e6e56LyZ2FUt
JyfnSZj50AWRP+2GQ0tGBhAAARDIBQHxlxMLIAACIAACIAACIAACIKBJgLT8 f0zpAWn/a67u
2yt/m/aT6dgWEgiAAAiAAAiAAAiAAAiAAAiAAAiAwJQIkHoX/nBY2Py/WkG0 PNDyKe0SxYIA
CIAACIAACIAACIAACIAACIAACAgC0HL0CAABEAABEAABEAABEAABEAABEACB uRGAls8NPW4O
gQAIgAAIgAAIgAAIgAAIgAAIgAC0HFoOAiAAAiAAAiAAAiAAAiAAAiAAAnMj MCktb5ULJWO6
U8TNYBdzOwy4PzQrAvk9i7JQc9QBfyJAAARAAARAAARAAARAYPIE0mo5XZfL L1JxfqU+kev1
cOFyg+UdjbM7eS/TvpWgccB+lATQ8g+N/NO698GxJAAZh3n4OI7f0uSzJa78 MVsh77RYv+N7
GahJ8Us3uMUQh3QuNbecu1rxVc30z59ufV8sU32oLTpkdPKMfGSVwuP2NdU6 jFx5bAgCIAAC
IAACIAACIAACoxMYQcsjzW0i18rJhcjfjry7bv2VsKnRqU0stMucXPBktjY3 M6eavG8Z7xMq
MDJzhfOkyhFKnOreyph7lzYny/WPV8yZOQRp2pqkzR8+vaWTn1U++CEM6Hry j2L8OiSUDy3P
wF+kad31Q9NAAARAAARAAARAAASSCIyv5XIQm/ZEl/48+juC/UZe9CvBbbE7 vpdUSsYDm+FN
lDp7eZi38F4Akr342ybkT3W2he4RkMixeGak5sXv1K+q0NQRyFsk5BTmNb8U Sc6DCLB8v4Cj
kJmHP5bK71kGurNApbEzwI8b94+gt0bZcJwTJnxAlcJ5BqXaXrtEJ4V+AFnn 2A2eP+HjJSlu
CGny7Ylp15ztnY6vf1B+lIqv/OVgZf+HzI8jP5Sh7gD8rAgfRLGen34jCHyc lked+V75QT1H
OeEndmcNHgsCIAACIAACIAACIAACYxMYQcuTOrEb70cIwQldUQycreduI4mi chdAR6UG8jDz
pNf7mujEG6qzV43A1oTJiIXk/Gku98PqEm6dnyd5p/0otxehTVOHQZnvG374 1sBAbUN7ZNCY
xYkY8sDNAjmyrZQzzgmj6l+YQ1Q9B8dc/GilmRMhUh3l81bu2e4tR3CQafgn 5/Rr7u0oOD3Y
6fSjVvROlWDX/Rtevo0HNQ/9BsUmgwVSY72bHewHmyICH/nz799JiTrz/ZtE fj39myOp/xSk
/5lgFyAAAiAAAiAAAiAAAiAwFQIjaLkSbZZNUvaTiYSy4+RwhFicIuelQEvC dR4s3BcMEdke
lj/FnRJ9LR+2U7WSKc+Vfl/6wK4jIvbhYxEp2yKbWBDRTn5KKOUod3lS1jy6 Z4HQ9bjzh1cp
bVeLcBA4dBtF6GgEUqVpmjyVtoxc8/DBoqLkwxF3Syj5Bo3/rfmlVL/zfiNk +3RLizikvj00
9JaHfP7E0Ut7/iA/CIAACIAACIAACIAACMyfwMS1fATVERTiNDVsFONqeSj8 Lh8JpXBJNvzu
u5E3JkY4lqFO7L7UDYlUhzqZ066DSqZ2IVZt3ue8/2KFaMlYFEZVy6Xx6nHi NwK6yHNGp86h
mwKT7cQecItCOhEtF7+FfoeOVFFfdji+iDh5sf5FdK8YS8spTs6KZTDZjQNa LvWnvtM8vnFa
nnAfUP7LoLkXZAMBEAABEAABEAABEACBzBGYrJZLvVuZ7KVV9LBse5f4fICr H34My8OoTIPA
pjzPmVdntRq837uYYXto/hSaFD3lG1Ug6AsdZBi+U6//8EgzxjHIonWssf74 dqUOA1gGOl0P
jIcPa3lwGgwcQf+ohdqV9mgm12qwu3W/ni2jP2o61Vkq7S5yyje/Q3Uk0gQt D9dz4jUP9i6d
J4MndpyWh3+DEbWlXuulV0Xpp9o/o7R/DpFaHv6TotZTmhAh7cmD/CAAAiAA AiAAAiAAAiCQ
CQIT1nJpyrfRrstDXZo9+fFGg5cGn8RGV+cj9EPmW/GXGAbc72UdzEk2qGry tNUsYD4sf4p+
7NLcY5L59yck81uts9NWOV3gNzj/lNaJj2JStH4dZOaCpJjrK2ZBPYK0X7kc BWbaX0XY5frD
kgenK5OrN/JOI88feaW3lzikAyfGjGsedbjZIZYHw4eHGIjmyL9BcQTlH6Da DSH9HaJoLY/5
uYWYp/rRITMIgAAIgAAIgAAIgAAIZIlAWi1Pa03Ir0lAipCPdn7Q3Nqpuw1r 1g3ZQCBrBMI9
a7JWQ9QHBEAABEAABEAABEAABHQJQMt1SWn3xR2xQH+K+FHmIeOx9FSdsUes 5LQhoHwQ0CMA
LcdPGARAAARAAARAAARAYHEIpNbywcnB2Ce9y2gtZFMtnNdzBrvQBxKuDF+j X8JEckZWYyIl
T7WQTB3KqbZ0UoXHnW9zOevCjcrpeTipo4NyQAAEQAAEQAAEQAAElpZAai1f WlJoOAiAAAiA
AAiAAAiAAAiAAAiAAAhMnAC0XCuMP3HuKBAEQAAEQAAEQAAEQAAEQAAEQAAE iAC0HFoOAiAA
AiAAAiAAAiAAAiAAAiAAAnMjEKvl9pOJ+xYgAAIgAAIgAAIgAAIgAAIgAAIg AALTI0DqDS2f
2x2R6R1XlDxtAvTLwX2raUNe1PJx8izqkUW7QAAEQAAEQAAEQGA0AklaPlqJ 2AoEQGAcApv7
nfHTOBUQ245f
Re: State of support for Sybase ASE in DTP 1.5.0 [message #587270 is a reply to message #34500] |
Brian Fitzpatrick Messages: 500 Registered: July 2009 |
Hi Jeffrey...
--Fitz
DTP Connectivity
>I have 2 years experience with the Eclipse IDE for various programming
>tasks involving Python and web programming. I am now facing a large
>15.x, but it will also be necessary to deal with 12.x).
> own Jconnect 6.05 JDBC driver.
> My experience when I try this is that I can connect to a Sybase ASE 12.x
> server, but not all of its resources can be browsed properly.
> I receive the error:
> JZ006: Caught IOException: java.net.ConnectException: Connection
> refused: connect
> make it in during a later 1.5.x release???
> if one exists - I have looked, but I have not located anything.
> If I SHOULD HAVE BEEN ABLE to connect and view most of the resources on
> the v12.x and 15.x servers, can someone point me towards a resource can
> Sybase experts here; unfortunately, they have no Eclipse experience.
> Thanks *very much* in advance.
> Jeffrey Zelt
Re: State of support for Sybase ASE in DTP 1.5.0 [message #587339 is a reply to message #34674] |
Jeffrey Zelt Messages: 17 Registered: July 2009 |
Junior Member |
Hi Brian:
Sep 30 1:05:16 2005
Sybase ASA
day? ***
URL is:
server.
snapshot:
3 dependencies).
warning.
Jeffrey
System Developer
Q-Free ASA
> Hi Jeffrey...
> Can you tell me which version of the jConnect driver you were trying to use?
> --Fitz
> Senior Software Engineer/Sybase, Inc.
> DTP Connectivity
nfHTOBUQ245fjUmVMJHmoBAQAAEQAAEQAAEQAAEQyCyBpRtb3vzWzObByGzF soNr7oimVwFR<
Current Time: Wed Apr 24 14:51:33 GMT 2024
Powered by FUDForum. Page generated in 0.03698 seconds
