Home » Eclipse Projects » Sirius » Using ELK layouts in a Sirius based product
Using ELK layouts in a Sirius based product [message #1853956] Mon, 25 July 2022 16:22 Go to next message
Avi Shaked is currently offline Avi ShakedFriend
I have a Sirius based implementation that uses ELK layout (ELK Layered), when "arrange all" is selected from the diagram standard toolbox.
I am trying to create a standalone product distribution. Everything seems to work, except for the "arrange all." Strangely, when I used the same product definition to create a runtime environment, the "arrange all" does work with the expected layout.
Any tips on solving these?
The Sirius packages embedded in my product definitions appear below. Am I missing something?
I will appreciate your help,
Avi
<unit id="org.eclipse.sirius.specifier.feature.group" version="7.0.1.202205300817"/>
<unit id="org.eclipse.sirius.properties.feature.feature.group" version="7.0.1.202205300817"/>
<unit id="org.eclipse.sirius.runtime.ide.ui.feature.group" version="7.0.1.202205300817"/>
<unit id="org.eclipse.sirius.runtime.feature.group" version="7.0.1.202205300817"/>
<unit id="org.eclipse.sirius.runtime.ide.ui.acceleo.feature.group" version="7.0.1.202205300817"/>
<unit id="org.eclipse.acceleo.query.feature.group" version="7.0.0.202102190929"/>
<unit id="org.eclipse.sirius.diagram.elk.feature.feature.group" version="7.0.1.202205300817"/>
<unit id="org.eclipse.elk.feature.feature.group" version="0.7.1"/>
<unit id="org.eclipse.elk.ui.feature.feature.group" version="0.7.1"/>
<unit id="org.eclipse.acceleo.ui.interpreter.feature.group" version="3.7.11.202102190929"/>
<unit id="org.eclipse.elk.algorithms.feature.feature.group" version="0.7.1"/>
<unit id="org.eclipse.elk.graphviz.feature.feature.group" version="0.7.1"/>
Re: Using ELK layouts in a Sirius based product [message #1853973 is a reply to message #1853956] Tue, 26 July 2022 12:43 Go to previous messageGo to next message
Laurent Redor is currently offline Laurent RedorFriend
No real idea. This list seems OK.
Maybe you can start by debugging method org.eclipse.sirius.diagram.elk.ELKAlgorithmProvider.getCustomLayoutAlgorithms(), in field algorithmData you should have all "ELK layout" including "org.eclipse.elk.layered". If it is not present, it confirms that the ELK layout is not visible by Sirius (so probably a dependency problem).
If the algo is visible in the previous debugging entry point, another interesting entry is org.eclipse.sirius.diagram.elk.GmfLayoutEditPolicy.getCommand(Request),
Laurent
Laurent Redor - Obeo
Re: Using ELK layouts in a Sirius based product [message #1853980 is a reply to message #1853973] Tue, 26 July 2022 17:12 Go to previous message
Thanks Laurent.
It seems that I forgot (or did not know I needed to) add the features into the product's "contents" definitions. I did it and the issue was solved.
Previous Topic:Sirius web front end
Next Topic:Setting somethings in semantic model during validation
Current Time: Tue Sep 26 03:47:15 GMT 2023
Powered by FUDForum. Page generated in 0.02396 seconds
